Question about Dell Inspiron 710m Notebook
Screen went black
I closed my Dell Inspiron 710M notebook. When I opened it up again the screen was blank. The computer seems to be working, but not the screen. Any ideas?
    Novelist:
  • 77 Answers
When you close the lid, there is a small pin that engages the case and flips a switch to tell the laptop the case has been closed. The monitor will ALWAYS turn off then, because otherwise, the heat build up would burn the screen! Do not try to defeat this, replacing an LCD screen is usually more expensive than the value of the laptop!
Now, that all being said (and please remember), the situation you have now is (hopefully) just that the laptop tried/succeeded in going into ACPI "suspend" or "hibernate" mode.
1. Remove all cables and 10/100. Remove all USB devices. Just leave the PSU (AC power supply) connected.
2. Press the power button firmly, JUST once. Wait. And I mean WAIT, because some laptops can take 2 minutes or more to come out of suspend/hibernate, if they were very busy at the time it was shut down.
3. If the LCD screen lights up. you are done. But if it does not light up now, then proceed to step 4.
4. Press and HOLD the power button down for 10 seconds. This forces the laptop to shut down completely, even from suspend/hibernation. Some unsaved files may be lost, but tghe laptop goes cold, so you can start ACPI over again.
5. After a few minutes, press the power button again, firmly, just ONCE and for 1 second max. Laptop should start up OK.
6. Once it starts up, go to START MENU/SETTINGS/CONTROL PANEL/POWER SETTINGS and search for the "hibernation" tab. Turn hibernation OFF. your laptop obviously has some problems or lack of responsiveness with hibernation (most do). Use suspend, instead. It is much safer,. faster, and still does a good job of saving HDD and LCD wear. Please let me know how this goes for you, there are other more detailed problems that may be involved here, but I suspect this is most likely.
Posted on Feb 11, 2008
My 5 year old Dell Inspiron 710m screen is cracked. My son hit it with a remote and it has black fuzzy stuff throughout it that is spreading. What can I do?
So sorry about the cracked screen. But the solution to cracked screens is replacement.
But pending the time it can be replaced, if you have a desktop monitor, you can connect it to it.
If not, a flat screen TV could do the job of display, using the monitor display cable.
Hope that helped?
Success.
May 18, 2011 | Dell Inspiron 710m Notebook
I am trying to diagnose a problem with my son's laptop screen going blank. I shall try to describe the symptoms. 1. When plugged into an external monitor, everything works fine. 2.The laptop screen...
Have you check the cable that goes from the screen at the motherboard? Usually this cable is not visible; it is hidden it one of the joints between screen and main body of the notebook.This cable is the most common problem in the cases that the notebook keeps on working although the screen is black. You can check it by opening slowly - slowly the screen all the way up and closing again slowly. If there is a cut at the cable your screen will get black at a specific slope.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, accept my solution.
Thanks and regards
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Oct 31, 2010 | Dell Inspiron 6400 Notebook
Hi my screen is black when I turn on my laptop.
ysounds like you either have to replace the backliught tubes and/or the circuit board that runs the backlight tubes.backlight tubes are available on ebay from a gentleman in oklahoma city oklahoma
Jun 23, 2010 | Dell Inspiron 710m Notebook
Dell won't turn on, screen blank, battery light on when pluggedin
Take battery out and see it will turn on with just the power supply. If this does not work try with just the battery and no other power. If these do not work try to find a know good battery and power supply and these steps again. If all this fails it will most likely be the computer power supply which in some cases is quite a costly repair. It is possible that the motherboard or processor is defective causing this issue.
Mar 20, 2010 | Dell Inspiron 710m Notebook
Inspiron 710m won't boot...goes right to black asks for password
go to youtube.com and search how to get past windows password screen for dell inspiron 710m. you will follow instructions from there. ok this is so you will learn how to do it all the time when you have trouble. i learn from searching and reading.
Jun 04, 2009 | Dell Inspiron 710m Notebook
Screen going blank and laptop freezes.
Go into the diplay properties, under the screen saver tab there is a button marked power, open this. Under one of the tabs there is a section that reads, when I close the lid, under this section set it as never.
Jul 10, 2008 | Dell Inspiron 1000 Notebook
Dell b130 lcd screen blank
Right under your screen there is usually a removable panel. Underneath there should be a ribbon cable that connects to the motherboard, make sure this is seated properly.
Nov 28, 2007 | Dell Inspiron 710m Notebook
Dell inspiron laptop screen issue
First, are you sure you have the correct power supply?
Also, the lcd inverter could be going bad, consequently needing more power than it can get off the battery.
Hope this helps,
Good luck
Oct 19, 2007 | Dell Inspiron 710m Notebook
Dell Inspiron 710m Notebook Logo
259 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
