Question about Muratec M1250 Fax
Muratec m 1250
I think imy termal transfer is to old beacuse my copies is no clear enought
    Scholar:
  • 159 Answers
Probably just needs cleaning. Try using rubbing alcohol to clean the head.
Posted on Feb 11, 2008
Settings on muratec mfx 2010
How can I fix the black paper when I copy in muratec mfx2010 ... I mean when I copying a paper.... the paper I get its all black
Mar 09, 2012 | Office Equipment & Supplies
Good Morning, Z4M plus TM how to change printer cartridge?
Here is a link to the manual that "should" answer any questions you have about the printer. I've had to reference it SEVERAL times!!
http://www.servopack.de/support/zebra/Z4Mplus_Z6Mplus.pdf
Hope this gives you what you need!
Mar 15, 2011 | Zebra Z4Mplus Label Printer
Hey.. the zebra printer z4m is sayin "ribbon out" but it doesnt take ribbon. So how do i fix it?
go to the setings, and check Direct Termal or Termal transfer, Have to be Termal transfere, then run manual calibration, if still going, try to go tu Ribon sensor and change the number, possible is to higth 250...?) change to low number, and try to calibrate again.
Nov 23, 2010 | Zebra Z4M Printer
NOT ABLE TO SEND FAX WITH ADSL LINE
Can you pick up the handset and dial a number and speak to the other person using the handset..?? You might just require a filter which your telephone company should be able to provide.
Aug 02, 2010 | Muratec M1250 Fax
Admin passwd need to clear
There is no documentation on the issue. Here's a link to Muratec Tech Support to ask for help...
http://www.muratec.com/support/service_question.asp
Apr 02, 2010 | Muratec Copier
Lable print ran out for paper and will not go back to normal. The lights on top are all on except Data , and is blinking Error Condition, Print Idle, Error cleared head open on the screen.
check the setings, change the setings, Media TYPE from Termal Transfere to Direct Termal.
if necessery, reset the printer to Factory Defult.
Mar 31, 2010 | Zebra Z4Mplus Label Printer
Reset code for muratec 1300 after drum replacement
I have already fixed it, Inside the durm,there has a fuse is broken.
Best regards
May 24, 2009 | Muratec Office Equipment & Supplies
Muratec MFX- 1430 Printer
first of all, you can change the toner cartridge at any time. the roller below is probably the transfer roller, which can be cleaned. you may also want to consider that the drum cartridge could be the culprit.
since this is a multi function machine, make sure that the lines are not showing up when you print, or receive a fax. if the lines ONLY show when you copy, then clean the small **** glass under the document feeder, that should be the source.
Apr 01, 2009 | Muratec MFX-1430 Copier
Muratec MFX 2500 copies have lines
need to be more specific, printing have both hor. and vert. lines aas well as copying ???
Dec 18, 2007 | Muratec MFX-2500 Plain Paper Laser Fax
Lines show on printed copies from Muratec MFX 2500
Probably a bad cleaning blade in the toner cartridge or a dirty charge wire.
Look for a small slider on top of the cartridge.
Muratec M1250 Fax Logo
46 people viewed this question
Top Muratec Office Equipment & Supplies Experts
Kyocera HP Expert
Ben
Ben
Adorjani Laszlo
Are you a Muratec Office Equipment and Supply Expert? Answer questions, earn points and help others
