Question about Hifonics Brutus BXi 1206D Car Audio Amplifier
Hifonics bxi 1206d
I'm running dual voice coil subs, when i power up the fuse is getting hot.do and how do you bridge the amp.When the subs start to play the fuse gets to hot and blows.
  • 82 Answers
Make sure you have a 40 amp fuse in it
im going to try to describe this to you
to bridge a amp this is for 2 ch AMP
I 2 2 I
I 2 2 I
I I 22
I I 22
I I 22
I I 22
#1 SPEAKER #2 SPEAKER
WIRE WIRE
ONE GOES ON THE POSIVE OF ONE SIDE AND THEN THE NEGATIVE OF THE OTHER
HOPE THIS MAKES SINCE
PLEASE LEAVE MY RATING
Posted on Feb 11, 2008
  • 4 Answers
Im with sic audio
Posted on Aug 14, 2008
    Scholar:
  • 96 Answers
The prior solution would be helpful but you have a monoblock amp not a 2 channel stereo amp and 40 amps is no where near big enough of a fuse, the amplifier uses a single 80 amp maxi type fuse and you dont / cant bridge a mono amp they r internally "bridged" so to speak.
2 dual 4 ohm subs wired together in parralel will make a 1 ohm load at the amp which would give 600 watts per sub, true rated rms all the time so you better have really good subs like a pair of brutuses or better.
to wire it that way do this:
each speaker has 2 coils.
put a jumper wire from 1 coils positive to the other coils positive then do the same on the negatve side of each coil.
then run the + and - of 1 coil to the sub do this for each speaker.
this will make the amplifier see a 1 ohm load for "bridged" operation i run 2 1606d's in 1 car and 4 2000d's in the other all wired this way
Posted on Jul 26, 2008
How to connect HIFONICS BXI 2607 D watt at 1 ohm....
That's dependent on your subwoofers. You will need 2 dual 4 ohm subs wired in Parallel, a single dual 2 ohm subwoofer wired in parallel, a single dual .5 ohm wired in series. Or something similar.
http://www.bcae1.com/spkrmlti.htm
Nov 20, 2009 | Hifonics BXi 2006D Mono Block Amplifier...
Wiring diagram
run them in sereis hooking them all up together and bridging the amp
Jul 22, 2009 | Rockford Fosgate Power 1500BD Car Audio...
I have a HiFonics 1206D amp and it keeps blowing the main fuse
The 60A fuse is WAY too small!!
The amplifier's Fuse is 80A
You will want the MINIMUM battery fuse @ 80A as well.
Since the current draw at the battery is greater because of the resistance of the wire - an 80A - 100A fuse is recommended.
The purpose of this fuse is to protect your BATTERY if something happens along the length of power wire.
What kind of "shop" are you using?? I would find another one!
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Jun 28, 2009 | Hifonics Brutus BXi 1206D Car Audio...
Protect Light Coming On - BXi 1206D
If you actuate the subwoofer by hand, do you hear any scraping sounds?
It's possible the voice-coil is rubbing and tripping the amplifiers protection.
Try the amp on a different sub.
Jun 23, 2009 | Hifonics Brutus BXi 1206D Car Audio...
Power good no green light no subs
Make sure you got a good ground. do not ground on painted surfaces! If you got power from battery, check the remote wire running to cd player. Hook up remote blue wire with the one for cd player. If you still have a problem and the fuse is good, then the amp is fried
Jan 30, 2009 | Hifonics Brutus BXi 1206D Car Audio...
Hifonics BXI 1606D problems
it may be a wiring problem you need to make sure all the speaker positives and negatives are correct. I sell alot of hifonics amps and have never had 1 do that. it may also be a bad rca cable. if it only does it when you use the filter i would say not to use it also make sure the gain is no more than 3/4 turned up and the bass boost no more than 1/2. if you have a dif amp try a temp setup using it and if it still does it its a wiring issue. also try 1 speaker at a time on the hifonics and keep adding 1 till it comes back it may be a bad voice coil on 1 sub .
Jan 08, 2009 | Hifonics BXI 1606D Car Audio Amplifier
Hifonics amp keeps blowing the main fuse
have u tried using thicker wire from the battery to the amp u need to put a fuse in there thats a minumum 60
Jul 15, 2008 | Hifonics Brutus BXi 1206D Car Audio...
Bridging 800a4
That all depends upon whether or not the sub you are running has dual voice coils or just a single voice coil. The 800a4 is a four channel amp; thus the only way you can bridge it will be 3 channel or 2 channel. If you are running a dual voice coil sub then you can wire the amp two channel and get 400 watts x 2 @ 4 ohms. Make sure that you sub can handle this kind of power though.
Here are the specs:
4 x 100 @ 4 ohms (13.8V - <0.05% THD)
4 x 200 @ 2 ohms (13.8V - <0.10% THD)
2 x 400 @ 4 ohms bridged (13.8V - <0.10% THD)
Fuse: External 60A
Manufactured in 1999 - 2001
Jun 18, 2008 | Rockford Fosgate Punch 800a4 Car Audio...
High Pitch Whine from Amp (not speaker)
make sure your rca andpower/remote wires are ran on seperate side of your car.it maybe recieving some kind of interference from the alternator. try buying higher shielded wiring too
Apr 20, 2008 | Hifonics Brutus BXi 1206D Car Audio...
No sound in my Hifonics Brutus BXi 1206D amp
Have you confirmed that you have a good signal feeding the amp?
Have you confirmed that the speakers are in good working order and don't have any breaks in the wiring?
Jan 01, 2008 | Hifonics Brutus BXi 1206D Car Audio...
Hifonics Brutus BXi 1206D Car Audio Amplifier Logo
319 people viewed this question
Top Hifonics Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
Jaime Hernandez
Marvin
Marvin
Are you a Hifonics Car Audio and Video Expert? Answer questions, earn points and help others
