Anon, the bulb/lamp plugs into the ballast, The attached videos shows the ballast and location near the end of the video. Check the attached links. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info." HITACHI how to replace your enclosure guide
If the TV is a few years old the flashing green light means the bulb need to be replaced. That's why the TV will not show a picture. Check your owners manual on how to replace.
The WS-55809 is a rear projection TV and does not have a bulb, it has 3 picture tubes. DLP and LCD Projection sets have bulbs, or mercury vapor lamps. Does your picture flicker equally with different inputs?
Mitsubishi that the one,who u should contact.Talk to them make some kind of deal with them to help u to do a repairing or replace the tv Light Engine Projection Block.That the tv problems,this problems a design flaw on the tv Light Projection Egine Block the IC they put in that causes of this white spots are showing up will continue showing up more and more white dots.It will not stops.
Hi, Mitsubishi WD-73286 is DLP tv that does not have any convergence circuit inside. Convergence is required in old model rear projection tv that has three basic colors picture tubes to generate color picture that projected on front screen of tv. DLP tv has light engine to generate picture, it is similar to multimedia projector that throws its picture on wall. Hope this info will help. Thanks.
Sound /No picture- Have you replaced the Lamp?
If Not, First make sure fans are running when Tv is Turned on .Then if fans are OK ,Most common reason is the Lamp.
What is the Model # that is printed on back of TV?
The bulbs in the unit are actually going out. Some DLP tvs use specific bulbs that can only be picked up by the manufacture. Some mom and pop shops carry DLP bulbs. Your best bet is to call the manufacture or search for the model online using WWW.GOOGLE.COM to purchase these bulbs. These bulbs should always be installed by a certified repair specilaist. Hope this helps.
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Line faults & possible causes to LCD, DLP & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
whats the model number and are there any lights on the front that are lit?
