Question about ASUS AI Lifestyle P5N32-E SLI (P5N32-E-SLI-GREEN) Motherboard
Systme shuts down
After running any application my computer reboots itself.It occurs approx 5 min after turning on my computer.
  • 983 Answers
As i think this is purely the problem with the smps which is located at the top inside the cpu ...
due to some power s voltage variation the smps is out .. there is no other problem so just replace the smps your problem will be solved ....
Posted on Feb 11, 2008
How to reboot computer
hi
  • Decide what kind of reboot you are going to do. A soft reboot is performed the way you are “supposed” to do it. For a soft Windows reboot, go to the Start menu and select “Shut Down” or “Restart.” The computer will then shut itself down. Clicking “Restart” makes it boot up without further intervention from you.
  • Step 2 Perform a hard reboot by pushing the computer’s power button and holding it until the computer shuts down. Wait 45 seconds and restart the computer by pushing the power button again. You may have to start up in safe mode, but that also allows you the chance to restart properly or work on programs in a safer way. This method may cause you to lose data or mess up the operation of some of your programs. But it may be the only option if your computer's hard drive is frozen.
  • Step 3 Power down all of the computer's components. Shut off all of the peripherals you have attached to your computer, and disconnect the cables. Then, plug all of the peripherals back in, and restart your computer. This can often solve problems with your hard drive.
  • Step 4 Purchase and install a program such as Drive Reboot Restore PC 6.0 that streamlines the hard drive reboot process. These applications help prevent the problems that can develop after repeated computer use. They also ensure that your hard drive maintains the configuration you want each time you turn it on.
  • Step 5 Investigate what the problem may be with your hard drive. Because of its delicate nature, your hard drive can very easily be thrown off.
  • Jul 04, 2010 | Compaq Pavilion ZT3280US Notebook
    Outside cooling unit shuts down after approx. 5 min. Of operation ?
    Check condenser fan motor. If that goes faulty, shut down will occur.
    Jun 15, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
    My plasma turns itself off for about 10 20 mins
    It seems that your unit has some sort of Thermal PSU fault, or a problem that is shutting down the Power Supply Unit, PSU. This happens so that no further damage, and possible fire will occur. After it shuts down and the faulty component(s) cool down, it restarts again until it once again goes critical and shuts down again only to repeat the cyle.
    You need to take the unit to a reputable service centre/man and ask for a firm "Quote" for the work to be done.
    Jan 21, 2010 | Samsung HP-R5072 50 in. Plasma HDTV
    Reddy heater 165,000 runs for approx 15 to 20 min. I unplug wait 5 min. it restarts again and runs for another 15 to 20 min. and so on ....and so on purchased approx 1 year ago
    There is a sensor in the tube that is a safety feture. it is a snap disc it maybe faulty, it is reading that the tube is to hot and shutting down, it cools and works again, check snap disc and also they need pleanty of fresh air.
    Jan 13, 2010 | Reddy HEATER R115 115,000-BTU PORTABLE...
    Grundig S350DL shuts itself off
    The default mode for this radio is in "sleep-timer." You can adjust the time it stays on or you can hold the On/Off button down for a few seconds as you turn it on. (You'll notice the "bed" icon no longer appears.)
    Nov 30, 2008 | Audio Players & Recorders
    Window shut down automatically and restart, then shut down again... It happened after a window update yesterday lunch time.
    Recovery SettingsOne of the things that is quite different about Windows XP compared to Windows 9x (9x is shorthand for Windows 95, Windows 98, and Windows Me in all their various versions), is that one can control how it responds to certain critical errors—those that cause the infamous Blue Screen of Death (BSOD). In Windows XP, the default setting is for the computer to reboot automatically when a fatal error occurs. If that fatal error only occurs when you're shutting down, the system reboots automatically.
    If you haven't changed any of the system failure settings, you should be able to see the error by looking in the Event Log. But a better long-term solution is to turn off the automatic reboot so you can actually see the error when it happens—chances are it will tell you enough about itself to let you troubleshoot further. To change the recovery settings to disable automatic rebooting:
    1.
    Right-click My Computer, and then click Properties.
    2.
    Click the Advanced tab.
    3.
    Under Startup and Recovery, click Settings to open the Startup and Recovery dialog box.
    4.
    Clear the Automatically restart check box, and click OK the necessary number of times.
    5.
    Restart your computer for the settings to take effect.
    Now when you go to shut down and a fatal error occurs, you'll at least see it and it won't cause an automatic reboot. You still have to sort out what's causing the problem, but that gets us to the next section quite nicely.
    Nov 04, 2008 | Computers & Internet
    ASUS AI Lifestyle P5N32-E SLI (P5N32-E-SLI-GREEN) Motherboard Logo
    80 people viewed this question
    Top ASUS Computers & Internet Experts
    Alun Cox
    Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
