Question about Maxtor Hard Drive
My local hard disk (c: drive) become not accessible
Please do help me with this..i can't access my local c: drive i don't have any extra hard disk..i didn't yet do anything cause i'm affraid i might delete file(s) on it..please lend me some solution on how i can access my hard disk and retrieve my recent documents on it..as soon as possible..
  • Fazlul Fazal May 11, 2010
    is the partition visible from my computer?
    President:
  • 2,351 Answers
If it's an IDE you can slave it into a working system & hopefully see it & copy the data off. If it's a seiral ATA SATA I/II, you'll need to add it to a working system. (All SATA's are masters). Again if seen, try to copy your data off. In both types it's a shot worth taking. Luck!
Maxtor's support page.
http://www.maxtorsolutions.com/en/Main/support.shtml
Posted on Feb 11, 2008
I can't access my local disk (D), it says drive need to be formatted.
D drive is usually the CD/DVD on most computers. C drive is your hard drive.
Jul 04, 2013 | Samsung HDD 250GB SATA 3,5" HD252HJ SATA...
Need to reboot i can't even get to the start screen, it keeps telling me to put in a disc.. i don't have a disk drive
This error means that your hard drive isn't functioning correctly. The computer is attempting to load the operating system off your hard drive but the computer can't find the operating system. There are several causes for this problem:
1. The hard drive has crashed.
2. The boot sector and/or operating system has become corrupted.
3. The hard drive has become disconnected from the laptop; this is unlikely but possible.
To determine what has happened follow these instructions:
1. Turn off netbook and remove all usb devices.
2. Turn on netbook and press whatever key enters the boot menu; often it is ESC or F10 - look on the first screen you see when you turn on the computer.
3. Look at the possible devices listed that you can choose from. If the hard drive isn't listed, then your netbook isn't detecting the hard drive likely because it has crashed. At this point you're going to have to take the netbook to a repair shop.
4. If your hard drive is listed, then it's possible that the hard drive is fine but that the boot sector has become corrupted. If you have access to a USB CD-Drive and a Windows installation disk or have a way to create a bootable USB flash drive, then there are some solutions that can be attempted. If you don't have access to these things, then you will have to take the netbook to a repair shop.
If you do have access to a Windows installation disk or can create a bootable USB flash drive, then post back to this solution and I can help you further.
Good luck, please post back to this solution if you have any difficulties, and thanks for using FixYa.
Jun 12, 2011 | Coby NBPC1023XPBLK Netbook PC
Can't get factory restore,no recovery disk for xps200, tried some other methods but to no avail..originated with blue screen shut down to prevent damage to computer..right now it doesn't do...
Connect the hard driver to another computer that works and run command prompt....Type CHKDSK (what drive it becomes with the : next to it like this C: , D: ,E: or F: ) /F /R ......
Example.... CHKDSK E: /F /R E: Is my second hard drive...don't turn off the computer it may take hours...After run Malware bites Here on drive from same computer and connect it to the dell and start
May 13, 2011 | Dell XPS 200 PC Desktop
My computer recognises the hard drive as a folder, and can't access the hard drive to search the contents. any ideas how to fix this?
Check if you hard drive is recognised as dynamic disk (device managment-disk managment), those can be mounted into folders!
TRY to access the drive from DOS PROMPT, to lunch one, go "RUN", and type CMD.
TRY to access your drive frome the adress bar on top of MY COMPUTER window, enter the letter of your drive and hitt enter. (the drive my have missing/extra files manipulating its access, the file can look like "autorun").
If none of the above was helpfull, dont give up, WIN PE minicd can always help, google for it , download it, burn it, and run it, you will certainly find it helfull, and you can access your disk in the browser, and copy the files into the working location!
GD luck
Jan 01, 2010 | VMware Workstation 4.x (WS4-ENG-W-CE) for...
Hard drive unaccessible
There is a program called On track recovery.
This application successfully recovers data from damaged hard disks.
You will need and extra storage where to transfer the recovered data.
Don;t forget to rate this answer if it helps.
Dec 03, 2009 | SimpleTech 250GB USB2.0 7200 RPM External...
Hard Disk Drive
Good day sir/maam, if your problem is the hard disk drive, try to reformat it first, usually reinstall your XP. if it cannot be formatted or cannot detect by your laptop. go underneath your laptop, and find the access panel for your hard drive. Remove the panel and you may find the Hard drive. Get a new one, replace it reinstall your OS. It would be better if you can add extra information about your hard drive problem. Better yet visit your local service center/dealer for proper advice.
Oct 09, 2009 | Acer TravelMate 240 Notebook
In my system have c,d, e, and f drives.i can access c,d,e and but i can't access the f drive..while accessing my f drive ''f: drive is not accessible''.access denied.but it appeare in local disk manag on...
just format the drive and check . After that if the drive not opened then go to disk manager and delete that drive and again creat the drive then check
Jun 08, 2009 | Computers & Internet
The hard disk in drive D: is not accessible
Hope I can help you with your problem. If your hard drive was installed to be used as D: in your old computer then you will have to set it up to be D: in the new computer. This may be why it is not being recognized. You can do this by connecting it as a slave on the primary IDE cable.
Also you will need to check the jumper on the hard drive to make sure it is set in the slave position.
Dec 03, 2008 | Maxtor Hard Drive
Maxtor Hard Drive Logo
134 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
Phillip Whisenant
Phillip Whisenant
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
