Wireing instruction I would like to hook up my Kenwood Receiver to an Optimus Equalizer and i cant figure out how to do it
  • Anonymous Dec 05, 2008
    wow yeah um i have this pro logic deck and can't figure ouit the tape monitor...cause it just act s like another source!!! GGGrowl
    ss
  • 1,512 Answers
Use the tape loop on the receiver, and connect the REC out to the input of the EQ. The output of the EQ goes to play in on the amp. If you have a tape loop on the EQ, then this is where you connect a tape deck. Engage the tape monitor and be sure that you have selected the source you want to EQ on the rec out selector(if you have one).
This is the only way to connect an EQ if the amp is without pre-in pre-out connections. If they are, then use them in the same manor as the tape loop. Good luck, get back to me here is you have any problems. A "FixYa" rating will help my profile and would be great for my time giving you this info. Cheers
Posted on Feb 11, 2008
How to hook up a pioneer 7 band gr 470 equalizer to a Kenwood kr-v6030 receiver
Connect one pair of RCA cables between the receiver and equalizer. Connect one pair of cables to the pre-amp output channels on the receiver and the other end of the cable to the left and right channel inputs on the equalizer. You will usually find these channels on the rear of the equalizer.
May 09, 2016 | Pioneer Audio Players & Recorders
How to hook up a 7 band pioneer equalizer great 470 to a Kenwood kr-v6030 receiver
Connecting an Equalizer to a Receiver Before beginning, purchase RCA cables. In order to run the signal from a stereo receiver to the graphic equalizer and then on to the amplifier, two sets of RCA cables are needed. These are basic cables used to connect auxiliary components like record players and CD players. The length of the RCA cables should be about the same length as the distance between the receiver and equalizer.
1. Connect Graphic the Equalizer to the Receiver
The first step in this setup is to connect the graphic equalizer (EQ) to the receiver. Most receivers will have preamp-in and preamp-out connections. Some have tape monitor connections. It's preferable to connect the EQ to the preamp-in or preamp-out because the tape monitor won't allow for connection to the amplifier as well.
2. Connect the RCA Cables
The first set of RCA cables should connect the receiver and equalizer. Connect one pair to the preamp output channels and the other end to the left and right input channels on the EQ. These are on the back side of the equalizer. Usually, the colors will correspond to the RCA plugs. That means connect the red plug to the red jack and the white plug to the white jack. Then connect the second pair of RCA cables between the receiver and the amp. Match the colors in the same way.
3. Connect the Amp to the Receiver
Now the amp can be connected to the receiver via RCA cables in the amp inputs on the receiver. This will create a loop from the receiver through the EQ and amp and back to the receiver so that all three units are connected.
4. Test Graphic Equalizer
Turn on the receiver, amp and equalizer. Once they are powered up, try controlling the sound with the equalizer knobs. They should fine tune the music according to your preferences. It's easy to change the frequency response or tone of the music with the equalizer knobs.
How do I hook up my Kenwood ge-74 graphic equalizer to my technics sa-gx530 receiver?
Because they are two different brands the only connection you can have is RCA cables which you can buy at any stereo shop, including car audio. You will not have any special functions from the two being connected. You will have control over sound quality.
Feb 16, 2016 | Kenwood Audio Players & Recorders
On a kenwood KR597 reciever, where do i hook up my KE597 graphics equalizer. Also must i remove my DP-R797 cd player to hook up my Maeantz PMD520 Cassette deck? Finally divorced
If you only have one set of tape in/out connectors, then hooking up two tape decks and an equalizer is going to be difficult. You could hook the "tape out" to one tape deck, that tape's output to the second tape, and the second tape's out to the equalizer, connecting the output of the eq back to your receiver....
Nov 01, 2014 | Audio Players & Recorders
Hook up kenwood ge-1100
2 stereo rca cables tape out to line in on eq, line out from eq to tape in on receiver. press tape monitor button to use eq, turn off tape monitor for direct. some receivers also have a dedicated I/o for eq, you just need to remove the jumpers and install in that loop (out to in on eq out from eq to in on rcvr}
Mar 16, 2014 | Kenwood Ge 1100 Graphic Equalizer
Hook up a 901 equalizer to a kenwood amp
instructions on pages 9 to 11
Bose 901 Equalizer
( click on the link above)
Sep 22, 2012 | Audio Players & Recorders
Hi, I just purchased a used set of 901s with the original active equalizer. they are both series VI and were bought together. Unfortunately, the man misplaced the installation instructions for the...
If no Amp is used, connect jacks ( Left, Right) from your receiver output to Bose equalizer Input ( L, R) where it says Amplifier. Then also under where it says Amplifier, connect jacks from Output to your speakers. This would require the type of speaker wires that are RCA (plug in, red and white) on one end bare wire on the other to the speakers.
I don't know what the output is on your Kenwood, but if it's low watts, an amp is much better to crank those Bose. It's a different connect with an amp. Go L &R from the receiver to Equalizer as before, then from equalizer to amp Input where it says Tuner. then hook bare speaker wires to back of amp to Bose speakers.
You should have full use of Bose controls. The Monitor button is for an extra component that can be hooked up on the back, right side of equalizer.
Jul 15, 2009 | Bose 901 VI Main / Stereo Speaker
Optimus 7 band equalizer model # 12-1969
I need to know what the wire are coming out the back of the optimus seven band stereo frequency equalizer/booster
Jul 07, 2008 | Car Audio & Video
276 people viewed this question
 Grubhead
Grubhead
