Question about Sharp 65DR650 65" Rear Projection Television
Negative picture,lamp indicator flahing 3 minutes after turning tv off
The lamp indicator start flashing,I have a negative picture.bought a new lamp installed it,still the same horible negative pix.After turning off the unit
the lamp indicator still flashing around 4 min,and stop.Need some advise
please.Leo I replaced my lamp and the picture is still bad
    Genius:
  • 3,587 Answers
Sounds like your system board is really shot ....did you have a power glitch recently? got backup?
Posted on Feb 11, 2008
2 Suggested Answers
SOURCE: negative picture,lamp indicator flahing 3 minutes after turning tv off
I changed my lamp in the 65dr650 but the picture still looks like a black and white tv and flickers
No Picture, but sound for a minute, then shuts off
I think your Display card not proper work so please contact LG Technician.
Thanks.
Feb 17, 2014 | LG RU-44SZ61D 44" TV
I have a Samsung HL-R5678W DLP TV that is acting up. When I first turn it on everything works, after 5 minutes it shuts itself off. After 2 minutes it will come back on without sound. It will do this a...
U turn tv on hear any squiling,grinding or motor noises?Picture show up before it shut down picture have flashes of black&white within the picture?Yes,to all of these,this tv have a colors wheel and it dead,require the colors wheel replacing.No,none of these problems.The tv projection lamp,if in this tv like a 1 1/2 or 2 years,tv ben on an watches like 4 or 5 hours a day?The "LAMP" LED light indication lite up or flahes,the projection lamp life is over.Require a new projection lamp.
Oct 22, 2010 | Samsung DLP HL-P5663W 56" TV
Status indicator flashes 3 short times, then one long red flash
Once the status light blinks 3 times, this is an indication that there's a problem with the lamp. The lamp may need a replacement.
If you replace the lamp, but get the same problem, check the inverter board.
If you're not sure where the inverter board is, then you may need to contact a pro for your safety.
Good luck and have a good evening!
Feb 14, 2010 | Mitsubishi WD-52327 52" Rear Projection...
TV switches itself off after 1 minute standby flahes red to green
there seems to be a possibility that your ballast might defective.. i recommend you replace it. It might not have enough voltage to keep up with the new lamp
Jul 02, 2009 | Sony Televison & Video
I cant get a picture to display after just replacing the lamp
After replacement of lamp, please put back Lamp Cover securely as TV shows error of lamp cover (3 times blink)
May 07, 2009 | Sony Grand WEGA KDF55E2000 55" Projection...
Panasonic PT50LC14 No Sound or Picture
unplug it, and let it set for a minute or 2, then try it again...if it does it again hit the power button again to turn it back on...also once the the tv turns on make sure you reset the counter for the bulb..that will also cause problems...to reset the counter press the (-) volume on the tv while holding down the (-) press spilt,pip on the reomte...the lamp will reset and the indicator will go out
Jan 20, 2009 | Panasonic PT-50LC14 50" Rear Projection...
No Picture - Lamp Indicator Blinking
This may be the main power supply, or the lamp supply. This is providing that the new lamp is okay.
The service tech will swap out the modules to service the set.
Jerry G.
May 15, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
T.v. will not turn on. flahes "lamp" then no picture!
This will have to be narrowed down to a specific problem. I would try the easiest things first. First check the lamp. Is it bad or just starting to go bad or does it just need to be reseated with the ballast? If the ballast flickers when turning on your TV, then you will know it is the lamp that is not working or the ballast may need to be replaced. If that is not the problem next check to see if the color wheel is spinning or broken. If broken, it will need to be replaced. If not spinning it is the DMD board that is bad. The color wheel is plugged into the DMD board. If the DMD board is good it will spin the color wheel, that is what will start your lamp. When you lamp starts, you have your picture.
Mar 23, 2008 | Samsung HL-R6167W 61" HDTV
Jan 30, 2008 | Sharp 65DR650 65" Rear Projection...
Sharp 65DR650 65" Rear Projection Television Logo
103 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
