Needing solution... good day... i just want to ask how can I fix a computer if it has no power display on the monitor? can I have a possible and good solution for my prblem? please help me..... thanks... >>hon_philippines...
    Problem Solver:
  • 5 Answers
First, check the linecord /power connections to the display.
If they prove out OK, then check the video connections. You may find them loose. If that's OK too, then:
You can either connect a different monitor, or add the appropriate
connector/adapter and use a TV.
Regards,
Posted on Feb 11, 2008
How to lower screen resolution on safe mode
Good day!
Right click in desktop > properties > pop up display properties > click on settings > advance > adapter > click list all modes
select the display you needed for your pc.
Have a good day!
visit HPParts us Computer Parts Power Supplies Electronics Hard Drives...
Aug 08, 2013 | HP Pavilion F1523 15" LCD Monitor
Screen Display stays on after several times of turning off and on
The most common cause of this is a failure of the filter capacitors on the power supply board. If you can do a little soldering then the repair is easy to do. You will need to replace the bad capacitors and then the unit should be as good as new again. Here is a link to additional information on which capacitors you will need to replace.
http://www.ccl-la.com/catalog/product_info.php?products_id=90
I hope this helps you out,
BuddyMc
Nov 30, 2012 | ViewSonic VA1912wb Monitor
HI i JUST BOUGHT A NEW COMPUTER BUT KEPT MY OLD MONITOR AND WHEN I TURN ON THE MONITOR THE GREEN LIGHT IS ON BUT I HAVE A BLACK SCREEN.
Good Day,
Please check the connection of the display port, may it be VGA or DVI. Be sure to have it connected to the right port. If the Computer have a video card, usually placed at the expansion slots, the Cable for the monitor should be connected there, not onboard. Onboard display port is located just below the PS2 plugs,where your mouse and keyboard (violet and green ports) are plugged in.
Also you may try the computer using other monitor. Possibly the resolution the CPU / computer is so high, your old monitor can have it displayed.
If all fails, you may ask from where you have bought the computer for possible fault on the new system.
Hope this helps, thank you for using Fixya.
Jul 10, 2011 | ViewSonic Computers & Internet
HP w1907 LCD Monitor goes to sleep by displaying a "monitor is going to sleep"error after turning on the computer and doesnt display anything. It works intermittently, in that, if the computer has been...
so if you test the monitor on a known good PC it does what?
fails, then its the monitor
works then its the failing PC
all old HP monitors pre 2010 many had a sleep timer
so push the menu key on the monitor
then look for sleep timer and turn it off,
the monitor defaults to that mode, so dont push reset monitor or bam back to sleep mode it goes. so turn it off again.
all this is in the manual, lost yours, wana read it first?
read page 4.7 see that? (osd +advanced +) power saver OFF
https://www.manualslib.com/manual/418165/Hp-W1907-19-Lcd-Monitor.html?page=25#manual
if that fails to fix it (tested on 2 PC ) the PC1 is bad.
that be a whole other WALL OF TEXt, ask.
Dec 10, 2017 | HP w1907 LCD Monitor
Display did not wake back up from sleep; no lights blinking and completely non-responsive, even after reboot. Display seems to have died. Possible adapter failure? I am running this on an '06 Mac Pro...
If you can connect an alternative monitor from a friend the fault of the monitor can be once for all confirmed. Now start from the power section, check for the power supply failure to the mains section of the LCD. If power is faulty and the +Bvoltage is absent , check for the drives, however if the power supplu is OK then a possible fault in the main board is for sure, a failue of the processing IC . you will need help from the service dealer to check up this board to confirm. Good day
Aug 16, 2010 | Apple Studio 17" Flat Panel LCD Monitor
Crt Monitor Macer Model C708 as soon as i connect the power cable there is no power, no display
Have you checked that power is reaching your PC? First, check your power socket by plugging something else in. Next, you need to check the monitor's power line.If it has a fuse in its plug, check that by substitution if you don't have a test meter.It is very unusual for the power lead itself to get a fault because monitor power leads are heavy and of good quality.
It is possible that an internal fuse has blown, but if it has, there must be a cause. I would not advise you to even check that due to very high internal voltages even when power is off. Unforunately, CRT monitors are worth so ilttle these days that they are not worth repairing. Your best bet is to find a used monitor locally, which should not cost you much because they can hardly be given away these days.Look in your local papers.
Apr 06, 2010 | Relisys Intro TE770 17" CRT Monitor
Rolling lines on computer screen
To isolate the issue i recommend to connect the notebook to any external monitor and check whether the display is good or not......If the display is good on the external monitor then u need to fix your computer monitor by local service center.
May 05, 2009 | Computers & Internet
Display fails after a couple of seconds
Connecting a different computer that works to it doesn't fix the problem(what does that mean, its not CLEAR at all)
my guess is you meant the new PC fails on this bad monitor , too.
ok the monitor fails on PC #2, sure....
so the monitor is bad, why ask for help, buy a new monitor.
why spend $100 to fix it when new is %50
why>?
your not going to fix any monitor, here, on fixya,
but there is one thing to check the very old monitors from compaq
ive answered this 4 times here now.
has menu botton
see that? push that now on the monitor
see that menu..
? one menu selection , has silly horrible, power saver timer on it
and a RTC clock that keeps time of day, (pc can be OFF)
if the power saver is on , get it off now, and if paranoid set the clock.
id set it. so its double safe, see?
this happened back in 2002.
i read you users guide for you its a 2001. oops, its got the above BS.
read page 18 and all related pages to this. clock and saver.
page 18 there, page 16 real.
if it one , the INANE thing will go to saver at odd times.
later this was removed for VESA , update, remote sleep rules. and time.
https://www.manualslib.com/manual/30090/Compaq-Tft8030.html?page=18#manual
May 01, 2017 | Compaq TFT8020 (White) 18" LCD Monitor
Monitor displays breifly then goes to blank screen
The power -inverter board probably needs an overhaul.
I redo many of these.
If the screen was pinkish or flickering before it finally got to this point, it is possible that a bulb has gone bad.
Fran
Sep 07, 2008 | Proview PL926WBi 19" LCD Monitor
Monitor problem
It could be a loose cable, or it could be going bad.
Is this a new monitor?
Mar 19, 2008 | Gateway FPD2275W LCD Monitor
Computers & Internet Logo
Alun Cox
David Payne
David Payne
