Question about Directv HR10-250 DTV Receiver
Hr10-250 powers downs
My reciever will just power off then reboot itself. It seems to do this while recording but it has done this while not recording. Any suggestions?
  • krissyswain Mar 09, 2008
    My receiver will either reboot on it's own or freeze all together. The buttons on the remote and receiver become non responsive and I have to unplug/replug. I also am unable to make a "successful call" through the receiver to the network.
It´s possible a bad contact on power or amplifier boards;it´s necessary to check them.Walter
Posted on Feb 12, 2008
Tip
Shut Down Your iPad For Real
When you press the power button on the <b>iPad</b> actually turns off just the monitor. That's why we talk so fast. What can be done to conserve battery power, or to recover from the freeze is to reboot the system. To do this simply by holding both the power button and the Home button until the red slider appears. Press and turn the <b>iPad</b>. Give it a minute and you can reboot by pressing the power button. It seems that a few seconds before responding so be patient.
on Dec 15, 2010 | Cell Phones
Reboots then shuts down again
To unlock the Channel Master CM7000PAL DVR:
1. Unplug the recorder from the wall outlet and DISCONNECT THE ANTENNA. Now plug it back into the wall power outlet.(This will keep the recorder from freezing and rebooting)
2. let it go thru it's normal bootup, tv guide search, etc.
3. When you are able to, hit MENU and then go up to TIMERS. Delete all of the record timers. Unplug it, reconnect the antenna, and plug it back in.
4. After a now a proper bootup, re-program you timers and you will be good to go.
5. And the best thing is, all of your pre-recorded shows will still be there on the hard drive.
I have 3 of these 7000pals and 2 have done this same thing, one of them did it twice. It seems like after years of adding and deleting timers, the DVR's software gets "confused". I've noticed twice it happened "on the hour" just as a program timer started while I was watching a program through the DVR. ZAP...Locked up! The power button would not even work to turn it off.
I would suggest that you do a yearly "TIMER CLEAN" to avoid this trouble in the future.
Oct 07, 2013 | Channel Master CM7000PAL HD DVR
My coby kyros mid9742 will not start up at all it just keeps rebooting
Turn the tablet all the way off, press and hold the VOL - and power at the same time for 8 to 9 seconds, it will show a green android guy with a system recovery menu. Use vol - to go down to Wipe Data/Factory Reset, press the power button to select it, go down to 'yes' to confirm, press the power button to select it, it will wipe the tablet, you then press the power button on 'reboot system'.
Apr 19, 2013 | Coby Kyros 716829701508 Tablet PC
Sony RDR-HDC100 will not remain operating and turns itself off
follow this step:
No power
  1. Check if the power cord has been properly connected to the power outlet.
  2. Check if the main power has been switched on.
    (DVD player's power supply transformer could be burned out)
Screen is "frozen" or completely black, or Power button does not work
  1. Try turning the power off and wait 3 seconds before turning it on again.
  2. Make sure the TV and VCR (if connected) are set to the correct channel or line.
    However the power supply can be faulty,some resistor,capacitor, diode or IC . see the block attached .If you do not have skill for electronic, go to the repair shop.
    God bless you
Feb 09, 2013 | Televison & Video
Reciever constantly powers on and then off again
ryantrulling,
If the receiver is powering off/on, there may be an issue with the power supply. Have you unplugged the receiver from the electrical outlet? If not, unplug for 10 seconds and plug back in. This will reboot the receiver and have it reacquire the satellite signal. If the lights do not illuminate after plugging the receiver back into the electrical outlet, please call 1-800-333-3474. We need to replace the receiver.
Ray Calo
DISH Network
May 16, 2010 | DISH Network DVR-625 DTV Receiver /...
I dont know how too reboot my dell dimension E521?
Dell seem to not make a lot of computers with reboot/reset button. If Windows is already running, you can turn it off or reboot it from the start menu. What you can also do is to hold down the power button for at least 5 seconds. Usually it will turn it off itself if you hold it for long enough.
Mar 08, 2010 | Dell Dimension E521 PC Desktop
Re: Denon AVR-1100 receiver Just powered it on after years of not being used, although I know it works just fine. Powers on fine, but the readout on the screen says "AUTO" (small) and "PROTECT" (large) and...
The receiver has gone into a protect mode because something is wrong and it shuts down to prevent further damage. Could be a power supply or output amp issue.
Jun 20, 2017 | Audio Players & Recorders
Flashing power light
same problem, my nv-ds50 powers up, but with the with power light flashing in twos and then powers itself down. The menu button sometimes works briefly when it's powered up. I had been transferring video back to mini dv tape from the pc (pinnacle studio 8) when I first encountered the problem and was wondering if I damaged something in the camera by powering up/down in the wrong sequence using my firewire cable?? I also seem to have a lower case "f" to the right of the timecode when it powers up - & cannot find any documentation as to what that could mean (although perhaps it's a "t" for timecode?)...I tried the c.reset option in "display setup" a few minutes ago - no luck then...but hey bingo, now I seem to have it back on line again ...go figure!
Nov 06, 2007 | Video Cameras
Directv HR10-250 DTV Receiver Logo
370 people viewed this question
Top Directv Televison & Video Experts
john milligan
rundiggity
Are you a Directv Televison and Video Expert? Answer questions, earn points and help others
