Question about GE (PSS26MSRSS) Side by Side Refrigerator
Water Leaking from the bottom of the Refrigerator
GE Side by Side Refrigerator is leaking water from the bottom of the unit. It is leaking on the Water and Ice Dispenser side. It is a slow leak but constant. What could it be? I have checked the water supple line going in the back of the unit and it seems to be fine.
  • 5 more comments
  • Anonymous Feb 12, 2008
    same problem and checked back not leaking, also checked chute no ice there.Help?
  • Billy 1 Feb 16, 2008
    No, The floor seems to be fine and no ice seen. The leak is right under the door (ice maker side) in the front of the unit where the little floor grill is. Thanks for trying
  • Anonymous Feb 20, 2008
    water puddles beneath refrigerator side
  • ljij Feb 28, 2008
    I have the same problem with my Arctica refrig. There is a sheet of ice on the bottom of the freezer. How do I locate the defrost drain hole? Thanks in advance!
  • 2hokies Apr 06, 2008
    We have water leaking every so often on both the freezer side and the refrigerator side, right at the front corners. It's not constant, it just seems to happen randomly one side and then the other. We also have the sheet of ice on the bottom of the freezer. What's going on?
  • rickarthur54 Sep 16, 2008
    We have a similar problem with our GE Profile. Water is leaking from the corner of the freezer side. It is not constant. I usually notice a puddle in the morning. At first I thought we may have dropped some ice underneath the freezer door/ It does not appear every morning however it is happening more frequently..
    Is there a tray underneath the refriderator that may need to be empty? Our refriderator is an older model but had no problems with it up until just recently with the puddle of water in the morning?
  • Anonymous Mar 17, 2014
    Water leaking from bottom of refrigerator
    Sniper:
  • 65 Answers
Is the floor of the freezer a sheet of ice? if so the defrost drain hole is clogged.
Posted on Feb 16, 2008
  • chris aube Feb 16, 2008
    ok, is there any gap in the gasket on the freezer side when closed? you may need to use a mirror to check the bottom edge. we will get this .
Mine was doing the same thing. Turns out the water supply line was broken just above the bottom hinge for the door. I had to remove the shelves on the freezer door by removing the screws around the door behind the seal and then spliced the line up by the dispenser and behind the grille at the bottom. I used 1/4" supply line that was left over from hooking up the supply line and two 1/4" to 5/16" adapters from lowes. A fisch tape makes it easier to run the new piece through the door but the fix was pretty simple overall.
Posted on Feb 27, 2008
I really appreciate your help. I'll check the gasket. Thanks!!
Leaking water from the front right side.
check drain tube and drain pan on bottom of unit most likely plugged drain or water line going up door is leaking
Dec 21, 2010 | GE Profile Arctica 25.4 Cubic Feet...
Water leak under GE Profile refridgerator when using door water
The water dispenser problem may be due to a defective water control valve. But when the refrigerator leaks this needs to be solved. I have a lot of different ways and reasons listed so click on the below link and read over this and use the part that applies to your refrigerators leaking problem. You also can contact me here or by email should I not get any messages here from you. Hope this helps and we will work on the dispenser problem next, Thanks, Sea Breeze
appliancepartsse@yahoo.com
HOW TO FIX A LEAKING REFRIGERATOR OR FREEZER
Aug 17, 2009 | GE Profile PCF25PGW Side by Side...
10 yr old GE side by side: freezer is leaking
Your drain is frozen up and so every time unit goes into defrost the water refreezes in the freezer's bottom. You either have to shut fridge off completely and let it dethaw or use hot water and an ice pick to hurry up the process. The drain is located in the very back of freezer. You will have to pull out the bottom drawer to see it. Good luck
Jun 10, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water leaking from overflow tube
pour warm water and baking soda down drain and look for cracks in tube.
May 12, 2009 | GE Refrigerators
Water leaking from outside bottom
the waterline going in the freezer door may have a hole take the kickplate off while looking underneath use the water in door to see if any water is leaking from that tube
Apr 27, 2009 | GE Profile TPX24PBDCC Side by Side...
GE Monogram leaking water on right side bottom door
If this refrigerator has a Energy Saver mode, turn it on.
Then, check the door gasket for the refrigerator to make sure it's not leaking. Test by placing a crisp dollar bill on the door jamb with the door open, close the door, and you should feel resistance to pulling the dollar out. Check with particular emphasis on the place where you see water leaking or accumulating
Jan 24, 2009 | GE Monogram ZDI15C Automatic Icemaker
Ice maker is leaking into the tray where the ice is dispensed causing the ice to become embedded into the tray
there is a screw in the ice maker unit that can adjust the water level open the ice maker whit cover and you should see it but turn it gently little by little each time...and see how much you getting :) very EZ good luck
Jun 06, 2008 | GE PDS22SIS Bottom Freezer Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator Logo
1,170 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Ilia Bichin
