Question about Kenmore 19233 Computerized Sewing Machine
Self winding bobbin
I just can't figure this out. I put the manuel selector on the choice that shows a bobbin and straight stitch in the largest stitch size. Would you please help me? Thanks!
  • 323 Answers
I think you need to push the bobbin winder (with your bobbin on it) towards the handwheel. Press the foot pedal and it should begin winding. If this doesn't solve your problem, post back with more details of what you've done and the kind of problem you are having.
As a last resort, go to Sears and let them show you how to wind a bobbin.
Sewman7
Posted on Jun 11, 2008
Digital display shows bobbin wind. Bobbin wind spindle moves slightly. When depress foot pedal, stitches for only a minute- stops. Cannot select any stitches as menu display remains on bobbin wind.
try putting a bobbin on to wind and then take off again, make sure when you do that the bobbin holder clicks back into the sewing position not the winding, you might need to give it a little push in the right direction then see if it sews ok for you. if not may need a service call.
Jul 20, 2017 | Sewing Machines
Haven't used my Kenmore sewing machine #385.19153 for a long time. The display shows "bobbin winding" I don't remember how to change for simple straight line stich
Try pushing the bobbin winder spindle to the left. It's on the top of the machine to the right of the spool. When this spindle is pushed to the right, the sewing machine is ready to wind a bobbin. Once the spindle is to the left, you should be able to select a straight stitch (stitches 10-12), set the stitch length and check the thread tension.
See https://www.manualslib.com/manual/505279/Kenmore-385-19153.html?page=44#manual for a picture.
I hope this helps.
Jul 04, 2017 | Kenmore Sewing Machines
My Bernina 830 will not switch stitches. It says the number but shows straight stitch and sews straight stitch
Is it a new 830 computerized model or the older 830 Record mechanical?
If it is the 830 Record, it needs oiling--1-2 drops of good quality sewing machine oil (specifically concentrate on the stitch selector lever and oil the metal parts that move against other metal parts) Do NOT oil the cams, plastic gears, any rubber parts, ie belts, bobbin winder wheel.
Bernina 530 through 830 Record Oiling Diagram
Oct 19, 2015 | Bernina Sewing Machines
CAn a brother lock 9290 sewing machine do just a straight stitch?
YES. ALL SEWING MACHINES DO STRAIGHT STITCH. EVEN IF YOU WOULD SET THE STITCH SELECTOR TO A ZIGZAG YOU COULD STILL SEW STRAIGHT STITCH BY SETTING THE WIDTH TO ZERO. OTHERWISE YOU COULD JUST USE THE STRAIGHT STITCH CHOICE.
Mar 22, 2015 | Brother Sewing Machines
I can't move the upper stitch pattern selctor to the K position.
not sure if this is any good to you but its all i can find at mo..The machine has a 'hold' in the blank (or red) posiiton. You have to push the selector dial in a little bit then turn it. If it is in the red position it will only turn clockwise...or go to this link... can move the upper stitch pattern selctor to the position Google Search
Oct 24, 2017 | Singer Sewing Machines
After I "undid" winding my bobbin, the electronic display still showed the symbol for winding bobbin and the machine will only sew straight. None of the other buttons like back stitch or change stitches...
are you sure you've moved the bobbin winding mechanism back to the right spot? if its still pushed over against the bobbin spool holder it may be stopping the normal functions from working. If that isn't the problem then it may be something for the tech at the Elna dealers.
Sep 10, 2013 | Elna Sewing Machines
Drop in bobbin on singer 6234 will not thread empty Bobbiin thread winds around underside od bobbin
try using a different bobbin and see if that helps, if it doesn't
then the machine may need to be checked to see if there is
something wrong with the hook and the hook race.
Nov 29, 2012 | Janome Jem Silver 662 Mechanical Sewing...
Shirring fabric?
Drop the bobbin with the elastic in the holder without feeding it through the holder, and enlarge the stitch length,
Mar 29, 2009 | Brother XR7700
Electrical problem?
Neither the needle up/down or the LED for the stitch selector will work if the bobbin winding pin/holder is pushed to the right (meaning pushed into the winding position). If you accidentally left the winding pin/holder pushed over, you will lose the functions of both the LEAD and the needle up/down button! (Neither of these functions can work while in bobbin winding mode!)
Nov 04, 2008 | Janome 4623 Mechanical Sewing Machine
Kenmore 19233 Computerized Sewing Machine Logo
146 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Douglas Plant
Douglas Plant
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
