Question about Samsung Axession 4 Device Universal Remote
Tv remote directions
How do I search for the code on a sansung axession 4 tv remote control?
  • tacckk7777 Apr 19, 2008
    Need code for samsung axession universal remote and orion tv
I have a Samsung 650 and a direct tv remote, which button is the setup button?
Posted on Sep 21, 2008
    President:
  • 2,712 Answers
You can find the remote control codes for difrent brands of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you reach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the following steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keys or press and hold SETUP until the Cinema's red light flashes twice to lock in your new feature. (If the red light does not blink twice, stop and repeat steps through 6).
To test the new feature, press and release the device key in which the new feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
If it hasn’t, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on May 02, 2008
I need a remote control code for an AXESS brand tv/dvd combo
AXESS brand tv/dvd Glen, try 711. Link below is where you can contact AXESS for Info if that code does not work.
TVD1801 13 13 3 High Definition LED TV with DVD Player
Apr 04, 2016 | Televison & Video
Tip
RCA Universal Remote Programming Instructions And Codes
HI,
Direct Code Entry:
Find the code your device.
1. Press and hold "CODE SEARCH".
2. Press and release the TV, VCR or Cable button. If programming an AUX position, press and release AUX first and then press the device type to be programmed.
3. Enter the 3-digit code number.
4. Release "CODE SEARCH".
5. With the device on, press another button to test (volume control/power button).If it does not work, repeat steps 1 to 5 with other codes which you have.
follow the below steps to set remote without codes
Code Search:
1. Turn on the device you wish to control.
2. Press and hold "CODE SEARCH".
3. Press and release the TV, VCR or Cable button. If programming an AUX position, press and release AUX first and then press the device type to be programmed.
5. Press ON/OFF repeatedly until the device turns off.
6. When the device shuts off press and release ENTER.
7. Try using the remote. If it does not function repeat steps 1 to 6 again.
To Get The Code Please Go To Below Website:
http://remotefinder.rca.com/default.aspx?site=rca
You need to select the following informations from the drop down list
1.Model of the remote
2.Type of device to which you want to program(TV/DVD/VCR)
3.Make of the device(Philips,Sansung)
Thank you
on Jul 27, 2010 | Televison & Video
Entering codes for tv on a 4 device axession remote
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Oct 21, 2012 | Magnavox Remote Control For Older Tvs...
How do you enter codes for remote programing
Read instructional manual Samsung Axession 4 Device it is universal remote control select tv or dvd and what brand the code is there and then press the number to remote.
Oct 21, 2012 | Samsung Axession 4 Device Universal Remote
I NEED THE CODES TO SET UP MY TV ZENITH TV
Remote codes for Zenith TVs. 008,101,117,142,149,175,241,311, 345,405,407,521,601,701,713,916
Jun 11, 2011 | Samsung Axession 4 Device Universal Remote
Necesito el codigo para tv sansung
I can help you with your URC-3021 Universal Remote Control issues.
The codes for Samsung TV's are: 0060, 0702, 0030, 0178, & 0812.
For complete instructions on entering the URC-3021 remote codes, please refer to my posted Fixya Tip One For All URC-3021 Code Entry.
I hope that helps.
_______________________________________________
Reassign URC-3021 Device Key
Urc-3021 Code List Download
One For All URC-3021 Code Search
Mar 25, 2010 | One For All URC-3021 Remote Control
I have an older Axession Samsung 4 device remote, I need codes.
have you already found the way for that old axession?
please answer to ezequielzelaya@ymail.com
thanks
Jul 16, 2009 | Samsung Axession 4 Device Universal Remote
How do I tell what model of axession samsung remote I have?
hello!
have you found the solution?
thanks!
Oct 16, 2008 | Samsung Axession 5 Device Universal Remote...
Codes
Cheers!
IrishDruid
Apr 30, 2008 | Samsung Axession 4 Device Universal Remote
Codes
I NEED INSTRUCTIONS HOW TO PROGRAM MY SAMSUNG REMOTE TO MY TV
Feb 16, 2008 | Samsung Axession 4 Device Universal Remote
Samsung Axession 4 Device Universal Remote Logo
1,169 people viewed this question
Jerry Greenberg
Jerry Greenberg
