Question about Sony Cyber-Shot DSC-P73 Digital Camera
My camara will not power up
I got this camara last year and we had alot of fun with it and then the power just stop comming on we got new batteries then we just let it sit for about a month and put more batteries in and still nothing
  • MrsBeasley Feb 11, 2008
    This is a bad product from Sony and if I hadn't got it as a gift I would want my money back
  • 983 Answers
The firmware is corrupted i think just take it to the technician & get installed the new firmware... it will work ...
Posted on Feb 11, 2008
Camara will not power up even with new batteries? Just stopped working while wife was shooting at daughtes birthday pary.
If the product is within the year, warranty would apply especially when you consider cost for out of warranty repair. From your description the problem is more likely the systems control board, "the brains of the camera"
Mar 19, 2012 | Olympus SP600UZ Digital Camera
When we turn tv on,it will click right off,and shows a stand by timer light. what could be wrong with this? My tv is 10 years old
Hi. I see this type of problem alot, and this seems to always be the problem.
The vast majority of these are due to capacitors either built itno the power supply, or on the main circuit board.
These capacitors work like a booster battery, giving a sudden charge of electricity all at once, that way it energizes the t.v..
These capacitors seem tro be failing alot, probably due to the fact that alot are manufactured in countries where quality standards aren't what they would be if they had been made here in the U.S.
Good quality capacitors should last around 30 years or so, before failure, however, alot of the are only lasting around 1/3 of that time.
Some are only lasting a couple of years, some are lasting 8-10, but all of them are not lasting to their life expectancy.
I would look at your circuit boards, and look for swollen or exploded capacitors.
If they are exploded, they will look like an exploded battery, where it splits down the side.
This is most likely the condition here.
As for repairing, good quality capacitors are not cheap, and can be the difference between getting it repaired and just buying a new t.v.
I hope this is what you were wanting to know.
Jan 31, 2011 | Sony FD Trinitron WEGA KV-36FS120 36" TV
I have the same problem, the batteries do not last. Just bought new high quality batteries and put them in. The camara is already showing low battery and turn's itself off (just after putting them in,...
this occurs in any device that uses battery/s in some cases a small short forms that drains the batts there is only two fixs have the fault found by a service tech and repaired ( expensive and very hard to find) or store the batts out of the camera untill its being used now if the batts are not lasting in the camera then its the batterys simple. always remember with units such as camers always always use rechargable batts they give a heck of a lot more power drive than shelff pre charged batts
merry christmas
sonic boom electronics australia
please take the time to rank this advice below
thanks
Dec 24, 2010 | Fuji FinePix S3000 Digital Camera
Car lost all power when using emergency brake - stopped using it and everything was OK - a week later went to start car and when turning key was totally dead - friend went to give me boost and when he...
Welcome to FIxYa.com
Check for a drain remove the positive side battery connect a test light clamp end to the battery wire and the pointed end to battery post light will be on. Pull one fuse at a time. When test light :light goes out that is the circuit draining the battery
Regards, Lee Davidian
Thank you for using FixYa,com.
Oct 21, 2010 | 1999 Oldsmobile Alero
My video cam doesn't power up. I have charged the battery for 8+ hours and the camara doesn't power up. The camara is new.
Hi friend,
You should check your battery charge is ok or not. then switch on our video camara. id it is not work ..you need to contact hardware ..
Dec 20, 2009 | Vivitar ViviCam 8025 Digital Camera
My kodak md1063 digital camera switches on then straight of,have fitted new battery no difference.
My kodak Easyshare C653 camera is 2.5 years old when suddenly did this a few times then completely refused to turn on at all. Research showed me that this is a firmware issue in Kodak cameras. Kodak website said it will look at it and try to fix it for minimum $70 which is not worth it in my case as I paid $130 for the camera brand new 2.5 years ago. So either pay the $ for kodak to fix or buy a new camera is the solution. I am buying a new camera but it won't be a kodak this time as I want a camera that last years and won't go dead after warranty runs out.
Sep 01, 2009 | Digital Blue EasyShare MD1063 Digital...
My power drivers seat stopped working
i have this power seat track assy. to just change it is good 100.00 plus shipping wreckcars@aol.com randy
Dec 23, 2008 | 1999 Mercury Cougar
Bush DVD 2038 DVD player
Not alot a user can do with these units unless you have all the proper tools and jigs. Read this and see if it helps. http://www.techlore.com/article/14550/ Good Luck PS please dont forget to rate this thread.
Nov 25, 2006 | Bush DVD2038 DVD Player
CAMARA SOFTWARE PROBLEM
Does your battery work with regular AA alkaline batteries ? They have higher voltage than NiMH rechargeable. I'm having a similar problem, just discovered today that my camera works fine with AA alkaline batteries.
Sep 19, 2006 | Samsung Digimax A7 Digital Camera
Sony Cyber-Shot DSC-P73 Digital Camera Logo
112 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
