Question about Kenmore 66312/66319 Microwave Oven
Oven error -f3-
We think our kids turned on the child lock so we press start when the l is displayed but it then goes to -F3- error and beeps 4 times. Then the display reads -f3- and we can't get that off?!?!? Nothing works with the -f3- error?!?!
  • 2 more comments
  • Anonymous Apr 08, 2008
    MODEL721.66319500 NEED A SOURCE FOR A NEW KEYPAD.
  • Anonymous Aug 19, 2008
    En la pantalla sale error F3 y suena pitidos no hace mas nada
  • Anonymous Dec 17, 2008
    I have the same problem, however I just took mine out of the box not more than an hour ago to plug it in, and the f-3 problem came up....I unplugged it 4 or 5 times, only to get the same f-3 display!
    Who do I contact about this?
  • SHARCNET-USA
    SHARCNET-USA May 11, 2010
    Did you try unplugging the unit for several minutes and plugging it back in to reset it?
  • Kenmore Master
  • 9,098 Answers
In most cases that code means you have a shorting keypad.
If you could post the full model number, I'd be happy to point you to the best source in case you or a friend want to replace it yourself.
Otherwise, we regularly repair these for customers nationwide for $39.95 postpaid plus thew cost of the keypad.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Feb 11, 2008
KitchenAid KHMS155LSS when press "bake potato" button,start flashing error F3
Question: Error Code - Oven - F3 Error Code - F3 E0 Answer Product Symptom:
Error Code/Message - Oven - F3 Error Code - F3 E0
Control displaying F3 E0:
There may be a problem with the Oven Temperature Sensor, or the associated wiring.
Power unit down by turning off the circuit breaker(s) for one (1) minute.
Power unit up by turning on the circuit breaker(s).
Monitor the oven for one (1) minute to ensure the error code does not display again.
Verify oven operation.
Jul 31, 2014 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Locked keyboard on a 1540tw
I guess your model number is GMV1540TW?
I think I answered this or a duplicate post already, but here goes:
The owner's manual covers that, but if for some reason you don't have yours, you can get it here.
To set child lock:
1. Press STOP/CLEAR.
2. Touch and hold START more than 4 seconds.
"LOCKED" will appear in the display window with two beeps.
To cancel child lock:
1. Touch and hold START more than 4 seconds.
"LOCKED" will disappear in the display window with two beeps.
Oct 06, 2011 | Goldstar MV-1502 Microwave Oven
Kenmore Gas Range model # 362.75491990 F3 error Oven will not hold temp - error message displays and beeps I Replaced the oven temp sensor same issue Is the control panel bad?
Many models of the GE microwave have sensors that can detect humidity from the foods you are cooking. This allows the microwave to make adjustments to the power levels used to cook your food. If "Sensor Error" appears, you should either press "Clear" to cancel the mode or leave the food in the appliance longer to give the microwave more time to detect the food.
Press "Time Cook" to manually enter the time if you receive an error message when trying to use the "Sensor Reheat" mode of your GE microwave. The error message may be caused by the food item being too large or too small to detect.
these are some other code error that will help you in case of next time.
  1. Step 1 Press "Off/Cancel" (or "Cancel/Off" depending on your model) to clear the error code. Note the code if it reappears.
  2. Step 2 Replace the touchpad if the code displayed is "F0," "F7" or "F10." A function key is stuck or shorted.
  3. Step 3 Replace the touchpad or the clock (ERC) if the code "F1" is displayed. Disconnect the ribbon connector to the touchpad. If no code is displayed after an hour, replace the touchpad. If the code displays again, replace the clock.
  4. Step 4 Replace the oven temperature sensor if "F2," "F3" or "F4" is displayed. "F2" indicates the oven temperature is too hot and the oven temperature sensor is suspect. "F3" or "F4" indicates the oven temperature sensor or shorted or open.
  5. Step 5 Replace the ERC if "F5," F6" or "F8" is displayed. The ERC is the main control unit. "F5," F6" and "F8 are codes that indicate problems in the ERC functions.
  6. Step 6 Inspect the door-lock assembly and circuit if "F9" is displayed. The door must lock when the oven is in use. If the lock mechanism is not functioning or if the detection circuit is malfunctioning, the stove will display "F9."
jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); }); NOTE:
"F3" codes mean your oven temperature sensor has failed or shorted out. The only thing you can do is to replace the sensor.
Take care.
May 11, 2010 | Microwave Ovens
Ge microwave jvm 1430 error code F3
F3 Key panel (touch pad) shorted This code will occur if a shorted key panel is detected continuously over 60 seconds. Replace key panel (also called touch pad).
Jul 17, 2009 | GE JVM1430 Microwave Oven
F3 Error Message
the code means this.
F3 Shorted touch pad panel
Good Luck
Dec 29, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Spacemaker beeping loud and f3 message driving us crazy
The error code F3 indicates an oven sensor problem. The oven sensor is most likely the failed part. The oven sensor probe must have the correct resistance readings at specific temperatures. When the electronic range control (ERC) cannot identify the correct resistance of the oven sensor or the resistance is way out of specs F3 will display.
I recommend calling a service technician to diagnose and repair your oven.
Dec 18, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave shows F3
microwave quits working and F3 comes up on the readout - along with a series of beeps - pressing any of the buttons on the touchpad does nothing - The F3 stays there and beeps intermittently
Jul 25, 2008 | GE JE1460 Microwave Oven
F3 Error Message
It needs a new key pad it is shorted the ge website has a list of error codes f3 is the keypad
Jan 31, 2008 | GE Advantium 120 Convection/Microwave Oven
Kenmore 66312/66319 Microwave Oven Logo
312 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
