Question about Pitco Frialator 35C Deep Fryer
Adjusting main burner flame
How do i adjust the shape and size of my burner flame when there is no air collars to raise and lower? my 35c+ orifice spud only has a nat orifice tip..
  • 640 Answers
Goto the gas valve,you will see 2 slotted silver caps 1 small 1 big.unscrew the big cap then youll see a white plastic screw.turn this screw counterclockwise to increase the gas pressure,clockwise decreases pressure.nat. gas pressure should be 3.5 inches of water colum
Posted on Feb 12, 2008
How do I adjust the side burner flame on a Weber grill?
The burner has a fixed orifice, but there may be an adjustable air shutter (to adjust more or less air) at the end of the venturi tube that inserts over the orifice. If not, also try removing the gas valve knob and see if there is a small screw inside the shaft that you can adjust the flames. Most stoves have these. Also be sure the burner hasn't been spilled on. it may just need to be cleaned for a proper flame.
Feb 28, 2015 | Weber Genesis Silver B Grill
How do I adjust the flame in my gas oven
You have to be careful when adjusting the flame because you can cause carbon monoxide issues. There are two adjustments. the orifice hood and the air shutter. the orifice hood when turned will adjust the flame amount and the air shutter will adjust the burning of the gas. the hood will be on the line feeding the burner usually on them safety valve and should be a 1/2 inch nut. The air shutter is the door like opening on the burner tube itself. Your flame should be a nice blue cone without any yellow and should not blow and walk off the burner.
Oct 05, 2014 | Kitchen Ranges
Convert lp natural gas
To convert a lincoln LP gas oven to a natural gas, you actually first of all need to buy from the supplier an orifice ment for natural gas and change. The difference in the orifices could be in the size of orifice aperture.
The orifice i'm talking about is located in the burner assembly. you got to dis assemble the burner so as to get to it.
After that you need to adjust the main gas manifold when the oven is on. The adjustment must be done such that the pilot flame is not yellowish
Jan 28, 2014 | Lincoln Ovens
Soot coming
Hi there. Check the gas pressure, it should meet the the nameplate required pressure, low gas pressure produce poor flame quality which results in soot formation.. The type of gas must also be compatible with the orifice sizes on pilot and burners. Check and clean as needed all soot formation on burners and fire tubes.
Regards.
Sep 23, 2013 | Pitco Frialator 35C Deep Fryer
Heater is not igniting
see this causes and fix it. God bless you
f there is no heat, check the electrical service panel for a burned fuse or tripped breaker. Relight the pilot light (see below). If there is not enough heat, adjust the burner air shutter (see below); and clean the burner ports (see below).
If the pilot light does not light or does not stay lit, clean the pilot orifice carefully with a toothpick, test the thermocouple and replace it if it is faulty (see below).
If the flame flickers, adjust the pilot (see below).
If there is an exploding sound when the burner ignites, adjust the pilot to a higher setting and clean the pilot orifice and the burner ports.
If the burner takes more than a few seconds to ignite, clean the pilot orifice and adjust the pilot light.
If the burner flame is uneven, clean the burner ports. If the burner flame is very yellow, clean the burner; open vents in the furnace room to provide more air; adjust the burner air shutter.
If the furnace makes a rumbling noise when the burners are off, clean the burner and adjust the burner air shutter.
If the air is too dry, wash or replace the evaporator pad if you have a humidifier; test the humidistat; and adjust the water-level float to raise the water level.
If some rooms are too cool and others too warm, the distribution system may require balancing. Refer to the Forced-Air Distribution Fix-It Guide .
Oct 08, 2012 | Intertherm Heating Cooling System 15kw...
Regarding charmglow 720-0289. can't get a hot enough flame. cleaned all burners and made sure all orficis on the burner were clear even blew out with air hose
Are the burner flames diminishing as you turn on additional burners? In other words, is the flame size correct when one burner is lit, but too small when several burners are lit? Is the flame a nice blue color or yellow? If yellow, adjust each burner's air shutter at the end over each orifice. Have you tried adjusting the pressure on your propane regulator? (If it's red, don't mess with it) If it's a silver regulator and has a center cap, you can remove the cap to adjust the screw inside, by turning it clockwise in 1/4 intervals until the desired flame size has been reached. It's also possible that your burners have corroded closed somewhat. Do you have cast iron or stainless steel burners? Cast iron burners tend to corrode shut over the years due to moisture. Stainless steel burners just tend to rust away and flake, but usually become flare ups or out of control flames. Anyway, that gives you some things to look at. Hope it helps. Douglas
Jun 15, 2010 | Grilling
79012 / 79014 / 79019 Gas Kitchen Range: The propane converson seems to be done right, howe...
It sounds like during the conversion process a step or two may have been missed.
The gas orifice for the main oven burner is most likely to large (was not converted to LP), or the air shutter on the burner was not adjusted. I would not use the oven with the flames that way.
There should be instructions with the installation instructions on how to convert the oven, basically on most oven burners the orifice is screwed down (tightened) until the flame is the right size, then the air shutter on the burner is adjusted for a blue flame.
Let me know if you have questions
May 05, 2010 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Need to adjust the burners the flames to high
Hello there:
Please follow these very easy steps and this should help you
Instructions Things You'll Need:
  • Gas Ranges
  • Screwdriver Sets
  1. Step 1 Find the tube that feeds the burner. There's a burner air adjustment on it that mixes the air and gas.
  2. Step 2 Look to see what type of burner air adjustment you have: It will either be a barrel-shaped chamber or triangle-shaped with a cover plate.
  3. Step 3 Loosen the air-shutter screw on the barrel-shaped type. This screw is on the end of the barrel closest to the burner.
  4. Step 4 Open the shutter on the barrel-shaped type by turning it counterclockwise; close it by turning it clockwise. Opening it will add more air, which will make the flame higher; closing it will reduce the air in the mix and lower the flame.
  5. Step 5 Loosen the screw holding the plate on the triangle-shaped burner air adjustment. Don't remove the screw - it just needs to be loose enough to move the plate.
  6. Step 6 Move the plate so that the opening is either more open or more closed. More open will make the flame higher whereas more closed will lower the flame.
  7. Hope this is very helpful for you
  8. Best regards Michael
Feb 02, 2010 | Kitchen Ranges
Upper & Lower Broiler Flame Adjustment
MY KENMORE OVEN BURNER FLAME IS TO HIGH AND IT WILL NOT TURN LOW
Jul 16, 2008 | Ovens
Burner flame adjustment
there are two considerations for burner height. 1) the gas adjustment screw on the knob and 2) the gas-air mixture to the burner. establish a flame and adjust the screw for a standing flame at the burner. adjust the gas-air ratio orifice so that the flame has no yellow tips.
Aug 30, 2007 | GE Spectra JGBP30 Gas Kitchen Range
Kitchen Appliances - Others Logo
333 people viewed this question
Top Pitco Frialator Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Paul Carew
ray gallant
Are you a Pitco Frialator Kitchen Appliances - Other Expert? Answer questions, earn points and help others
