Question about Blitzz Technology BWI715 Super G 802.11g/b (b000220dgm) Wireless Adapter
Super g wireless install
My old coputer had a super g wireless pci . I removed it and put in this new computer now that computer wants a driver disk or something to let it know what new hardware to install and I dont have a disk to use (gone/misplaced /not here) any sugestions help please.
I HAVE SAME PROBLEM LIKE TRUCKER 77546 .I NEED A DRIVE OR SOME THING TO INSTALL BWI 715 SUPER G802.11g/b ON MY NEW COMPUTER .BECAUSE I HAVE LOST MY SOFTWARE DISK FOR IT! THANK YOU.
Posted on Feb 13, 2008
How to enable wireless networks on hp pavilion a6330f or does it need a wireless card and which and what type of card or PCI or USB? What is a PCI? How to install a wireless card?
See the link below for product specifications.The simple way to go is an external usb adapter for wireless, since your motherboard only has one PCI slot and it likely has a 56K modem installed in it. Remember to put the driver disk which comes with your adapter in the CDROM/DVD drive BEFORE you plug in the usb adapter , and follow the installation directions carefully - unrecognized usb devices can be difficult to remove...
HP Pavilion a6330f Desktop PC Product Specifications
Mar 14, 2015 | HP Computers & Internet
How to wirelessly connect zoostorm G530
The USB one should work. The computer should detect it and automatically install the driver. If you have a disk with it try that. Once the computer has installed the adapter you need to wirelessly connect it. The old school way is to see your router in the listed stations, click on it and then supply the correct key. The new way of doing it is to use the magic button on the router itself which unlocks it for 2 minutes. Then when you click on the router listed it just lets you in.
Oct 22, 2017 | Computers & Internet
Install NX1101
I hope you know what you have bought and what you have (computer) are compatible. since you did not mention what computer you are trying to install this into, I will provide generic instructions.
1. remove all cables from rear of computer. remove cover from computer. Side panel or top cover, sometimes all covers have to be removed on some cases.
2. using a #1 philips screw driver or #5 torx driver remove the small screw from one of the case slots covers near an empty PCI connector on the motherboard. You find those near the place you plug in your video cable. Don't loose the screw.
3. align the new PCI card with the PCI slot and gently push straight down until the card is seated, you have to also align the metal alignment frame with the empty slot you removed from step 2. (if you removed the wrong blank, no problem, just remove the next one over and put that one where you removed the earlier one.) Now put in the screw that you saved from step 2. tighten.
4. Replace cover. Reconnect cables. Power back up.
Aug 03, 2012 | ASUS NX1101 PCI Gigabit Network Adapter
Can i take the old card out when installin the new d link
If you have bought a new pci Ethernet network card then yes you can, you need to completely turn off the computer and unplug from the power socket, taking the side panel off and locating your pci card, un-screw the clip that holding it in place making sure you dont touch any other part of the computer, and taking the old one out, remove the packaging from the new pci network card and pushing it into place making sure its completely down and before applying the screw to fix it in place, put the side panel back on, plug in the plugs and turning the computer back on making sure you re-place the Ethernet cable, after which on boot-up your computer will say new hardware found and install it if it doesn't do it by itself you will need to search or insert the driver cd that came with it to make sure it works perfectly. please let me know the outcome of this Kronoguy
Jul 06, 2011 | D-Link DFE-530TX+ Fast Ethernet PCI...
Keep getting a setup error on the install disc for th ENLWI-NX2 adapter.
If the PCI wireless adapter card is accessible by opening the computer case, then
First, turn off the computer, remove the wireless adapter from the PCI bus.
Second, use a non-abrasive, soft, pink pencil eraser to clean the electrical contacts on the wireless adapter card. There may be some slight corrosion on the contacts. Then remove the pencil eraser debris by wiping the contacts with a plain, non-treated, unscented facial tissue or soft lintless cloth. Do Not wipe it with your fingers because the oils in your skin can cause further rapid corrosion.
Third, carefully and fully replace the adapter card, being careful to properly seat it in the PCI bus.
Fourth, turn on your computer and check Control Panel. Add/Remove Programs for anything associated with your driver card, that may have been installed. You will want to uninstall these before trying to install the driver again. Also check Control Panel, Add/Remove Hardware or Control Panel, System, Device Manager for any entries associated with the adapter card. These will also need to be removed/uninstalled.
Fifth, restart your computer. When the "Found New Hardware" prompt appears, Cancel it without allowing it to try looking for and installing drivers for your adapter card. You will be installing the drivers from the CD in the next step. Allowing Windows to attempt installing drivers at this point may result in *.dll and other support files for the drivers being installed which are incompatible with the adapter card driver and support files on the CD.
Sixth, insert your CD and install the adapter card drivers from the CD.
Seventh, restart your computer if instructed to do so by the adapter card driver installation program.
Eighth, restart your computer, which will force a flush of all memory buffers, disk buffers, and complete the installation as the computer is shutting down. This will also allow the operating system to add the necessary entries to the operating system registry during the boot-up phase of the restart.
If your operating system is Windows 7, then you will need to download the appropriate driver from:
http://www.encore-usa.com/us/support/ENLWI-NX2
An updated driver for Windows 7 was posted on May 23, 2011. an updated Utility file is also available for download at the same web page.
If your operating system is Windows XP or Windows Vista the above driver for Windows 7 may still work. If it does not work, then perhaps the driver on the CD can be recovered by cleaning the disk.
To clean the disk, first try using water only. If that does not work or the disk has fingerprints or grease/oil on it, then use water and a single drop of clear dish detergent such as Dawn. When drying the disk, use a soft lintless cloth and be sure to wipe in radially from the center toward the edges. Do Not wipe in a circular direction around the disk, because this could create more scratches in a direction that would maximize potential data loss.
If the CD is scratched this could also account for an error when installing. CD polishers are available at most department stores ranging in price from $15 to $125. A CD polisher kit will usually remove scratches, allowing an uncorrupted read of whatever is on the disk.
If your operating system is something other than Windows XP, Windows Vista, or Windows 7, then there appears to be no driver available from the manufacturer, Encore. In that case, a wireless adapter that has a driver compatible with your operating system will need to be procured.
May 23, 2011 | Encore (ENLWI-NX2) Pre-802.11n Wireless...
Computer Will not start with my new pci device
Remove the card and install again making sure it goes all the way in..( and/or installing on another slot.. Make sure theres no hair or dust goes in the slot.. If problem persist, 1. You probably need to access bios n configure/enable the pci ports.. 2. The power supply is insufficient.
Nov 13, 2009 | Xterasys Wireless PCI Card Ethernet...
BWI 715 Super G wireless driver for Windows
I have the original CD Drivers, If you want I can share it with you.
Jimmy.
Jun 19, 2007 | Blitzz Technology BWI715 Super G 802.11g/b...
Super G 802.11g/b
ok look in device manager down the list to your wireless card and see if it is listed, if so check that there is not a red cross on it, if so right click and select enable. if a yellow exclamation mark driver not recognised with card. If it is listed and you are unable to enable it restart the pc and press F2 or DEL to enter your bios and on the peripherals menu, see if the wireless controller(if it is built in card) is enabled. If non of the above works, then the code 10 would normally be refering to a faulty peice of hardware.
Mar 18, 2007 | Blitzz Technology BWI715 Super G 802.11g/b...
Blitzz Technology BWI715 Super G 802.11g/b (b000220dgm) Wireless Adapter Logo
232 people viewed this question
Top Blitzz Technology Computers & Internet Experts
Michael Galve
Michael Galve
didi2005
JP Services
JP Services
Are you a Blitzz Technology Computer and Internet Expert? Answer questions, earn points and help others
