Hello the first thing to check is. the long pin on the inside of the door these sometimes snap off . if ok then check to see if the belt has come or snaped if ok then you may need to check the capacitor this next to the motor will have 2 wires coming off it these dry up good luck
regards
shaun
Also, if pin is in place, check that it does indeed make full contact with the switch on the dryer after the door is closed. You can check this by closing the door and then pushing it further in, listen for a "clicking" sound. If there is a clicking sound then the pin is not making sufficient contact with the switch and the switch 'arm' has to be adjusted or a new switch bought to replace it
