Question about Video Cameras
JVC GR-D33U ERROR CODE EO4
ERROR CODE EO4 SAYS TAKE TAPE OUT AND REINSERT IT BUT TAPE WONT COME OUT
  • lindar171 Nov 27, 2008
    I have the error code E04 problem but mine says : remove and reattach the battery
    President:
  • 4,402 Answers
· http://www.camcorderinfo.com/bbs/index.php
· JVC camcorders
· Tap o the side to fix your problems
-only, only, only use the more expensive JVC tapes. They keep their tension far better than cheaper brands. Also, they won't rub off their oxide coatings on the heads as easily, avoiding the 'clogging' of the heads (which thereby requires constant cleaning-further damaging the heads).
-when and if you do get E- errors do a complete rewind or fast forward to the end of the tape in order to pull out tape slack. Then remove battery and tape for a while. If still screwed, then yes, sharply tap (not hard!) on the closed tape door. That may reposition those tiny switches that I mentioned earlier and get you going again.
-NEVER, EVER, EVER, leave tapes in the machine when not in use....it creates problems for the heads and the mechanisms.
-Don't leave the battery on the camera when not in use for extended periods of time. It can create problems with respect to resetting the computer controlled logic.
-there are little switches and interlocks that provide electrical feedback about the mechanical status of things to the main processor of the camera (ie. tape/no tape in camera, door open/closed etc). Over time, the mechanics get out of adjustment because of usage, humidity and certainly rough handling. So: treat the mechanisms very, very, very delicately. Don't use/store the camera in humid conditions, hot conditions or very cold conditions. Certainly don't leave it in your car---ever!
-get the camera "cleaned and ajusted" regularly to avoid these problems. (I know...more $$$$)
· -I keep bags of dessicant in an insulated camera bag with the camera to maintain dryness and optimal temperatures during storage.
Posted on Feb 11, 2008
No consigo el manual de la jvc gr-d33u
http://books.jvc.com/booklist.asp?Model=GR-D33U
Jun 27, 2011 | JVC GR-D33US Mini DV Digital Camcorder
Looking for Manual for JVC GR-D33U Mini DV Camcorder.
http://books.jvc.com/booklist.asp?Model=gr-d33u
Nov 12, 2010 | Cameras
Unit in safe guard mode why , it reads on screen jvc gr-d225e can you help me.also says Eo4 eject and reinsert tape but the tape well not inject when open. help.
I JUNNKED THE CAMCORDER AND GOT A GERMANY CAMERA ; ITS SAD
THAT YOU DID HELP ME WITH THIS LITTLE PROBLEM; NOT EVERTHING IS BASE ON MONEY; I ASK FOR HELP AND YOU ONLY
WONTED MONEY. sad sad
Sep 10, 2009 | Video Cameras
What is a eo4
Sep 10, 2009 | JVC GR-D73E Mini DV Digital Camcorder
JVC GR-D30U Digital Video Camera error E04
there was a hole under the tape deck.. u can try to force;y open it right there
Sep 01, 2008 | Cameras
E04 Error
Eject tape leaving cover open and remove battery. Re-insert battery and re-insert tape also leaving cover open. Keep repeating this process until eo4 message disappears. This worked for my GR-DVL100e after about four repeats. After getting your camcorder operational, they say it is good practice not to leave tape in camcorder when not in use.
Jun 26, 2008 | JVC GR-DVF21 Mini DV Digital Camcorder
JVC GR-D30U
Waarschijnlijk staat de kop vast
Oct 31, 2007 | JVC 580136 Camcorder
E04 Error Can't watch or play
Hi there, please check this link: http://www.planetdvd.net/board/index.php/m/131342/0/#msg_131342 Best regards, Arpi
Jun 08, 2007 | JVC Cybercam GR-DVL820 Mini DV Digital...
Eo4 error code
HI SIR the fault is caused either by the take up or supply reel in the camera they are not rotating when the tape is inserted.maybe A defective tape or hung reel brake can cause this issue.or maybe a bad loosen guide of the tape path is lame , Try replacing the tape, if this does not resolve the problem you may need to seek professional service to have the reels checked. thanx and plz try to rate and remember i am here just to help u thx
May 08, 2007 | JVC GR-SXM920 Camcorder
Eo4 error
hi a malfunction of some kind has occurred in this case the camcorders functions become unusable. -eject the cassette once and re-insert it - it claers up yoy sould consult your nearst jvc dealer. good luck
Apr 07, 2006 | JVC GR-DX25 Mini DV Digital Camcorder
Video Cameras Logo
1,108 people viewed this question
Top Video Cameras Experts
Are you a Video Camera Expert? Answer questions, earn points and help others
