Question about Olympus EVOLT E-500 Digital Camera
Card full, but it is not!
I can no longer take any pictures because my card says it is full, when i always delete all my pics after i download them to my computer.    When it says it is full, i go back into it and it says "no pictures" but when i try to take another picture it says, "card full."  What is going on? How do i get my camera to take pictures besides just throwing this thing away and getting another brand? Thank you kindly, Christine
  • 52 Answers
Well, U want to format ur card, u can do this
From ur computer:
Insert Ur card Into ur card Reader
go to my computer
right click on the CARD and FORMAT
From ur Camera:
Go to menu on ur camera
Find the FORMAT option and click YES
and hopefully thits works for U. :)
Posted on Feb 11, 2008
I put my memory card into laptop, message says my card is full, and yet i delete my pics from camera., do i have to delete from memory card also, if so how do i do that.
Did you delete the pictures from the internal camera memory and not the SD card? An easy way to solve this problem would be to insert the card into your computer and open up "My Computer". In here you should see your memory card mounted as a usable drive. Open up the SD card, select everything in it by pressing "Control" + "A" and then hitting delete. This will clean everything off of the card. If you want to save the files from the card first, simply make a folder somewhere on your PC and drag all of the files from the SD card into that folder after pressing "Control" + "A". If you are still getting an error stating your card is full after removing them this way you may need to re-format the card or it may be malfunctioning.
Jun 27, 2011 | Computers & Internet
After deleting the pictures from the memory card and putting it back into the camera, the pictures are loaded back on the card, what could be the problem? When I put a new card it acts like it is froze up.
Sounds like you failed to delete internal memory from setup menu before inserting card, and ALWAYS use camera to delete pics...from internal memory and from card...do not delete pics using a PC, or format card on PC.
Oct 18, 2010 | Moultrie GameSpy 4.0 Digital Camera Deluxe
How do i get the pictures from my camera to the memory card
the question I ask is why would you want to do this?
The camera has XX Mb of memory in case the card becomes full. Generally one downloads the pics on to a PC and deletes the Camera files to start again
If you want to keep the pic files in memory and save them tpo your pc. remove the card for safety.. Interrogate your camera via the connection cord and the software it came with. Download the folder with the pics in memory to your PC. Then delete the files on the camera. Insert the SD card and In menu, set up to save files to SD card rather than memory while there is space.
Please rate my help++++Thanks fore using FIXYA
Apr 16, 2010 | Samsung L200 Digital Camera
Internal memory is full,I have erased all
Take out memory card from camera, format internal memory to delete all pictures at once or delete them one by one.
Once memory card is inserted in camera, internal memory is no longer available to store/ delete pictures so remove memory card from camera to get access to internal memory.
Nov 06, 2009 | Kodak EasyShare C743 Digital Camera
Not able to 'delete' a picture from my Lumix TZ3
Sounds like a MobileMate quirk Tanya. Use your USB cable connection to your PC/Camera interface and delete pics that way too see if this funny goes away.
If it does, and I believe it will, then it is a SanDisk issue not revising the File Allocation Table(FAT) after deleting the Pic File on the mem card.
You could also find out if this is just an SDHC SD card reader issue by using an older less dense standard 1 or 2Meg non-SDHC mem card in the reader and see if issue goes away.
The fallback of course to view and delete the pics on the camera before download, or download pics then note which pic file numbers you want deleted after viewing on PC, then put SD card back in camera and delete them there.
Another option for trial, is to cut and paste the whole DCIM folder, or sub pic folder to your PC from off the SD card using the card reader. The camera automatically generates subfolders under the DCIM folder if you completely remove(deleting by a cut or move), when you take your first picture on a camera with a DCIM but not sub pic folder. Try this first and I think you will find all pics will be deleted from camera that are in a subfolder under DCIM. If not, then cut or move the whole DCIM folder and create a new DCIM(empty) folder on the SD card using the PC and card reader. Of course using this method you cannot selective delete individual pics from the mem card. You would be deleting them all after the Folder cut or move from the SD card.
Dec 02, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
XD card picture error
Try to use a card reader instead. They are only a few dollars. I use one all the time, and hardly ever will use the camera on different models I have.
Never delete from the PC to the camera. It can cause corruption. Once corrupted, you may lose all pictures on the card.
Always delete from the camera, unless you will format the card anyway.
Use the camera and try to delete the bad picture from the camera. this may fix the problem, if not, try to read from another camera or a card reader...don't ever delete from another camera or the card reader.
The last is not good, and that means to format the card, and you will lose all which is on the card.
You may try to copy to internal memory.
One more thing... take out the card. reset all in the camera menu. Then reset all the things you like. Put the card in and try to read each picture in play mode only. If one picture is very slow, delete it. This may take some time as corrupted files may read slowly. then try again.
Sep 01, 2008 | AOpen Olympus 64Mb xD-Picture Card (AX4C...
I took about 200 pictures and they were suddenly deleted off my camera. i thought they were accidentally deleted. i took about 40 more pics and it said my memory card was full so i know they're still there...
get a memory card reader and try to download pics from card to comp-then open and click any folders you see related to memory card-card will show up as a new drive letter in my computer-pics may be in different folder and still be there-if you can't find pics at all go to sandisk.com and get recovery software to see if you can still retrive them
Aug 17, 2008 | Cameras
Memory Card Deleting Photos After A Certain Amount Of Time??
I've have xD cards that I thought I deleted the photos, but they showed up on the Xd card when i put it in the card reader to download another set of pics. I think it happened because I used the card in 2 different cameras (thus, the cam each saved pics in their own different formats).
Jun 22, 2008 | Olympus Stylus 730 Digital Camera
Hi I have a Finepix A920 digital camera which despite downloading the pictures from the camera keeps saying internal memory card full. Any Ideas ?
Downloading pix does not remove pix from card, YOu must manually delete pics on card or use Picasa to download and choose "delete card contents after download" option or similiar option of your software.
Jun 13, 2008 | Cameras
Olympus EVOLT E-500 Digital Camera Logo
64 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Are you an Olympus Camera Expert? Answer questions, earn points and help others
