Question about Frigidaire FRT17G4B Top Freezer Refrigerator
Fridge problem When my Fridge is running, it is letting off a really bad odor in the back. It only seems to smell when it is kicking in to run. I have scrubbed the fridge and freezer clean so I know thats not what it is. Like I say the smell only comes from time to time.
  • 1 more comment
  • Anonymous Mar 14, 2008
    I also have a Fridgidaire less than 3 years old. Lately, when the compressor kicks on a really unpleasant odor emits from the bottom vent. I've cleaned everthing inside and out to no avail. There's no condensation in the drip pan. I've placed a deodorizor next to the drip pan, which helps somewhat but the root of the problem is still a mystery?
  • Anonymous Mar 27, 2008
    i have a brand new frigidaire fridge and when the fan comes on it smells bad ive taken the back off twice now and the smell is coming from the condenser dont know why but im calling the repair man in and when i figure out what the problem is i will post it DONT BUY FRIGIDAIRE THERE JUNK
  • Anonymous May 08, 2008
    I Have the same problem and my fridge is only like 6 months old. It smells really bad and ther is nothing going on that I can find. Its really annoying and makes the kitchen smell horrible. It only does it when the fan kicks on
  • 45 Answers
Usually the smell is the water dripping into the pan under unit place cleaners and use charcoal inside unit to remove odars that collect on evaporator and get concentrated then go to drip pan
Posted on May 16, 2008
Refrigerator Odor
Remove all the food from the unit and clean it with a diluted chlorine bleach solution and let dry and then do it one more time. Also get a box of baking soda and put it in the fridge to absorb odiferous smells odors
Jun 30, 2017 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Tip
Bad odor in refrigerators...
Many face the problem of bad odor in refrigerators. Here are few simple tricks to get the problem of bad odor solved:
  1. Keep an open box of baking soda inside the fridge it will absorb the foul smell.
  2. Place newspaper made into balls all over your fridge and freezer so that it is completely covered.Spray the newspaper with water until it is completely wet.
  3. Allow the fridge to run as normal for five days. During this time, the combination of evaporating water and paper will soak up the nasty smell. It should be noted that you will have to turn your freezer to the lowest setting to avoid getting frozen.
  4. Buy some freshly ground coffee.Dump 1 to 2 cups of the coffee grounds on a large plate and spread them around. Use multiple plates if the smells are extreme.Place the plate on the center shelf.Close the refrigerator for 24 to 48 hours.Dispose of the coffee grounds.
  5. Cut a lemon in half and put it in there - it will absorb the smells and make it clean smelling.
  6. Last but not least ....Empty contents of fridge wipe out with warm water and a little lemon juice then cover a tray or plate with kitchen foil and fill with charcoal put in fridge over night and the charcoal absorb es all nasty ouders then in morning remove plate or tray.It should have no smells at all.
Thank you for this opportunity t post few tips which i know. I think all the above are home made tips and anyone can try it out who are facing the problem of bad odor in their refrigerator..
on Oct 18, 2009 | Kenmore 50522 / 50524 Side by Side...
There is a strong odor coming from the freezer something like a fish smell or a burnt wire. The ice maker is working ok and the fan blows air just fine and the freezer and refrigerator are operating just...
The smell could either be the fan motor or the defrost heating coil...
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Mar 18, 2011 | Amana ABB1927DE Bottom Freezer...
Bad water
There is a water filter located in the toe kick panel in front of the fridge at floor level.
Problem solved.
Feb 22, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Odor coming from back of fridge
This is very unusual, most of the time when I get complaints about odor it's form the inside of the cabinet. This should be easy enough to solve though. The odor is likely from dust accumulated underneath, or from something in the drain pan. If the unit has visible fiberglass insulation underneath you should replace it with new because, even if the source of the odor has been removed, the insulation can still contain it.
Unplug the refrigerator, take off the kick plate and rear cover. Clean and vacuum the entire under- carriage, condenser, fan, and condensation evaporator tray.
Be gentle with the components though, especially the capillary tube ( a pipe about the size of a 14 gauge copper wire )
Jan 06, 2009 | KitchenAid Superba Architect KSCS25INSS...
Odor in GE side by side Fridge
Sounds like mold.  I'd try Lysol or one of the other products that claims to treat the odor cause in the air.  Spray a quantity into the empty fridge and freezer and turn it on.  Let the fans spread the stuff around. Try to find the internal vents which seem to pull air into the coils to spray into.
Nov 27, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Bad Smell in Fridge
To remove odors:
1. Remove all items from refrigerator or freezer. Throw
out any spoiled foods. Take out removable parts and wash
them and door gasket with mild detergent in warm water.
Rinse well and wipe dry.
2. Wash interior walls and door liner with solution of 1-2
tablespoonsful of baking soda to 1 quart warm water, and
wipe dry. Leave door open and let it air out well, with a
fan directed toward inside, and opened windows if climate
permits.
3. If odor still remains, try one or all of the following
means of odor removal.
a. Spread baking soda out on shallow pans (like shallow
glass casseroles, pie plates, or jelly roll pans lined
with foil) and put pans on shelves to absorb odors, or on
the bottom and in baskets of chest freezer. Leave open
and unplugged.
b. Buy activated charcoal (which is specially treated to
remove odor molecules from air) at some department store
housewares sections, appliance store, or pet shop. Spread
out on shallow pans and put on shelves of refrigerator.
Turn refrigerator on low setting and run empty a few days
so odors will be absorbed.
c. Spread cat litter in shallow pan in cabinet, turn on
and run empty a few days. If odor is disappearing but is
not all gone, replace old litter with fresh litter.
d. Pour several ounces imitation vanilla (not pure
extract) in a shallow saucer, put on shelf and let run
empty a few days.
e. Put fresh ground coffee in cereal bowls inside the
refrigerator and let run empty several days. A slight
coffee odor may remain, but will disappear after washing
again with baking soda solution.
f. Pack each refrigerator shelf with crumpled newspaper.
Set a cup of water on the top shelf or sprinkle the
newspaper lightly with water. Allow refrigerator to run
for approximately 5-6 days. This method takes a bit longer
but has been effective in removal of strong odors.
g. Buy a commercial odor remover, and follow instructions
exactly. Several companies manufacture a liquid
concentrate which sells for about $3.00 for 1/4 to 1/2
ounce. A couple drops are put on a piece of cotton and
placed in the area to absorb odors, in the cabinet or
in a room.
Three of many brand names are: "Odor-Away" by Wrap-on
Co., available at hardware and hospital supply stores,
"SuperCD" IBL Household Products by Crackerbarrel Sales,
Avenal, New Jersey, available in pet supply department
or special products in grocery, or "Clean-Air" at some
appliance repair shops.
Hospital supply stores carry Dow Chemical Hospital
Disinfectant and Deodorant Spray. Spray into cabinet and
quickly shut the door. Repeat.
4. If none of these methods removes all the odor, then it
has probably penetrated into insulation. Contact an
appliance service company for an estimate on cost of
removing the liner and replacing the insulation. If cost
is too high you may prefer to get a new appliance. It
could be used for occasional cooling of soda pop where
the odor will not get into the beverage.
Ice and Refrigerator and Freezer smell like alcohol chemical
I believe that you might have a coolant leak causing the chemical odor. You really should get it checked out by a fridge repair-person because it's not healthy to breathe in the fumes.
May 21, 2008 | Hotpoint HSS25GFP Side by Side...
Very bad odor in Maytag refrigerator
There is a very bad smell from the bottom of the refrigerator . There is a pan under the refrigerator with a very bad smelly Liquid , How can I clean that pan I couldn`t pull it out ? Thank you
Feb 20, 2008 | Refrigerators
Stinky Ice
You could try using ice aid, http://www.partadvantage.com/store/showpart/10127281. However there is nothing on a fridge that causes an odor only things that are put into the fridge i.e. food, water quality.
Nov 07, 2007 | Refrigerators
Frigidaire FRT17G4B Top Freezer Refrigerator Logo
599 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
