RCA 56 inch TV; model# P56938; service# P56938YX2
I bought a RCA 56 inch TV (model # P56938), from an individual about 20 miles from my residence. While transporting the TV in the back of my truck, the wind caused the outer screen (the kind that doesn't leave fingerprints), to rip into pieces. The TV still works good, but without that top screen, the picture has a very bright red, green, and blue lights shining in it. Where can I get a new screen for it? Approximately how much does this screen cost? And how do I fix this?
  • 2 more comments
  • estrass Feb 16, 2008
    I had almost the exact same thing happen. Except the model no. is P56926. I believe the outer screen assembly part no. is 240945.
  • NICKELSNIC Jul 14, 2008
    pLEASE LET ME KNOW WHERE YOU GOT YOUR SCREEN i CANT FIND IT
  • sfmission24 Sep 23, 2008
    O.K. I should have read all your comments first.. before I transported my beautiful 56" in the back of my pickup truck also.. and like you, the wind ripped the outer screen off and it hit by brothers pick up ( he was driving behind me ) .. so did anyone figure out where we can get a new outer screen and the cost.. please please share the info.. thanks AlĀ
  • luckyblueeye May 16, 2009
    Can't find that screen. It is called a Lenticular. The frame pops off and looks pretty simple to install...trouble is...I can't find the screen because the company has discontinued the model. Seems that they would at least have replacement parts for this model.
ladywinn
  • 5138 Answers
SOURCE: parts identification
I can help you with this,i will get back to you later today its 3am here and i dont have my breif case with me i just order a FBT for a RCA PTK195 .ThankYou for using FixYa. Have a Nice Day.
Posted on Feb 10, 2008
  • 2336 Answers
SOURCE: sony 65 inch screen tv
The lines you saw, i;m sure they are the ones called retrace lines but know the failure could be located on the red CRT board. Most likely the video amplifier is defective and not necessarily the CRT.
What is the model number of your TV?
Posted on Jun 17, 2008
welcomejee
  • 10594 Answers
SOURCE: 52 inch rca hdtv has
It seems convergence problem in your tv.
Let me know model number to help you out in better way.
Posted on Sep 27, 2008
  • 1030 Answers
SOURCE: RCA 52inch Model R52WH77 HDTV
may i suggest reading the ariticle the fl231 problem in my tips and tricks section of my profile. YOu MAY have a 5 dollars 30 minuter fix. Determine if you have the convergence option under the setup option of the customer menu. if you dont then congratulations you have a simple fix. i you do have the convergence option and the autoconvergence then you might have other problems. and will have to troubleshoot further. If so ill talk you through some more. THIS set has NO stk convergence ics. my feeling is the fl231 which i see alot on this perticlar model at the shop
Posted on Oct 08, 2008
  • 65 Answers
SOURCE: RCA 52 inch projection tv approximately 10 years
Convergence amplifiers need to be replaced. Professional can do this no problem. Call around for price
Posted on Apr 09, 2009
I have a rca tv model # p56938 and it just stopped working and now just makes a beepin sound any ideas on what it ,might b b4 i throw it out
If power light is green and just barely tries to come on you may have a High voltage problem.
On back of set where model number is located is a Chassis number : something like PTK195 ETC. what is that number?
Mar 13, 2012 | RCA Televison & Video
My 56 inch rca tv has 3 difrent colors on it turns on ok but show s it like their is 3 of everything on the tv
This is a common problem and is known as a convergenc failure. You can get parts and instructions from sites such as www.TVRepairKits.com
Aug 18, 2011 | RCA HD56W66 56" HDTV
My rca model d56w20 56 inch tv wont turn on
Usually its the CP150, CP120 and the CP114 capacitors that will cause that symptom. You can get the RCA repair kit by that same name from www.tvrepairworld.com which does include the repair instructions.
Oct 23, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
56 inch rca hdtv
Good Day;
The RCA TV uses a different type of Convergence Circuit then most other TV's. There is A fuse next to the FLY BACK that opens that can cause this. If not handy call an Authorized Service Center, get an estimate. Cost avg $400.00 to $650.00 depending on your location and problem.
Good Luck, big IRISH.
Sep 22, 2008 | Panasonic PT-56DLX75 56" HDTV
RCA-Churping Noise
it needs horizontal supply repaired and all will be well....
May 28, 2008 | RCA P56923BL 56" Rear Projection...
Parts identification
Feb 10, 2008 | Televison & Video
Rca projection tv serv#p56938yx mod#p56938 serial#c135c50tx chassis#ptk195s16p cant id
Here are some numbers to call for Flyback Replacement
Electronica 1-800-772-5578
Asti 1-800-221-1828
you will need RCA chassis# PTK195s16p - flyback number1541938b.
Feb 07, 2008 | Televison & Video
56 inch RCA rear proj T.V.
Sounds like the capicator on the high voltage is swelled,removing the back cover,make sure to unplug the unit first,there is a u shaped heat sink about middle ways of the board,inside that heat sink is a cap,it will be swelled on top of it,its a 2200 35v cap.
Jan 05, 2008 | RCA D56W20 56" Rear Projection Television
Tv is acting on its own
Most likely your problem is the remote sensor inside the TV set. The remote sensor is located on the front panel board or inside the reflective cavity somewhere around the secondary mirror. Good Luck
Jun 15, 2007 | RCA P46810LV/12BL 46 in. Rear Projection...
Televison & Video Logo
642 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
