Question about Jl Audio E1200 Car Audio Amplifier
JL Audio e1200 Red protect light on
Any advise on what is wrong. All the fuses look fine. Thanks in Advance...
  • mercadoruben Jul 27, 2008
    jl audio red protect light on
  • 82 Answers
It sounds like you have a bad ground make sure its on the frame or body and any rust or paint is scraped off
Posted on Feb 11, 2008
E1200 jl amp was working fine. Speakers stopped playin an power an protect lights are on.
If the "protect" lights are illuminated, either you blew the finals on the amp, or the supply voltage reaching the amp is under 10VDC.
May 21, 2015 | Car Audio & Video
When i turn my volume up to a certain point the power light on my amp will blink off and on and the subs will cut off...what could be some possible solutions? is the amp not suppose to be tuned up? it...
Sounds like you are showing too low of an impedance load to the amp. The E1200 is only stable as low as 2 ohms. If your subs are wired to show lower than a 2 ohm load then the amp will go into protection mode as the volume or gains are turned up
Dec 23, 2010 | Jl Audio E1200 Car Audio Amplifier
I have a jl 500/1v2 and when i have the volume up for some time it teens to turn the amber color light on and turns off my amp and sub i turn down the volume for like 30 sec turn it back up and every thing...
its probably wires touchin or the ground not connected well with fat enough wire. i would try to rewire and do everything all over again because one wire or fuse is messing up i had t he same probelm. its the red light on the amp is ur amp shut off or ur warning light?
Jun 03, 2009 | Jl Audio E1200 Car Audio Amplifier
Wire three 10" jl subs to jl e1200
what is the impedance of your woofers it will be a number with an Omega symbol. Looks like a horseshoe next to your woofer . Like this JL Audio 10W1v3 8ohm. Please, Please tell me you bought 8 ohm woofers JR?? Because if not, it ain't gunna happen.. If you did buy 8 ohm woofers than wire them in parrellel which means all the +'s together and all the -'s together giving you a final impedance of 2 ohms and your amp will think your a car audio GOD... But if not be ready to smell plastic burning where your amp used to be.... let me know i can walk you thru the wiring but let me know what you have. ok. mark
Mar 18, 2009 | Jl Audio E1200 Car Audio Amplifier
My jl e1200 is very distorted
check your groud make sure theres contact and check your rca's
Mar 15, 2009 | Jl Audio E1200 Car Audio Amplifier
Which amp do you guys prefer will bumps better on the jl 12w3v2?
jl audio is a good name to stand by for amps kickers amps sound good at a high vol but not at a low vol
Nov 30, 2008 | Jl Audio E1200 Car Audio Amplifier
If my jl amp e1200 is on green, but no power is going to the sub
your audio wires from the head unit have been pinched or discontected or the head unit is not putting out a signal
Nov 29, 2008 | Jl Audio E1200 Car Audio Amplifier
Will a jl amp e1200 kick a jl woofer 12w3v2 loud
yes a 1200 watt amp will do the trick.. the problem would be in the box the 12w3v2 sub needs a good size box and you should have one made for your car. and yes you will get the bass you want
Nov 16, 2008 | Jl Audio E1200 Car Audio Amplifier
Amp wont turn on
It's possible the ground is not a good connection. Sometimes it may look good but dirt or corrosion builds up resistance creating a voltage drop where the wire is grounded to the frame.
Jan 26, 2008 | Jl Audio E1200 Car Audio Amplifier
Only works for RADIO!!!
You're using the wrong control lead. There should be an amp control lead. You're using the power antenna lead.
Oct 31, 2007 | Jl Audio E1200 Car Audio Amplifier
Jl Audio E1200 Car Audio Amplifier Logo
221 people viewed this question
Top Jl Audio Car Audio & Video Experts
Mark Skinner
hoyzee1
Morne Olivier
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
