Question about Panasonic PT-65WX51 65" Rear Projection Television
Picture color The picture on my TV only has red, blue, brown and black/gray. No red or green. Tried adjusting color with the user menu on the TV with no success. Had the convergence modules replaced a year ago and has worked fine since.
I discovered that the red input from my DISH receiver had come loose. I plugged it in and all is well.
Certainly glad I didn't call a technician out!
Posted on Feb 11, 2008
Samsung LCD TV diagnosis. Possible tcon board?
T-con board is causing all your problems. You are correct. You can get parts from here: TV Parts Universal TV Stands DLP Chips ShopJimmy
Sep 21, 2015 | Samsung Televison & Video
Danco instructions
Umm, yeah I think so....
Nov 10, 2013 | Danco Home
My hitachi 53udx10b was supposedly just serviced but the picture is extremely blue. Have tried adjusting picture to no avail. Help.
I am going to tell you a simple thing to do to know what your problem may be.
With the set on turn the color all the way to zero. Go to a channel if you can that is in black and white. What color is the screen?
If the answer is that it is blue in the background whoever serviced the set did not and could have removed front speaker grill and inspection plate behind it; there is a black plastic block with three screen controls (red,green,blue) and 3 focus controls (do not touch the focus ones.)
I suspect if the blue screen is there a slight adjustment of the blue screen down will correct this.
The picture with the color at zero should be black and white or gray. If blue is background color it will also be with color.
This is called gray scale; picture with color off has to be gray or black and white.
Before you rate this solution if you have questions make a comment right here and I will advise you.
SD TECH
Jun 29, 2011 | Hitachi 53UDX10B 53" Rear Projection...
Need lg 32lh30 calibration specs
I think I have a solution involving far less effort. Have you tuned your picture settings? Out of the box, the settings are ok and the presets will do the trick for most. But if you're like myself, you want the best picture possible. Here are my settings:
Picture menu:
Aspect ratio: Just Size
Energy Saving: Off
Picture Mode: Expert 2
Backlight: 35
Contrast: 90
Brightness: 54
H Sharpness: 40
V Sharpness: 42
Color: 50
Tint: 0
--Expert control menu
Dynamic contrast: Off
Noise reduction: Off
Gamma: Medium
Black level: Low
Real Cinema: On [grayed out]
Color Standard: HD [grayed out]
Color Gamut: Standard
Edge Enhancer: Off
xvYCC: Auto [grayed out]
OPC: Off
Expert Pattern: Off[grayed out]
Color Filter: Off
White balance: Warm
Method: 10 point IRE
Pattern: Outer
IRE: [see below]
Luminance: 137
-- 10 point IRE calibration
IRE: [Red, Green, Blue results, respectively, for each IRE point]
100 [-8, 1, -40]
90 [-13, -5, -40]
80 [-20, -12, -40]
70 [-17, -14, -33]
60 [-17, -12, -31]
50 [-17, -13, -26]
40 [-13, -12, -19]
30 [-6, -4, -8]
20 [-6, -4, -10]
10 [2, 3, -1]
Color management system
Red color: 2
Red tint: 0
Green color: -1
Green tint: -7
Blue color: 2
Blue tint: 7
Yellow color: 0
Yellow tint: 1
Cyan color: 0
Cyan tint: 0
Magenta color: 0
Magenta tint: -2
These are taken from CNET.com
Nov 08, 2009 | LG 32LH30 32 in. LCD HDTV
TV picture is red.
Normal color picture is composed with 3 colors R-G-B (Red-Green-Blue). Picture turns Red means: Missing Green and Blue colors (many reasons: bad contacts, projector tubes dead, and other...). Try to give some "tabs" to diagnose ... I don't know what is the type of your Projection TV, how long you owned it, to have more idea.
May 15, 2009 | Toshiba 57H81 57" Rear Projection...
Color adjust
Greetings!
Adjusting the picture tubes is a scary proposition, but since you have already done it...
The easiest way to balance the gray scale is to turn the color all the way down on the set. The next part is easier with two people if the screen controls are on the back of the set. This is the part you saw that has six small knobs on it. There are control for the focus of the red, gree and blue and for the screen level of the red, green and blue. You will want to adjust the screen controls in an effort to get the picture black and white (this is why you turn the color down), hence the term "gray scale". Just make slight adjustments, take your and be patient. It will take some time, but you will get your picture balanced back out in time.
Hope this helps!
Rob
Jan 15, 2009 | Philips 50P8341 50" Rear Projection...
Picture is Gray, does not show any color
Are you using component cables (red/green/blue)? Check your connections to see that they are all seated properly. When using component cables, if only the green is plugged in, it will give you a black and white picture. You will get color once you plug in the red and blue.
What kind of sources are you using? what kind of cables are you using? Need these kinds of specifics to ehlp you out.
Mar 28, 2008 | Televison & Video
Rear Projection Tv Problem! black and white... Please help
go into menu turn color off see if you have a black and white picture if not adjust red,green, and blue screen drive on controls in back of tv you have red, green, blue it will have focus /screen controls cover each tube do one at a time blue focus and screen drive adjust to clear blue picture do all 3 tubes, then adjust them to where you have a black&white picture once this is done turn color controll back on.Thank You for using FixYa and Have a Nice Day.
Nov 11, 2007 | Toshiba 50H72 50" Rear Projection...
Picture has a green shade
Sounds like your red picture tube is not emitting enough brightness to balance the colors. A temporary solution could be to slightly increase the screen voltage of the red CRT to give a good black and white picture when the color control is turned all the way down. If the set has not been serviced in the last 5 years or so, and you're not ready for a new HDTV set, it may be worthwhile to get a technican to look at it and clean the dust off the lenses and mirror and evaluate whether a picture tube rejuvination might work along with the gray scale tracking adjustments.
Mar 10, 2007 | Toshiba 51H84 51" Rear Projection...
Panasonic PT-65WX51 65" Rear Projection Television Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
