Unable to upgrade RAM......
Hi all....
I have a pc in my office when I tried to upgrade the RAM (256 MBDDR II RAM exists) with 512 MB DDR II RAM in the other slot, the system booted with a error stating "Memory could not be initialized and Channel 'A' is not compatible with Channel 'B'' though my RAM size has incremented I used to see the same condition before upgrading (pc with intel PIII processor with 2.8Ghz) what could be done to get the best optimized performance out of that...?
Regards,
Hari
  • 1 more comment
  • harikreative Feb 11, 2008
    It works!! and as of now the pc is being inserted with 512 and i want this 256 to be placed in the other slot. What might be the cause of this problem?
    1 memory stick is 256 MB DDR II type and incremented it with 512 MB DDR II type in the other slot provided.
    Mother board - intel 8280 1G (ICH7 FAMILY)
  • brian c
    brian c May 11, 2010
    What happens if you leave just the 512 installed and take out the 256?
    Are they both the same speed memory?
  • 589 Answers
Sounds like they are 2 significantly different speed memory sticks. Normally, the faster of the two sticks will "clock down" to match the slower stick.
Without knowing the motherboard and memory stick specifications, it's hard to tell, but it's most likely a speed issue.
Posted on Feb 11, 2008
  • brian c
    brian c Feb 11, 2008
    I think the confusion here is the memory speed itself.
    For instance, one stick may be PC2-4200 (DDR2-533) and the other is PC2-3200 (DDR2-400), etc.
    DDR2 only means the "type" of memory, not the actual speed.
    The speed of the memory "should" be on the labels, or stamped on the memory stick somewhere.
What is the maximum memory capacity for the MX6027 model ?
Hello Marc,
The maximum is 1 GB. Standard, it comes installed with 256 MB but you upgrade with additional 256 MB or 512 MB memory modules. The modules you are looking for are:
256 MB DDR (1 x 256 MB) SODIMM (PC2700) 2.5v SYNC
512 MB DDR (1 x 256 MB) SODIMM (PC2700) 2.5v SYNC
There are lots of places on the web to find decent prices for this memory. I have included a few below.
http://www.memorystock.com/memory/GatewayMX6027.html
http://www.pcmemorystore.com/Gateway-M_Series_Notebooks-MX6027-ram.htm
http://www.computermemoryoutlet.com/Gateway-M_Series_Notebooks-MX6030-memory.htm
This document includes instructions for replacing the memory. It's a simple straightforward process.
http://support.gateway.com/s/Mobile/Q106/Blade/8511418.pdf
Hope this helps.
Have a blessed day.
Thanks for using FixYa
Jul 29, 2011 | Gateway MX6027 Notebook
I have a Gateway 838GM. It has 4 slots for RAM. It came with 1/2 gig RAM (2 sticks, 256 Megs each). I tried installing new RAM- 2 sticks, 1 gig each. If I replace the original 2 sticks, the computer...
Here are the specifications of the Gateway 838GM: You will have to replace the existing memory with thesesettings only: The machine comes with: 512 MB = 256 MB (removable) + 256 MB PC3200DDR SDRAM DIMMs. Supports Dual Channel DDR Nowyou can only upgrade to 4.0 Gig total. I would recommend going to this link and order the correct memory foryour computer I use them quite a bit. http://www.memorystock.com/memory/Gateway838GM.html Rob
Dec 01, 2010 | Computers & Internet
I upgraded my RAM to 1 Gig but it's still showing only 256 meg. Why?
Hi this model sopport 2Gig Memory Ram.
RAM Technology DDR SDRAM Installed RAM 512 MB Max Supported RAM 2 GB Number of Memory Slots 2 x DIMMs Supported RAM Speeds 400 MHz • 333 MHz Installed Cache Memory 256 KB
Please check in to your Bios system maybe share memory Video or capacity is setting
Nov 03, 2010 | Dell Dimension B110 PC Desktop
Hi, I wish to upgrade my Ram speed from 256
Hi friend,
You can use more then 2GB Ram in your motherboard. it should be DDR-1 Ram .....you can change..
Dec 28, 2009 | Intel Motherboard
What kind DDr memeory should i look for on my old P3 Direct desktop?
It depends on how old it is. it is has 256 mb in each slot then it probably could upgrade to 512 mb in each slot, if it has 512mb in each slot it probably could upgrade to a gig. if it only has SD ram in it though, you can't upgrade to DDR.
Aug 31, 2009 | Intel P3 Direct PC Desktop
I want to upgrade my ram what type of ram should i use and how what is the maximum amount of ram i can upgrade to?
Memory Upgrade for Sony VAIO PCG-K35 Laptop, the Sony VAIO PCG-K35 Laptop takes the PC2100 DDR SDRAM SODIMMs Memory Type, and comes installed with 512 MB = 256 MB (removable) + 256 MB (removable) of Memory. You can upgrade your Sony VAIO PCG-K35 Laptop to up to a maximum of 1.0 GB Memory, the system has 2 sockets to install Memory, already with 512 MB = 256 MB (removable) + 256 MB (removable) standard Memory installed. For best Laptop performance use the maximum amount of allowed Memory per slot for your Laptop.
Regards
Jun 29, 2009 | Sony VAIO PCG-K35 Notebook
Which memory ram for amilo pro v7010
http://www.fujitsu-siemens.ru/Resources/123/2080773523.pdf
Here's a link to the Data Sheet with the specifications to that Laptop in Adobe Reader format.
Looks like your Laptop came with either 256 or 512 MB of DDR SDRAM and it is upgradable to 2 GB of DDR SDRAM.
You can check to see exactly how much RAM your computer came with by going to Control Panel, double-click System and it should tell you how much RAM you currently have in the System Properties box.
The motherboard has 2 slots for RAM, you you could add a second 256 MB or a second 512 MB stick of RAM. Or if you wanted to upgrade to the 2GB of maximum RAM this computer handles, then you can take out the RAM chip(s) that is installed and install two 1G DDR SDRAM.
Jan 31, 2009 | Computers & Internet
512 MB memory boards do not work in my Fujitsu Lifebook S2020
frquance is not set and it is not recommand that 2 different friquance ram is not working propaties
Jan 09, 2009 | Fujitsu LifeBook S2020 Notebook
Upgrading acer laptop RAM
You Can Actually Upgrade This To 2 Gig Memory.
Each Slot Will Take 1 A Gig Strip.
I,d suggest Buying another 256 mb Strip, To Put Into Slot 2.
Or Buy a 512mb ( Half Gig ) Which Will Give you 750mb With your Existing Strip Already In There. ** Recommend 1 Gigabyte Max** 2 gig of Ram in This Baby Would Probably Start Glowing.
You Can Buy DDR/266/333 In 256/512/1 Gig Strips. These Are Commonly Known As SD-RAM-Modules.
Mike @ Compurepair.
Feb 28, 2008 | Acer TravelMate 2500 Notebook
Unable to install Windows xp
If you can afford it i'd look at trying another stick of 256 or a new 512 stick, XP doesn't really like anything under 512 and it pretty much won't run at all with 128, so if you can get it cheaply try that first if that doesn't fix it let me know
Oct 30, 2007 | AOpen MK77M-II Motherboard
Computers & Internet Logo
63 people viewed this question
Alun Cox
David Payne
David Payne
