Televison & Video Logo
Posted on Jan 17, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need a manual fot mitsubushi CT29GB1 as I was
I need a operators manual fot mitsubushi CT29GB1 as I was given a TV without one. Have no idea how to tune or anything else. Looked on net but no luck.
Anonymous
Level 2:
Scholar:
  • Expert 108 Answers
  • Posted on Jan 17, 2010
Anonymous
Expert
Level 2:
Scholar:
Answers
108
Questions
0
Helped
30089
Points
339
Mitsubishi's TVs are much better their cars but some have a weird tuning system. Under the cover for AV3 input (lower right front of TV) is a small recessed button marked 'preset'. Push this, then choose 'Auto' to scan and load the channels then choose 'Manual' to adjust and reassign them to the right channels.
1helpful
How do I remove the battery. From a Mitsubushi Colt
The service and repair manual with diagram will guide you to fix the problem and you will get the manual from the given link https://toolsnyou.com
How to fix a LT55265 Mitsubushi LED Flat Panel TV that has a constant blinking green light?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
Blinking codes details of many popular brand TVs are given. Surf the site with patience.
If blinks continue without any pause, the main board is faulty.
My proscan needs capacitator fot 42la425h
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Circuit diagrams of many popular brand TVs are given.
I need an owners manual fot TV dp256649
There is no such model Sanyo TVs manual in internet to search. Please check the model number once more. You can locate this number at the back cover of the TV.
Was given a second hand plasma LG 42PC1RR without the manual.dont know how to operate the tv,especially the recording feature..plss help me..tnx
Hi, for your tv manual go here
Type in the brand and model number and download your manual.
http://circuitworldrepair.com/cwr.html
[email protected]
http://www.corkin.com/Profile/view.cfm?userid=77703
1helpful
I bought a Sony SVO-9500 MDP VCR witout the manual, cannot get a manual anywhere!!! I wish to now the menu commands tPE SuH Cnr Ynr YEn FrE uIA FOT Please help, what do they mean!!!??? Thank...
Settings are described in the manual downloadable now at www.eserviceinfo.com
From the manual
tPE = tape end operation mode REwind/EJect/STop
SuH = SVideo selection AuTomatic/OFf
Cnr = Chroma noise reducer ON/OFf
Ynr = Digital luminance noise reducer ON/OFf
YEn = Digital Y enhancer ON/OFf
FrE = Freeze mode selection FRame / FIeld
uIA = VISS index marker ON/OFf
FOT = Foot Switch Operation LowEdge HighEdge LowLevel
Hope this helps
2answers
Mitsubushi Big Screen TV Screen Protector vs 60601
that will have to be a dealer orderd item.. Unless you can find one used. I would try the tv shops in your area , they may have a used mitsubishi screen
2answers
Factory v chip codes
If you forget your passcode, you can view the locked TV without entering your passcode. This is done by pressing the number 9 and QV buttons on the remote TV control at the same time, when your
password is requested. This process temporarily unlocks the TV.
When entering the V-Chip Lock menu, this process deletes your old passcode and prompts you to enter a new passcode.
Mitsubishi WD-52725
SEDI-POSSIBLY YOUR SET HAS A LOW 5 VOLT POWER SUPPLY.TEST VIA VOLTMETER ON PLUG J-9 WHICH IS ON LITE ENGINE .YOU WILL NEED TO REMOVE BACK OF SET TO MAKE THE TEST.IF 5 VOLT IS LOW BEST TO CALL A MITSUBUSHI TECH.JOE TV
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
