Question about AT&T Blackberry Curve 8300 Smartphone
Call log my fiancees work phone is the blackberry curve..every other day he will come home with a deleted call log..not sure why..he claims the phone deletes the call log itself..any ideas?
  • 3 more comments
  • lamaison Feb 11, 2008
    ok well heres the thing..do you think that this may have anything to do with it..his blackberry has a custom made computer program through his job, which requires him to take about a hundred pictures a day...do you think that the memory is what deletes the call log to store more space..he swares the phone does it automatically..what u think
  • mzugha2 Apr 03, 2008
    my call log just deletes on it's own, and I can't figure it out. I will make a call then look back in the call log and it's gone. It will work for a while but then it just goes away. Please help.
  • Kremer Apr 07, 2008
    My call log and text messages delete without any reason.
  • BerlinD Nov 30, 2008
    My Blackberry Curve won't receive all text messages. And deletes them along with my call log. Theres plenty of available memory..
  • littleone17 Dec 08, 2008
    my call log and texts delete automatically without my confirmation. sometimes the texts delete before I can even read them.
Silly. Plain silly. The question is how many other things does he have installed on the phone? Any themes, excess profiles, large numbers of pictures, several third party applications... This will all contribute to system resources being depleted. If he has a factory default set up with less than 100 photos and zero video or music -- he is probably selling you a dream. If however the opposite is true, the phone may be dumping his call log. Mine DOES infact to do that when my memory is getting low since loading a couple of videos and a Bob Marley theme. I hate it. I am trying to retreive a call that I lost because of that exact thing. Think of it as being a kin to a Blue Screen of Death on a PC.
Posted on Nov 10, 2008
  • drjmpc Nov 10, 2008
    Tip: BlackBerry Losing Text Messages or Call Logs?
    Are you having issues with your text messages vanishing without deleting them? Or maybe you notice your call log is suddenly empty? Both of these are symptoms of a full memory.
    What can you do to avoid this? Clear out as much as you can from your BlackBerry.
    Move pictures, ringtones, music, and videos to your microSD card if you have one. You can even set your camera to save pictures there by default.
    Delete programs you do not use. I often download a free trial
    or try out freeware that I discover I don't need or like. I often forget about these programs which are taking up my memory. Make sure to remove them either using Desktop Manager's Application Loader or under Options, Advanced Options, Applications.
    Keep your log clear. The BlackBerry keeps a log for trouble shooting. Just hold down the alt key and type lglg from the homescreen. Once the log comes up go into the menu and select clear. Make sure to close the log when you are done.
    See what programs are open. This is also a great help on the battery. From the home screen hold the alt key and press the back button. You will get a banner of programs that are running. There will be some BlackBerry applications that are always running, such as phone, messages, and BlackBerry Messenger.
    Clean out old e-mails, text messages, and call logs you don't need. I often accidentally save an e-mail or a text. I try to check my saved messages regularly and get rid of what I don't need, such as my flight info from a trip I took three months ago.
    Check your themes. Do you have lots of themes installed on your BlackBerry? They take up memory. You may want to delete them in Options, Advanced Options, Applications.
    Remove any media you are no longer using, such as old ringtones or mp3s that have worn out their welcome on your BlackBerry.
    From your Desktop Manager use Application Loader to see what languages are loaded on your BlackBerry. You can remove any you don't need. Also consider removing any other the option applications that come your BlackBerry that you may not use, such as Password Keeper or BrickBreaker. If you don't use it, free up the space.
    Try any or all of these as they fit for you. These steps helped me stop my vanishing text messages.
You guys are all stupid retards, Blackberries have a memory preservation system that deletes Logs and Text messages when memory is low, it just so happens you assume hes hiding stuff from you, dumb hoes.
Posted on Nov 01, 2008
I am a female and I can tell you that all three of my new blackberry phones delete the call logs and txt when my battery and or memory is dangerously low from time to time. Please do not go speculating that your future husband is doing anything behind your back based on uninformed strangers. Ask around, search around you will see that others have complained of similar problems on the net. Yes, be cautious but don't over do it, its the fastest way to make a mistake you might regret.
Posted on Jun 30, 2008
I am having this problem with my blackberry curve i can call my phone from another phone and it shows up on my call log then when i back out of that screen and go back to call log there is nothing there this is very inconvienient if i want to go back and see who i talked to and when i talked to them and since it is my phone i know that noone is lying about it cause it does it with the phone in my hand please help and maybe you need to give the guy a break it also does it to my messages
cricket
Posted on May 29, 2008
Trust me the call log deletes itself at&t will tell you to make sure your desktop software is updated but it still happens sporadically
Posted on Apr 15, 2008
That is BS.. my husband and I have the same phones well i noticed his call log was deleted and I asked him he said no the phone deleted them by itself, I thought it was weird, but 2 days later I was at work checked my call log and had just checked it 1 hour earlier and the history was there but when i check an hour later everything was deleted... nobody touched my phone.. INSTIGATORS..
Posted on Mar 06, 2008
Thanks!!! i did actually do something like that already...i kept his phone all weekend, and he never touched it..on friday i made all kinds of calls just t see if the calls would delete...needless to say they were there allllllllll weekend...the call log did not delete..he swares to me that he is not lieing.he told me to call at&t and verify the numbers that he did talk to on friday to see...i dont know....thanks!!!
Posted on Feb 11, 2008
  • 52 Answers
Well, Sorry to say this but i believe he makes some phone calls that he dont want u to see so what i m thinking is that he is lying to you cuz there is no way a phone deletes its call log it self, no phone in the world.
  • Victor Barajas
    Victor Barajas Feb 11, 2008
    listen girl, Pictures, Music, Applications, and games take up space in cellphones ( pdas, Blackberries, smart phones, etc). This space gets full and wont allow u to put no more music or take pictures or none of this, this shouldnt be a reason to alter the call log since the call log has a certain amount of calls that can be stored, Specially black berries can save hundres of recent calls so it is a good thing in case u need to get a number u dialed past days, even weeks, so i just think that he is hiding stuff from u, have him leave u the phone for a weekend to see what he says, dont warn him that u are gonnna keep if for a couple days, just keep it, if he says no they u know wuz up, he can tell his boss that he left it at a friends out of town and that shouldnt be a problem, so yea, :)
  • Victor Barajas
    well, i dont know, he tells u to call AT&T but even if u call they wont give u no information. he is a big lier, thats wuz up
The mute/lock button on my blackberry curve won't lock my phone
Not sure what might cause this problem, but try doing a soft reset, it has worked for me. Press and hold Alt+Right Shift+Delete.
May 07, 2009 | AT&T Blackberry Curve 8300 Smartphone
Call log deleted
It is because your phone is out of memory. You need to buy a memory card and move you pictures, ringtones, and music onto that and then it will stop doing that.
Apr 23, 2009 | AT&T BlackBerry Curve 8310 Cell Phone -...
My Blackberry delete my texts and call logs automatically. Please
the trouble is that you have used all of the memory on your phone to check it go to the little tool symbol that looks like a wrench and then go to status check to see how much free files you have if it says zero you will need to delete some unwanted files most of the time its if you have a lot of ringtone or music but you can also get a memory card after you selete some files turn the phone off and take the battery out and replace it repeat the steps to see how much free files you have then
Apr 05, 2009 | RIM BlackBerry Curve 8310 Smartphone
Blackberry curve 8130 phone category
This will typically happen when you need to clean your trackwheel.
I've done this, but it's a little scary - it looks pretty easy to break your trackwheel..
http://www.blackberryforums.com/general-8300-series-discussion-curve/108122-how-clean-your-8300-blackberry-trackball-pic-guide.html
Mar 14, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
Blackberry Curve 8330 - Stopped receiving e-mail from one account (but not the other)
The setting should be on your phone. Either delete the account on your phone and reset it up. Or check the email settings option.
Jan 19, 2009 | AT&T Blackberry Curve 8300 Smartphone
How do i fix this?
take the battery out for 5 min... thats how I fixed my problem... also, try updating the blackberry's firmware...
Jan 18, 2009 | AT&T BlackBerry Curve 8310 Cell Phone -...
Hello - my call log and texts aren't showing on my blackberry curve 8310 - not sure if i need to change a setting?
The problem is you don't have enough free space, so the phone deletes the call log and text messages to make more room. You basically have to delete any applications you don't use. Go to this website to fix it:
http://forums.crackberry.com/f3/how-increase-blackberry-s-file-free-memory-34633/
Here is an in-depth process of correcting this type of issue:
http://www.blackberryforums.com/general-blackberry-discussion/112029-losing-call-logs-sms-emails-optimize-your-bb-how-setup-max-free-memory.html
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Dec 23, 2008 | RIM BlackBerry Curve 8310 Smartphone
SMS messages and call logs being deleted
i had this problem with my phone, the blackberry is deleting all your messages and call logs because you dont have any phone memory, so your phone deletes everything it thinks isnt important.. so delete some of your pics, music or ringtones, and invest in a memory card! hope that helps!
Sep 20, 2008 | RIM BlackBerry Curve 8310 Smartphone
Call logs
Add a memory card to your phone.  The BB will delete call logs first when its memory is full.
Apr 03, 2008 | AT&T Blackberry Curve 8300 Smartphone
How to recieve MMS video on my Blackberry Curve
press Alt+LGLG. This opens your event log. Ignore the warning, press the blackberry key, and choose clear log. Restart your phone with alt+right shift+delete. Have the MMS resent, and you should get it.
Mar 07, 2008 | AT&T Blackberry Curve 8300 Smartphone
AT&T Blackberry Curve 8300 Smartphone Logo
375 people viewed this question
Top AT&T Computers & Internet Experts
Prashant M
Prashant M
Are you an AT&T Computer and Internet Expert? Answer questions, earn points and help others
