Question about Motorola Mobility RAZR V3i Cellular Phone
Motorola RAZR V3 screen stuck
Screen stuck on hellomoto..and flashes off and on with that...cannot shut off without removing battery...what is up with this?
  • kathleen kelly Feb 11, 2008
    Dileep..thank you for your suggestions. I will give it a try. thanks keki
Eat poop
Posted on Apr 13, 2008
  • 983 Answers
Try putting other battery any of ur frnd s one...
put for charging for 4 to 5 hours continuously & try ....
if problem persists then may be the os software is corrupted...
visit technician he will do flashing and install the new software...
before going to technician just try some of these tips...
download P2K tools software which is compatible for all motorola phones... it is having in built drivers also so install the driver by giving the location where the p2k tools is located in that select folder "drv" ... this folder have all drivers when u connect ur cell to pc through cable just install this... then u go to p2kmode in that and go to flex option do flexing once....
dnt download the new version of p2k tools download old one (new one means may be p2k tools 3)
it is available in some of these websites
p2ktools-mod.en.softonic.com/java/download
www.e398mod.com/content/view/165/28/
gsmhosting.com/vbb/archive/index.php/t-41842.html
forums.mobiledia.com/topic48216-0-asc-10.html
Posted on Feb 11, 2008
My E815 Motorola phone is stuck on the HELLOMOTO bootup screen. I'd like to revive the phone one last time to extract some numbers, etc.
Have you tried to remove battery? Have you already got another phone? You can get the numbers from your old or same carrier.
Jan 06, 2011 | Motorola Mobility E815
When I Turn My Phone On It Just Stays On The Hellomoto Screen.
Try powering up the phone without the memory card!!!chances are that the phone files may be corrupted the solution to this problem is to flash the phone!!
Feb 27, 2010 | Motorola Mobility RAZR V3
I put a memory card of music on the phone and its just stuck on the screen that says hellomoto
remove the memory card, then remove the battery from the phone. Wait a minute install battery into phone and turn on. If all is good, power phone off before installing memory card. As a safety precaution, do not install or remove memory cards, in any device, with power on.
Sep 11, 2009 | Motorola Mobility SLVR L7 Cellular Phone
Frozen ''hellomoto'' screen on Razor V3c when turning on phone
You have a couple of options:
Take it to a motorola repairer or try to update the firmware on your phone. As you cant get it to go past the Hellomoto screen a hard reset would not possible.
Apr 05, 2009 | Motorola Mobility RAZR V3
Locked up at the "Hellomoto" screen
all - the firmware on the phone needs to be reflash to correct this issue take the phone to a mobile service center to have this done.....
GUEST -
take the phone to a mobile service center to be unlocked or try online at unlocknow or mobile2mobile.net
Dec 12, 2008 | Motorola Mobility RAZR V3
your firmware is corrupt, the only way to revive your phone is re flashing it.Its hard to do, and by doing it wrong may damage your phone. To safely retrieve your phone is let the experts do it or go to a near cell repair shop and let them help you out,
if you want to do it your self, try this
first you need is a RSD lite program or flash and back-up to flash or reformat your Motorola,
to enter the bootloader
hold * then the # then power button, your phone will boot to bootloader, and you will see there the flash program of your phone,
start the program rsd lite or flash and backup
then connect it to your computer VIA usb, automatically the program will detect your phone,
i prefer that you first buck up your firmware by using F&B (Flash and backup) then use RSD lite to flash your Motorola,
RSD lite its much easier to use than F&B, but for safety backup first your firmware,
gudluck
Nov 25, 2008 | Motorola Mobility RAZR V3c Cellular Phone
A motorola RAZR V3
this site is where you should update your falty software.http://www.motorola.com/consumer/v/index.jsp?vgnextoid=4507f7c0c1a0b010VgnVCM1000008206b00aRCRD&pg=PG_TYP_00001&manual=y&catID=6de76a7ce2ea0110VgnVCM1000008206b00a____&ps=y&show=globalSupport&msgNoCategory=Please+select+a+category&msgNoModel=Please+select+a+product&msgNoManual=Please+select+a+manual+type&selectProduct=bf9d5a7be49c9010VgnVCM1000008206b00aRCRD. and this one has trouble shooting guide if that does not work.http://www.motorola.com/Hellomoto/Master%20Lists/Product%20Manuals/Static%20Files/CA-EN/29742_V3UserGuide_ENS.pdf
Oct 25, 2008 | Motorola Mobility RAZR V3
Phone problem. Phone will turn on but...
Hangs on "Hellomoto"
Motorola Software Update (MSU) located on the Motorola website:
http://direct.motorola.com/hellomoto/Motosupport/source/SoftwareUpdateSelect.asp
This should upgrade your phone’s software and restore functionality of the phone.
May 22, 2008 | Motorola Mobility RAZR V3
RAZR CELL PHONE FROZEN SCREEN
There might be a firmware issue, you might have to re-flash the software in it.
Nov 21, 2007 | Motorola Mobility RAZR V3
Hi try pulling out the battery for a few min and later when you put back the battery , keep your phone for charging. Then try switching off and off when the charging is taking place. Hopefully it should solve the problem.
Oct 20, 2007 | Motorola Mobility MING A1200
Motorola Mobility RAZR V3i Cellular Phone Logo
108 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
