SPARKLE Computer Sparkle GeForce 8400 GS Video Card - 512MB DDR2, PCI Express, DVI, VGA, HDTV, HDMI Support, Video Ca PCI Express Graphic Card Logo
Posted on Jan 17, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Monitor my monitor is vibrating
Anonymous
Level 2:
Mentor:
An expert who has written 3 tips or uploaded 2 video tips.
  • Expert 103 Answers
  • Posted on Jan 17, 2010
Anonymous
Expert
Level 2:
Mentor:
Answers
103
Questions
0
Helped
25641
Points
302
Have you tried another monitor with the card ?? if after changing the monitor it still vibrates then replace the card or if you overclocked it put it to default settings
19helpful
My baby monitor won't stop vibrating!! about every five seconds it vibrates 7 times.
I had the same issue, I called Samsung, they where great help got right on the line with them. The issue is on the actual camera for the monitor the sensitivity dial is set to high, just lower it and you should be good.
Dość często zdarza się, że monitor drży i jest zniekształcony obraz. Wówczas muszę lekko go uderzyć i drgania...
Your screen has voltage issues need to be checked by a technician .especially its power supply section .some component need replacement
1helpful
My monitor screenis vibrating very much. even its
Try adjusting the refresh rate, specs indicate is should support 75 htz, default is 60
My computer monitor screen appears to shake or vibrate
well that happens because of internal faults, it is possible that some IC have gone bad, so take your monitor to service station as soon as possible before something worse happen
1helpful
Monitor is vibrating
You will be having with a strong magnetic field very close to the monitor. It could be speakers , Power supply of the speakers , UPS or the CPU itself. Try and getting some distance between the magnetic field. Shutdown the comp completely do the shifting and then restart and see
Samsung 2253bw lcd monitor makes loud, fast ticking noise > 10hz. Noise occurs even when monitor is powered off with switch.
Turned out ticking noise was harmonic vibration triggered by a nearby airconditioning compressor. Once I guessed the cause, putting a rubber pad under the monitor to dampen the vibrations eliminated the ticking. Removing the pad caused the ticking to reoccur. Ditto with turning the A/C off or on. Weird!
Monitor screen is vibrat left-right & up-down side
just go to the menu of your monitor then try to reset the setting so it will set the factory default value
hope this will help u
The monitor vibrates every now and then
Dear Sir this happens due to voltage fluctuations. Check the voltage of your outlet or else check with ups. If it continues even after replacing the UPS. You need to consult a technician.
Thanks & Regards
Nanda Kishore.
Acer monitor screen vibrates at lower half mildly
Try moving everything like speakers/power blocks/other monitors/pc cases away from the monitor.
Screen Shaking/Vibrating
Yeah, Degaussing is basically resetting the magnetic field inside the monitor. go into the menu options, and search for that option. if this does not work, then your monitor is really old, and needs replacing.
Top SPARKLE Computer Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a SPARKLE Computer Computer and Internet Expert? Answer questions, earn points and help others
