Question about Bosch Nexxt Premium WFMC6400UC Front Load Washer
No LCD Display
My LCD display went out on both my Washer and Dryer in this series. Is that something that would be covered under a warranty? I thought twas the purpose of LCD's. They don't go out!
I have Bosch Nexxt Premium washing machine. The numbers and letters do not display correctly. LCD control panel display hard to make out. Missing digets and characters. Does it need a whole new control panel?
Posted on Nov 10, 2010
  • 351 Answers
They can fail try writing a letter to the manufacturer,if there a good company the will help.
Posted on Mar 12, 2008
  • reichard Nov 10, 2010
    I also have Bosch Nexxt Premium washing machine. The numbers and letters do not display correctly. LCD control panel display
Display panel flashing 93 E
Warranty?? Call immediately Samsung Customer service if under warranty. according to: e84 was a new error code in 2013 and covered under warranty.
Mar 13, 2015 | Samsung Refrigerators
My hp dv600 when powered up looks normal but if i give it a few seconds the screen goes black and wont come back i shined a light and i do have picture but no light maybe ballast?
An LCD screen cannot produce enough light by itself. It needs an additional light source.
A Backlight is the additional light source.
A Backlight is a CCFL.
Cold Cathode Fluorescent Lamp.
Very similar to the Fluorescent lamps, (Bulbs), used in homes and businesses, but on a MUCH smaller scale.
HP Pavilion dv6000z series Notebook PC, is a general series designation. The EXACT model number is on the bottom of the laptop in a white Service Tag.
The HP Pavilion dv6000z series of Notebook PC's used either an LED or CCFL type of Backlighting.
Depends on which model it is.
As stated in the above information a Backlight is mounted in the back, or on the side of the LCD screen.
The LCD screen is composed of layers. These layers are held together by a metal frame which emulates a picture frame. If the Backlight is a side unit it will be held in place next to the layers, and inside the metal frame.
[Which means the LCD screen's metal frame, (LCD Panel Frame), needs to be opened on one side.
This will leave the layers which compose the LCD screen loose. The layers MUST be held in the proper placing when changing out the Backlight. Not an easy job to accomplish]
An Inverter is used to change the power coming from the laptop, to be used by the LCD screen, and Backlight.
90 percent of the time the problem is the Inverter.
The Inverter for the Pavilion dv6000z series of Notebook PC's is located inside the Display Assembly.
The Display Assembly is the
1) Display Enclosure Cover, (Plastic top of laptop),
2) LCD screen,
3) LCD Panel Frame, (Metal frame around LCD screen),
4) Display Bezel, (Thin plastic frame which surrounds the LCD screen in the front)
5) Camera Module
6) Inverter
7) Display Enclosure Cover Hinges (2)
8) Display Enclosure Cover Hinge Covers (2)
9) Wireless Antenna Transceivers and Antenna Cables
10) Microphone receivers and cables
11) Various mounting screws
[The Top Cover for a Pavilion dv6000z series Notebook PC is essentially the Palm Rest. The cover under the Keyboard]
With the Display Bezel removed the Inverter is located at the bottom.
(Display Assembly removed from laptop first)
HP Support > Pavilion dv6000z Notebook PC series> Manuals>Service Manual>
One example of an Inverter for an HP Pavilion dv6000z series Notebook PC,
Please post additional questions in a Comment.
Jun 11, 2011 | HP Pavilion dv6000z Notebook
I Bought a Bravo series 300 Washer and Dryer 18 months ago. They came with a 1 yr. manufacture warranty The first month I had problems with the dryer which was covered under warranty.. It was inconvenient...
usually most areas have a USED appliance store. usually these guys will have a bunch of old fridges and stoves around outside the store. Our town has three or four of them. you may have to ask around but these guys usually have parts for cheap. and they will sometimes make house calls. try googling used appliances in your area. they may also set you up with a cheaper washer with a METAL tub.
good luck
Nov 15, 2010 | Maytag Bravos 3.8 Cu. Ft. Washer
Washer won't start, display monitor reas
Is your machine a FAV9800AW LCD display?
If so here are some links for the SM and parts look up.
The Service Manual for reference. Sears Parts Direct for reference.
If you machine is the above type the issue could be related to the Motor which under warranty for 10 yrs. Could be the Motor Controller which is only under warranty for 2 yrs. Maytag Customer service info is in the SM. They will need your serial number off the machine located on the back of the console right side. If you are not a DIY’er I would call Maytag for a authorized repair service call to check out the failure.
Oct 14, 2009 | Maytag Neptune FAV6800AW Top Load Washer
I have an e15 code on the lcd display
Are you sure it is E15 and not F15?
F15 on an lcd display washer/dryer indicates dryer element faulty. this being the case then it will probably require a new element fitting.
Hope this helps
Dec 05, 2008 | Hotpoint Ultima WD72 Front Load...
Washer making a weird noise
forgot to include the most important step! We got the dimes out after wadding up a small piece of duct tape, sticky side out, and using locking forceps to grip the tape while fishing out the dimes from the drain pump.
Sep 03, 2008 | Kenmore Oasis HE 27082 Top Load Washer
LCD screen
Probably not as a cracked display usually results from dropping or sitting something heavy on the unit.
If it just cracked under normal use, then this would be a defect and it should be covered under your warranty. The only sure way to know is to take it in and try your best to convince them that this is covered under your warranty.
FYI, the warranty is probably from the manufacturer, unless you got some extended warranty through Best Buy? Otherwise the stores responsibility varies from state to state.
May 07, 2008 | Computers & Internet
KitchenAid Architect Series KEMC308KSS
check your power connections at the junction box, the unit for the clock is only pulling an amp at the most, but when you try to use the ove your putting the electrial connections under a load and if not tight or right will cut off the display and main cpu unit
there is a loose connection somewhere
Apr 12, 2008 | KitchenAid Architect Series KEMC308KSS...
Machine is dead
hard to diagnose ths one but i would start by verifying power in to all the pc boards (there is 2)
Sep 24, 2007 | GE WPGT9360EPL Top Load Washer
Bosch Nexxt Premium WFMC6400UC Front Load Washer Logo
516 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
