Question about Mitsubishi MS12TN Air Conditioner
Mitisubishi Ducted Reverse Cycle AirConditioner
Dear sir,
Recently, one of my electrical appliances caused a 'trip' to the electrical circuit. I reset the mains electrical board but the air conditioner doesn't work properly. It runs for about 10 mins, some vents do not have air coming out and after that, it stops automatically. The display screen message says 'P8'. How can I reset the airconditioner to rectify this problem?
Thanks
Smoke coming out of vents and air smells
Posted on Feb 09, 2009
  • 86 Answers
1.check blower fan motor.if blower fan motor donot work then compressure trip after 5 to 10 minitue.
2.make switch of airconditioner n reset again.
Posted on Mar 17, 2008
  • harjeet singh Mar 17, 2008
    fan motor not working.check wiring .
At end of washing machine fast spin the machine trips my electricity circuit and TV switches off along with other appliances. Can you tell me what's wrong with machine?
This tells me that you do not have an overload situation. There is a short, and/or one or more faulty breakers possibly including the main breaker.
Even an experienced DIY'er with electrical knowledge would probably contact an electrician at this point. If there is a potential problem with the main breaker then it is best to get professional help.
Why is my electric circuit breaker tripping
Common Causes for Tripped Circuit Breakers
Why Does My Circuit Breaker Keep Tripping
Jul 02, 2015 | Washing Machines
Fridge/freezer keeps tripping
Try to plug into different circuit, if it trips that breaker on the board then the appliance is probably at fault.
I must assume that you have not acquired something plugged into the same circuit as the fridge.
Sep 26, 2017 | Beko Refrigerators
Replace main control board
Is the wall receptacle defective? Have you plugged something else into the same wall receptacle without circuit breaker activating? Test with another appliance that also has the third round ground prong. If this is not the problem then yes an electrical short exists within the treadmill, inspect the cord itself for loose prongs, there may be liquid damage inside from a previous liquid spillage which would cause an electrical short.
Dec 22, 2013 | Nordic Track Exercise & Fitness
Tripping circuit breaker
please follow this steps and fix it. Otherwise call some electrician. God bless you
The circuit trips again. 2 issues could be causing this:
  • Overloaded circuit: Use fewer devices simultaneously or try moving certain devices or small appliances to a different area (use another outlet and circuit). Try resetting.
  • Electrical short: If your circuit is not overloaded, but the circuit keeps tripping, then this is likely the problem. The appliance or electronic device could be causing this short, or there could be faulty wiring in the walls. Consult a qualified electrician.
Oct 28, 2013 | Kitchen Appliances - Others
Circuit breaker trips after water supply cycle
check the condensor fan in the compressor area and make sure its running if not the compressor will overheat causing high head pressures on the compressor causing it to draw too much current to operate the compressor and kick the breaker out,also make sure the condenser coils there are clean and it has ample air movement away from the wall
Apr 21, 2013 | Kitchen Appliances - Others
Rv airconditioner trips breaker
Does it trip when fan only , or when compressor for cool cuts in? Sounds like capacitor perhaps . Get back to me with model number, and whether it's a ducted system, or blows out at ceiling assembly.
Apr 02, 2012 | Dometic Rooftop RV Air Conditioner
I have a Proform XT 90 treadmill that was recently purchased. After I brought it home, I plugged into my power strip and everything worked fine. Yesterday I plugged it in and nothing lights up on the...
cocopoi-
A couple likely issues would be:
1. Is the starter key installed correctly?
2. Has the onboard circuit breaker tripped? The breaker reset is next to the on/off switch, which is on the lower front of the unit. Press the button once firmly. If this was the problem, the treadmill should work again immediately. If the onboard circuit breaker trips repeatedly, there may be a short circuit in the machine, in which case you may be at risk of shock if the unit is not repaired properly.
3. Has the circuit breaker or fuse for the particular outlet you are using tripped? Try plugging another electrical appliance into the outlet. Does it get power? If the circuit breaker or fuse has tripped, that particular circuit may be overloaded or faulty. Only an electrician could tell you for sure.
Please followup if you need further assistance.
Regards,
DIYpro
Apr 29, 2011 | Proform Exercise & Fitness
My MSS15 aircondition stopped blowing cold air. Cleaned filters, turned machine off from main power, started it manually; still no cold air. Out side motor fan spins but sounds like compressor is not...
You will need to check the electrical side of the system....There are many thing that could be wrong. Contactor, start capacitors, thermostat, 24 volt side of circuit, compressor, Breaker tripped, bad breaker, Don't have 240 volts to unit, Manual reset HP switch tripped, bad fan motor.
As always, if you are in doubt about what to do, the best advice anyone should give you is to call a licensed electrician or HVAC tech to advise what work is needed.
Before you do any work yourself,
on electrical circuits, equipment or appliances,
always use a test meter to ensure the circuit is, in fact, de-energized.
Feb 12, 2011 | Heating & Cooling
The Reset button on cord keeps tripping, when turned on it works for a minute then trips again
There's obviously there is a short or electrical overheating problems omewhere in the appliance that's causing the circuit breaker (Reset Button) to trip. Stop using the AC unit and have it checked by a professional.
Feb 04, 2011 | Heating & Cooling
Mitsubishi MS12TN Air Conditioner Logo
548 people viewed this question
Top Mitsubishi Heating & Cooling Experts
vince
D. E. Hev
Stuart Slabber
Level 1 Expert
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
