Question about Compaq Presario M2000 Notebook
Dropped laptop I have a son vaio vgn n350e that fropped about a foot, the screen has colored lines both up and down with a few green lines that run down like cracks, I tried hooking laptop to a vga but monitor does not turn on, tried pressing fn with f1-10 with no luck, i just want to verify lcd is bad before trying to replace, i also see the lines when laptop is off in the background? Any idea on how to verify the lcd with monitor?
  • lowe408 Feb 11, 2008
    sorry for the bad spelling
    Novelist:
  • 77 Answers
The symptoms you describe can be a damaged LCD, but they can also be caused by a loose LCD connector. If you are comfortable opening the laptop case, it would be wise to check this first. Sony uses standard Torx screws, if you buy the right size, taking it apart is not too difficult. Just do not FORCE anything. Be very patient, careful and gentle. Work in a space where you can capture any parts that drop and organize all the screws/parts in the same pattern they were removed. Then you find the ribbon connector (usually brownish-orange in color) and check the seating at both ends. If the laptop was OPEN, meaning the lid/LCD was open when the laptop was dropped, this ribbon might even be torn, and need replacing.
Posted on Feb 11, 2008
I dropped my laptop, Vaio VGN-NR185E, and the screen is turning blue with the white colors, so if there's a blank page it's blue instead of white, I believe it's the inverter or maybe a loose wire, What do...
If the unit was dropped, it could be that a wire /cable came loose,but it most likely is the LCD screen. Was the unit dropped on one edge of the unit or did it land flat?
on edge: probably the LCD screen
flat: loose cable or inverter
Best guess....without seeing unit.
Nov 15, 2010 | Sony VGN-NR185E/S VAIO NR Series
Fuzzy line going right down right side of Sony Laptop VGN-CS26g
The pixels inside of the LCD are going bad. Your screen is going to need to be replaced. When pixels in screens go bad it usually turns colors or gets fuzzy after it heats up.
May 14, 2010 | Sony VAIO VGN-CS260J/P Laptop
VGN-FS640W - Three green LED's come on but no boot up.
your hardrive is going bad cannot read the disk.take hardrive out and tap it slightly? then replace see if it makes a difference..
Jun 17, 2009 | Sony VAIO VGN-FS640W Notebook
How
go to control panel, performance and maintence, select hardware, and then select device manager, select your wireless card, then select details at top of box, that will give you the device id, cut copy and paste it in google for drivers. should find a site with that specific driver>
Jun 02, 2009 | Sony VAIO® VGN-N350E/W PC Notebook
Coloured vertical lines down lcd screen
To isolate the issue, i strongly recommend to connect the notebook to the external monitor by VGA port which had BLUE colored on the notebook. So that if it is normal then you need to confirm the issue is with the LCD display.
Apr 01, 2009 | Sony VAIO VGN-FS640W Notebook
Sony Vaio VGN-N350E question
Normally this should be specified on the service tag at the bottom of the laptop, if the service tag had been removed it may be difficult to identify the exact model.
Feb 22, 2009 | Sony VAIO® VGN-N350E/W PC Notebook
Strange Green Vertical Line
I encountered a problem with my sony vaio laptop after installing windows xp. It lost sound and keeps reporting that it does not have sound device when i try to play music.
Apr 21, 2008 | Sony VAIO VGN-BX563B PC Notebook
Compaq Presario M2000 Notebook Logo
66 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
