Question about Philips 32DV60S 32 in. TV/DVD Combo
My tv is zapping itself from the inside.
I can hear my 57in projection hdtv cracking and turning off. it sounds like it is charging up and then jumping across somthing. please can you help me.
josh trudell. gosh76@gmail.com
I used a dryer (antiststic) sheet and rubbed the projecter heads also blew out all the dust then vacumed out the bottom of the tv. and it seams to be working just fine.
Posted on Feb 11, 2008
Loud cracking and zapping coming from tv,sounded like speakers,when it was first turned on.Was happening intermittently but now nothing.Checked power and fuse inside and nothing seems burnt or cracked
Something has blown.. possibly a resistor, diode or ??? on one or more of the boards. You should take the TV to a service Agent who should be able to resolve the problem.
Apr 02, 2016 | LG 37LC7D 37 in. LCD HDTV
My Misubishi WD-52631 DLP TV is off sudenly. I turn it on again, but no picture, no sound, nothing happened. I reset it, nothing happends. the green power light blinks for a while, then shut off itself....
Tv LED "LAMP" light indication is blinking?And ur tv projection lamp inside ur tv been used like 1 1/2 or 2 years.Yes.The tv projection lamp require changing,tv projection lamp life are ended.
Apr 19, 2011 | Mitsubishi WD-52631 52" Projection HDTV
I have no pic sony lcd proj tv model # kdf-55wf655, 57in,
Lamp or ballast bad. If ballast good and lamp bad, will here a mosquito buzz every 15 secs. after turn on.
Apr 20, 2010 | Sony Grand WEGA KDF-55WF655 36" Rear...
Tv takes to long to turn on and screen resizes
sounds like a power supply issue. partstore.com might have a power supply for this tv
Mar 18, 2010 | Sony KDS-R50XBR1 50" HDTV
52" RCA big screen tv turns on and few seconds turns off by itsel
if you heard a hissing or like static sound your board probably has a hole in it now. the board on the left side with the flyback fransformer. the hole is from where a prong has come loose an is arking over an it burns the board the ark is the sound you heard.
Apr 23, 2009 | RCA R52WM24 52" HDTV Projection Television
Color problems with Hitachi 57in rear projection
One or more of the projectors lights( my guess is the green one) are either blown or in the process of going bad. Have them repaired or replqaced by an authorized tech.
Dec 28, 2008 | Hitachi 57F500 57" Rear Projection...
Red screen and only red bulb powers on.
The red tube and the red crt board sound like the problem. these would be the first thing that needs to replace 250 for tube +50 for crt board. + labor about 300 to 500 to repair
Jan 17, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Nothing but Red Screen
check to see if you noticed some liquid on some of the wires on the red crt could the crt coolent be leaking onto the board under the crt and the blue crt is missing alot of coolent!!!
Get a weird zapping noise
sounds like theres a short, most likely the flyback transformer
take in for service
Dec 05, 2007 | Zenith D52WLCD 52" Rear Projection...
Flashing color in and out with popping sound
This sounds like the solder joints have cracked on the AFT can inside the tuner, a common Sony problem. Removing the tuner, opening it up and resoldering the grounds and small transformers inside should clear it up.
Jun 26, 2007 | Sony KP-43HT20 43" Rear Projection...
Philips 32DV60S 32 in. TV/DVD Combo Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
