Question about Sharp AL 1631 Copier
How to locate and replace copier exhaust fan
I read on your site that a 3H error code on my Sharp AL-1631 copier means that it has an overheating problem. How can I go about checking and/or replacing an exhaust fan? Is that under the case on the left side of the unit, above the power switch? And where can I purchase the part?
Thank you!
  • 1 more comment
  • luvhaiti Feb 11, 2008
    Thank you for your help, Andy. I checked the picker fingers, and they seemed to be fine to me. What else could be causing the H3 error? The copier is only about 2 years old, and has 8491 total copies on it.
  • luvhaiti Feb 12, 2008
    Thanks again for your help. I did the reset as suggested, and now the machine attempts a start up, and I hear the fan, but then it immediately goes to an L4 error code. Another post an Fixya states that the L4 code is a drive motor problem. What do you think, or suggest?
    Thank you!
    Mark
  • Anonymous Dec 01, 2008
    sharp sf-2218 doesnt start coppying and a h3error code is blinking
  • 61 Answers
Hi, H3 is abnormal high tempeature in the fuser. Never had issues with the fan, probably you have a 'melt down', inspect the fuser through the sprung loaded flap and see if the three picker fingers that rest on the roller are melted. If they are then you require a fuser rebuild to include both fuser rollers, fingers, bearings and thermal fuse.
Cheers
Andy
Posted on Feb 11, 2008
  • 62 Answers
Thios models have trouble with upper fuser bearing being to tight this cause l4 codes take high oil put on the upper fuser bearing.
Posted on Mar 07, 2008
  • Kevin Shearer Mar 07, 2008
    This copier have problem with the upper fuser bushing being to tight take high temp. oil lube them. This will take care of l4 code.
Hi, i fix the 3h code with Andy's reset solution the only extra was to open the side feeder and close it again.
thank you
Frances
Posted on Feb 28, 2008
Mark, yes L4 is main motor, do the reset again. If L4 reappears i still think you have fuser issues. Being very careful not to electricute your self, remove the fuser by the two chrome screws, leave still connected, as you look at the machine from the end, lower left hand side should be a chrome plate, which when pressed in makes the door switch. Switch the machine on while holding the fuser, make the door switch. Machine should turn over, also you should see the heater lamp come on.
Andy
Posted on Feb 12, 2008
Hi, try a main board reset by pressing these buttons= cancel, exposure, cancel, exposure. Display has to go dead, enter 14 then print. Should reset however if there is an on going fault then H3 will return. If it does then your thermal fuse, located in the fuser unit, will need replacing.
Cheers
Andy :)
AL-1631 is flashing "H". How do I fix this which appears to be heat related.
the h means that your fuser needs to be replaced. it might be fixable by changing the thermal fuse but most of the time the whole fuser needs to be replaced
Sep 28, 2014 | Sharp AL 100DR Laser Toner Drum Works for...
I HAVE A SHARP AL 1631, IT SHOW ME A 4 CODE, HOW CAN I TO SOLVE THIS
their is no A4 code,if you mean H4 try to reset it by simulation 14
Dec 26, 2010 | Sharp AL 1631 Copier
Sharp al 1631 copier has a H 4 code on I reset it and it seams to work but for how long will it last
A H-4 error code means that there is aproblem with the fuser unit. It could be that the thermister is dirty and not reading the correct temp. of the upper fuser roller. How long will it last for? Your guess is as good as mine... There are to many things that may cause it to fail... Good Luck
Jul 23, 2010 | Sharp AL 1631 Copier
Sharp al 1631 error code l-1
The problem it in exposere lamp section.The forward scan is not compelet.Cause is the mirror motor control board or mechanical parts.
Oct 03, 2009 | Sharp AL 1631 Copier
Sharp AL 1631 is flashing 1 L. What does that
Hi:
This might refer to your scanner assy being locked. The scanner assy is the unit under the glass that scans your document prior to copying it. Look inside the cavity where you pick up your completed copies. Look at the upper left corner and see if there is a knob there. If there is, make sure it is in the completely unlocked position.
Andrew
Aug 09, 2009 | Sharp AL 1631 Copier
What is the code to reset the Sharp AL 1631 copier
Sharp - How to reset code
To enter service mode press thesekeys: orange C button,Interrupt, 0, Interrupt. The screen goes black when you have done itcorrectly. It may take a few tries – must be done in certain time.
To clear the maintenance indication (service man): press 20, start,1, start (the display will start to flash when entered correctly).Power off/on to make the copier dude go away. Good Luck!
Jan 31, 2009 | Sharp AL 1631 Copier
H3 ERROR CODE SHARP AL 1631
H3:
00:TEMPERATURE OF FUSER UNIT HIGH,THERMISTOR CONTROL BOARD FAILING
Did you replace the thermistor? check the thermofuse also for continuity
Oct 20, 2008 | Sharp AL 1631 Copier
Sharp AL-1631 has 3H error code
3H error means overheating...what you can do is supply new fans or clean the unit for dust and others. check for the exhaust fans if its still working. this will reslove your problem.
hope this helps
Jan 27, 2008 | Sharp AL 1631 Copier
Sharp AL 1631 Copier Logo
270 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
