Wireless cardbus pc card tew -601 pc
Hi..
i have acer laptop -acer 3610..its not wi-fi inbuilt ..so i bought a pcmcia card called wireless cardbus pc card tew-601 pc
mimo 108g , ieee 802.11g
108 mbps mimo wireless lan from trend net
kindly assist me how do i install it ..is software required for this?s
how can i acces wi-fi if i am in awifi zone..kindly assist me
Hi..thanks for ur suggestion..my problem has been solved by opening my computer - properties - hardware and clicking on device manager and thr other device showing yellow question mark and i thought wirelss device doesnt work properly and i cliked on update device..a nd now my pcmcia card works fine
Thanking you
Neethan
Posted on Feb 12, 2008
How to change wi fi card
Usually the cards for wifi in laptops are called mini pci cards- there will be a slot on the bottom of the laptop that you can open to remove the card. Other options for changing out include using a pc card (also known as PCMCIA/ Cardbus/ etc) or an USB wireless adapter. I personally suggest the USB, since it would not void warranty, and overall would be a cheaper solution
Sep 24, 2012 | Fujitsu Siemens AMILO Pro V2000 Notebook
Does this devise pick up internet on laptop or desk top either one
Hi cfisherman8
This is a PCMCIA Wireless Adapter Card.
It slots into the large PCMCIA Port that almost all larger laptops and notebooks have.
This device can also work in a Desktop computer but requires a PCMCIA Cardbus Adapter to be installed in the Desktop Computer for it to slot into. There are different types of Desktop PCMCIA Cardbus Adapter. Some types internally connect a PCMCIA Wireless Adapter Cardbus to an empty Motherboard PCI Slot and others externally connect a PCMCIA Cardbus to the computer via its USB or Serial Ports. See here for examples:
http://www.amazon.com/StarTech-com-Port-CardBus-PCMCIA-Adapter/dp/B000BMMN7K/ref=sr_1_21?s=electronics&ie=UTF8&qid=1316320335&sr=1-21
http://www.amazon.com/Startech-Cardbus-Adapter-Transfer-115-2kbps/dp/B004WGR6YG/ref=sr_1_12?ie=UTF8&qid=1316320098&sr=8-12
http://www.amazon.com/Quatech-PCD-X-U142--CardBus-adapter/dp/B001BEF3YC/ref=sr_1_28?s=electronics&ie=UTF8&qid=1316321566&sr=1-28
Other alternative internal wireless networking devices for Desktop computers include a PCI Wireless Network Card. See example here:
http://www.amazon.com/Sabrent-Wireless-802-11n-Network-Adapter/dp/B002DYIZ2Q/ref=sr_1_14?s=electronics&ie=UTF8&qid=1316320278&sr=1-14
Once installed, it is able to send and receive data wirelessly between the computer and any Wireless Router/Modem to which the computer is configured to connect.
This device is most easily used with a Laptop. An easier solution for a Desktop PC would be a USB Wireless Adapter.
I hope this helps.
If this Answer goes some way towards helping to resolve your Query, Problem or Fault, please take the time to Rate it. Doing so helps Solution Providers, like me, better understand the needs and the point of view of Askers, like you, and guides us in exploring the best ways to provide the most comprehensive, useful and high quality Responses and Solutions we can. If you need further help, please do not hesitate to post another Question or add a Comment to this Question.
Thanks for using FixYa
Sep 18, 2011 | D-Link Air DWL 650 802.11b Wireless...
CAN I USE INTERNET THRU WIFI WITH COMPAQ ARMADA E500 ?
it seems like your laptop not have inbuilt wi-fi connection, so you can not use the wi-fi but if you buy a USB wireless adapter or wi-fi pcmcia card so you can use the wi-fi in your laptop.
Thank you for using Fixya
Regards
Manish
Jun 13, 2010 | Compaq Armada E500 Notebook
I have a compaq presario F756nr with an Atheros wireless wi-fi card in it. Can I replace the wi-fi card with a Broadcom 802.11 b/g wireless LAN card?
no you cannot replace the built-in wi-fi card...
if you try to change the drivers for atheros wi-fi to Broadcam driver, your wi-fi card will not function anymore.... but you can always install another WI-FI card in your laptop... you can buy a USB Adapter or a Cardbus(PCMCIA) adapter for this purpose...if you want your wi-fi signal strenth and range to be higher, you can opt to buy an adapter which comes under N standard....N standard wi-fi adapters are capable of connecting at a speed of more than 300mbps(practically) to any N standard device like router....
Mar 29, 2010 | HP Compaq Presario F756NR Notebook
I have a samsung X10 running windows 2000. how do I set it up to run wi-fi?
This is a pre-xp operating system and I assume a pre wi-fi laptop.
your easiest option would be to buy a wireless usb adapter if you have usb ports on your laptop. Otherwise you will need a wireless PCMCIA card.
Jan 15, 2010 | Samsung X10 XTC 1300 Notebook
Can my 1625CDT be made WI-FI adaptable
Any laptop computer that doesn't have a built-in wireless card can be wireless enabled by installing a PCMCIA wireless card or an USB wireless adapter. Go and see your friendly computer shop.
Aug 06, 2009 | Toshiba Computers & Internet
Gateway PC crashing when connecting to Wi-FI
if i was you i would load up a version of win xp on another hard drive inserted into your laptop, load the drivers for the laptop including wi fi drivers then see if ok. if not you can be sure its a faulty wi fi card in your laptop,you need to disable internal wi fi card remove,replace it.but first try borrow a pcmcia wi fi card just to check if everythings ok
Dec 06, 2008 | Gateway MX6438 Notebook
Wireless card
Let me guess...it comes up as an unknown pcmcia controller.
I have 4 pcmcia cardbus cards and the only one that my armada M700 recognizes is a twinmos B. All others come up as unknown pcmcia controller.
Apr 13, 2008 | Compaq Armada M700 Notebook
Wireless connection
before you insert the card to the slot run the cd thats comes with it and install the software. after installation of the software insert the card. if it is properly installed, you will see a single computer icon on your task bar click it up and search for a network.
Feb 11, 2008 | Computers & Internet
Computers & Internet Logo
124 people viewed this question
David Payne
David Payne
