Question about KitchenAid KT2651X Epicurean Stand Mixer
6QT KITCHENAID MIXER DOESN'T POWER ON
I have a KitchenAid KT2651X. I was kneading bread dough and it started smoking and shut off. I unplugged it and turned it to the off/reset possition. A couple weeks later plugged it in and tried to turn it on but nothing happened.
  • 1 more comment
  • Karen S Feb 12, 2008
    If it was the motor wouldn't it make SOME noise when I turn it on?
    The motor shaft moves freely by hand.
  • Karen S Feb 29, 2008
    I ended up taking it to a local shop and he said it was a fuse and the speed control. We'll see if that does it. Ihaven't got it back yet.
    Guru:
  • 1,894 Answers
Put some lubrication to it...
Posted on Feb 17, 2008
  • 1 more comment
  • dewan nafees ahmed Feb 18, 2008
    i think ur motor is not receiving proper power.. recheck it using some tech..
    this will surely fix u..
    thank you
    good luck
    dont forget to rate the solutions
  • dewan nafees ahmed Feb 19, 2008
    since you have also said that there is some smoke then it must be some surely due to some high voltage that have caused that fault.
    even i had my power board burnt up in one of my equipments once. and that was due to high voltage.
    also repairing this depends upon how much damage has happened to the PCB.
    if it has burnt to the worst case then you will have to replace the whole power board.
    if only that component has damaged and BOARD is safe means then the cost incurred will be very less. only that component which has damaged.
    now for finding what component has got damaged you will have to equip yourself with a multimeter. using that find which component is not receiving the voltage properly.
    now take a solder rod and a lead and flux. now remove that component from back side.
    now put in the new component and solder it again.
    WARNING: but do all this only if u pretty handy in electronics. else you will do it in ur own risk.
    also dont forget to rate the solutions.
    thank you
    good luck
  • dewan nafees ahmed Feb 26, 2008
    what happened???
    Genius:
  • 1,665 Answers
You must call a tech assistance to inspect electric circuit and motor windings, shaft bearings, bushes etc.
If you have not some technical experience it's not recommended to do it by yourself. (Your appliance must be disassembled to figure out what caused smoke.)
Important Safeguards:
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000010547.pdf
When using electrical appliances, basic safety precautions should always be followed including the following:
1. Read all instructions
2. To protect against risk of electrical shock, do not put mixer in water or
other liquid.
3. Close supervision is necessary when this or any appliance is used near
children.
4. Unplug mixer from outlet when not in use, before putting on or taking off
parts and before cleaning.
5. Avoid contacting moving parts. Keep hands, hair, clothing, as well as
spatulas and other utensils away from beater during operation to reduce
the risk of injury to persons and/or damage to the mixer.
6. Do not operate mixer with a damaged cord or plug or after the mixer
malfunctions, or is dropped or damaged in any manner. Return appliance
to the nearest authorized service center for examination, repair or electrical
or mechanical adjustment. Call the KitchenAid Customer Satisfaction Center
at 1-800-541-6390 for more information.
7. The use of attachments not recommended or sold by KitchenAid may
cause fire, electrical shock or injury.
8. Do not use the mixer outdoors.
9. Do not let the cord hang over edge of table or counter.
10. Remove flat beater, wire whip or dough hook from mixer before washing.
11. This product is designed for household use only.
Posted on Feb 12, 2008
  • Kleanthis Mavropoulos
    Kleanthis Mavropoulos Feb 12, 2008
    http://tristate.apogee.net/mnd/mfphowm.a...
    The stator in an AC motor is a wire coil, called a stator winding. It's built into the motor. When this coil is energized by AC power, a rotating magnetic field is produced.
    If the wire coil of the motor is short circuited or burned at some point perhaps make some noise trying to rotate.
    Also unplug AC power and make sure that motor shaft and reduction gears can rotate freelly by hand.
    So as motor can rotate freely the electric circuit must be checked. Use a multimeter to measure the resistance at its cord terrminals with power switch position "On". If reading measurement is infinite implies an open circuit problem (Check any Fuse, power cord, switch, wires etc for continuity.)
    If reading is too low (i.e below 50 Ohm) may motor winding is burned.
    Rewinding a motor usually is not the cheaper solution.It depends on how much you accept to pay for your machine to have repaired and in working condition.
  • 552 Answers
Most likely because you smelled smoke, the motor burned out.
Depending on how old it is, the brushes in the motor may be short.
If you were lucky, if the brushes are replaced, it may work.
The best thing to do is, take it apart.
If the motor itself smells burned you can bet it is.
Just make sure it is unplugged and then remove screws holding it together. Probably are screw on the bottom of it.
If is probably better to replace the motor if you want to keep the machine. That is if it's cheaper than replacing.
Let me know and I will try finding a cheap enough motor replacement.
  • Hjalmer Lamminen
    Hjalmer Lamminen Feb 13, 2008
    Motors when stuck normally make a humming noise.
    If yours is completely burned out or the brushes are worn out, then you may not hear any noise, because there is no current flowing in the motor.
    Something else could have burned out. If you look inside, then you can see first hand what it is and then I can find a part for you or direct you to the place to get one.
    I have worked for 30+ on electric motors and all types of motor controls in and outside of industry.
  • 796 Answers
Hello sir
  • isaac johny
    isaac johny Feb 12, 2008
    due to the smoke as you have indicated it must have damaged the power circuit....or short circuitary in the power cord....
    if any part of the power circuit is burnt its cheap to get it replaced or if any other in main circuit is affected then it may cost you....
    if you are handy with your electrical skills then you can try replacing the burnt part....
Mixer arms shake when kneading bread
You have not supplied a model number and the bowl lift models are not all the same. A couple of items you could check, make sure that the bowl retaining clip that engages with the dimple on the pedestal side of the bowl is not broken. Make sure any bolts/screws holding the pedestal to the base or the pedestal to the motor are tight. Even if you supply a model number I can't think of anything else to look at unless the handle is not lifting the bowl up tight enough. I think on some models the arm holds the carrier up with some pressure which would help stop the wobbles.
Jul 13, 2017 | KitchenAid Kitchen Aid KP26M1X 6 Quart...
KitchenAid stand mixer KSM50PWH. Was kneading dough with dough hook attachment and it quit turning. Motor works fine but the part that's supposed to go round and round doesn't. Can I fix this?
The Nylon Worm Gear has stripped. This is designed into the part so if the Mixer gets overloaded, it won't burn out the motor. Which is odd if you have the reset switch like I do.
Part# 4162897
You can buy it online at Kitchenaid.com
Jan 17, 2011 | KitchenAid Food Mixers
I have a kitchenaid 600 professional stand mixer. I was told that you can only use the dough hook with setting 2 for only 5 minutes. What do you do for recipes requiring a longer time for kneading? Is...
You can knead longer than that, but you run the risk of over heating the mixer because at that point the dough is very firm. Your best bet is to knead it by hand.
May 14, 2010 | KitchenAid KP2671 Professional 6 Series...
My mixer just started smoking while i was mix some
Your mixer may still be good, let it cool down and then check it out, If it runs OK then there is no problem. The motor in your mixer probably over heated from trying to mix bread dough which will make any mixer work hard. These mixers will get warm when over worked but unless heavy smoke was coming out and you were getting a burning enamel smell it is probably OK. Let it cool and try it but I suggest you not use it for bread any more.
Oct 08, 2009 | KitchenAid KT2651X Epicurean Stand Mixer
Is 300 w mixer powerful enough to mix bread dough?
Your mixer is easily able to handle the kneading of bread dough. Please advise:
9 cups of all purpose white flour, maximum.
6 cups of specialty flour, maximum. This is any flour besides all purpose white.
Bread doughs are only to be needed on speed 2, and never for longer than 7 minutes.
This is all stated in the Use and Care guide for the mixer itself. If these guidelines are not followed, it may lead to a product failure.
Jul 02, 2009 | KitchenAid KSM90 Ultra Power Series Stand...
Used the bread kneading hook, after 10 minutes, smoking
The mixer motor has probably overheated, as proper use and care was not being followed with the stand mixer.
Bread doughs are recommended to be mixed on speed 2 only and never for longer than 7 minutes. With the resistance of a bread dough that is provided against the beater, mixing for over 7 minutes may overheat mixer and cause smoking.
Please consult your use and care guide to refresh your memory about how to properly use your mixer for making bread doughs.
Jun 07, 2009 | KitchenAid K45SS Classic Stand Mixer
LOOKING FOR RECIPE FOR MAKING BREAD DOUGH IN MY KITCHENAID KSM90 MIXER. I HAVE NEVER MADE BREAD IN MY MIXER, I DO NOT HAVE A MANUAL.
Hi Manfredi. Follow this link to download your mixer's manual.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Instructions%20and%20Recipes%20-%209704323.pdf
If this solution has assisted you, please rate it. Good luck, and don't overload the mixer when you're making bread dough. ricardok45
Mar 20, 2009 | KitchenAid KSM90 Ultra Power Series Stand...
Pops out of lock under a heavy load
Hi Susan. There is no worse feeling than the feeling you get when you find that you've been seperated from your hard-earned money by a company that markets a product with glowing phrases of what their product can do...And then doesn't deliver on it's promises. Kitchenaid mixers can make short work of bread dough NOT! My Kitchenaid HD Pro (475 watts) self destructed after only 30 uses of making my Sourdough Bread. The problem? A cheap piece of plastic that takes the stresses of two important shafts in the mixer. Cheap, shoddy parts in a mixer you paid top dollar for. Kitchenaid shows no shame in doing so.
What is happening with your mixer as it tries to mix your dough is that the head unit is thrust back and forth and side to side (bucking). Eventually hinges become loose and sloppy. Kitchenaid's behaviour is legal and beyond reproach, so make your next mixer purchase an informed one.
Goto www.consumeraffairs.com and do a search for your Kitchenaid model. You'll notice that you're not alone in your mixer troubles.
I solved my mixer problems by buying a used Hobart 20qt. Commercial mixer (A200) and rebuilt it. When mixing heavy dough you should only use about 60% of the bowl capacity. less, if your mixer is agonizing with the amount of food in the bowl..
You will be able to replace the thumb screw. Be prepared to wait for at least a month for the part to arrive once ordered.
If this solution has assisted you, please rate it. Good luck! ricardok45
Mar 08, 2009 | KitchenAid KSM90 Ultra Power Series Stand...
KitchenAid 600, Stand Mixer - Loud grinding noise, happened when mixing bread dough. When bowl is lowered (dough hook disengaged)....no noise, hook turns. When bowl is raised so that hook engages dough,...
Hi. Stop using your mixer. If your mixer is still covered by warranty, call Kitchenaid Customer Service, they are very good with warranty repairs.
If your mixer is out of warranty, remove the silver band that surrounds the top of mixer. Remove the top cover. At the front of the mixer, locate the transmission housing which is now exposed. Examine this housing carefully for cracks. If you find cracks anywhere in this housing, you have found the under-engineered plastic transmission housing. Kitchenaid's replacement housing is made of metal. Your plastic housing has no business being in a mixer that is marketed as being able to mix bread dough. It cannot!
If you're confident that you can make the repairs yourself, go to the Kitchenaid website and download the parts drawings. Remove the Trans. housing, remove the worm gear shaft assembly which is driven by the motor.. Remove and save as much grease as necessary to thoroughly inspect the worm gear. Inspect the worm shaft bearings. Look for cracks, or missing pieces on the bearings. Look for crunched cogs on all gears. Be prepared to wait at least a month for your parts to arrive after you order them. The replacement grease should be Shell Darina 2, or Chevron FM ALC EP 2.
If you're not confident about repairing this yourself, call Kitchenaid and determine the nearest "approved" repair shop.
You may be able to pressure Kitchenaid to pay for the damaged parts in your mixer. They are still installing these plastic Trans. housing on new mixers. Insist on a metal cover when replacing. Apparently, Kitchenaid feels no shame in their manufacturing process, and will not issue a recall notice for these housings. They are substandard at best.
If you found this solution helpful, please rate it. Good luck! ricardok45.
Jan 31, 2009 | KitchenAid KP2671 Professional 6 Series...
My mixer was straining to stir bread dough. Now the motor turns on, but the arm does not rotate.
Did you hear a CRACK sound just as the mixer stopped running? If so, the plastic transmission housing may have failed & destroyed the worm gear and the front and rear bearings and possibly deformed the bearing seats as well. It happened to me. Although these machines are marketed stating that they can knead bread dough, they can't. Mine failed 5 months out of warranty, after only30 batches of Sourdough Bread. Take the top cover off of the mixer and look for the transmission housing near the front of the mixer. If there obvious cracks in it, it is your problem.
Dec 03, 2008 | KitchenAid K45SS Classic Stand Mixer
KitchenAid KT2651X Epicurean Stand Mixer Logo
563 people viewed this question
Top KitchenAid Food Mixers Experts
jack arons
Colin Stickland
Colin Stickland
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
