Question about Gateway 7415GX Notebook
I want to install a printer
I have a Xerox WorkCentre XK35c printer,scanner,copier all in one, How can I install it into my Gateway 7415GX PC Notebook. This printer is not listed in the files of my notebook.
Anyone can help?
Ferjan
    Genius:
  • 3,587 Answers
Yes..you need to get the download file from Xerox.com and install it from that application. Got backup?
Posted on Feb 11, 2008
How do I clear fault code 016-311 for workcentre 7345
That error indicates the scanner is not installed. Check the connection from the scanner to the main ess board and reseat if necessary. If cable is damaged, replace with part number 117K38440.
http://www.iteminconline.com/117k38440_117k38440-xerox-workcentre-7425-iit-controller-cable.htm
Mar 12, 2012 | Xerox WorkCentre M128 Copier
How to install Xerox WorkCentre PE16 scaner? i ...
How to install Xerox workcentre PE16 scaner?i install twin & driver but not work . Please help...
May 20, 2010 | Xerox WorkCentre PE16 All-In-One Laser...
How do I scan a photo onto my laptop using a Xerox WorkCentre Pro Scanner?
Just attach the scanner to your laptop.Install the drivers of your scanner into your laptop and restart the laptop.
Now start scaning your documents..
Regards,
polysandy
Apr 06, 2010 | Xerox WorkCentre Pro 412 All-In-One Laser...
Error 016-311 xerox workcentre M128
This error code means the Scanner is not installed. The reason for this code could be a bad or diconnected interface cable, or corrupt system software. Check the cables for connectivity. If the problem persists, it will probably require a call to Xerox service. 800-821-2797
Nov 08, 2009 | Xerox WorkCentre M128 Copier
Xerox PE220 scan
you do it by install the driver and then the scanner cd and you have the possibilte to scan via pc
Feb 21, 2009 | Xerox WorkCentre PE16 All-In-One Laser...
Xerox WC Pro 35 - Error 14-563
this code means your scanner has failed to setup correctly. this could be a problem that you would need a qualified tech to service the copier. there is nothing that you can do after you power off and power on (popo) the copier. it could be voltage, pwb board, or a binding scanner assembly.
Sep 21, 2008 | Xerox WorkCentre M118 Black and White...
I have a WorkCentre XK35c/25c that I now use just as a copier.(Not hooked up to computer) When turned on it has power but when you hit start it sounds like it is going to copy as the light bar goes across...
The scanner for the flatbed has failed to properly move. The rails may be dirty, or the motor may be binding. Additionally there is a home sensor switch that must be activated when the scanner is initialized. Finally, when the copy button is pressed, does the lamp on the scanner come on within a few seconds?
If not, the scanner lamp may have failed.
Zenbob
Jul 28, 2008 | Xerox Office Equipment & Supplies
Scanner problem
reinstall the driver for the printer from this site:::
http://www.support.xerox.com/go/results.asp?prodID=XK35c&Xlang=en_US&Xcntry=USA&Xtype=download&prodName=WorkCentre%20XK35c
Oct 23, 2007 | Xerox WorkCentre XK35C InkJet Printer
Gateway 7415GX Notebook Logo
47 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
