Question about Foxconn NF4UK8AA-8EKRS Motherboard
Errors when i install certain games it gives me a crc error telling me that a certain file doesnt match the setups .cab file. the medium from which you are running the setup may be corrupted. I am possitive that the cd rom works and that the game works. also my operating system is operational. I have a second computer that runs the same os and the same cd rom. i have no issues with the second computer. I am pretty sure this has to do with the motherboard or the harddrive. it is a 500gb hd
  • 983 Answers
No this is not the problem with any motherboard r with hard disks this is the problem with the cdrom drive ... the capability of the reading cds is less of the cd rom u r using in this first system ... once you just have a check by removing the cdrom drive of the second computer & inserting into the first comp... it will surely read that cd....
this means it s the timt to change the cdrom of the first computer .. so just buy new 1..........
Posted on Feb 11, 2008
Setup cannot find proplus.ww owow64ww.cab
How to fix - Setup cannot find ProPlus.WW\ProPsWW2.cab
When you receive the error "Setup cannot find ProPlus.WW\ProPsWW2.cab" it might mean the MD5 checksum the install was expecting and the one on the actual file do not match. Here's how I fixed the issue.
First let me explain in simple terms what the MD5 is. MD5 is an algorithm that is used to verify data integrity. If anything in the file changes the MD5 will also change so it's a way for the program to check the integrity of the file.
The MD5 file is kept in the setup file of the proplus.ww folder. Open it with notepad and find the section that looks similar to the following **the numbers after "MD5 =" is what you need to be concerned with. Also remember that your numbers may differ. **
<LocalCache DownloadCode="{90140000-0011-0000-0000-0000000FF1CE}" SkuComponentDirectory="ProPlus.WW">
<File Id="Office64WW.xml" MD5="899A7D743D01852EBD036B465D1EF181" Size="4685" RelativeCachePath="Office64WW.xml" RelativeSourcePath="Office64WW.xml"/>
<File Id="Office64WW.msi" MD5="43B44C38BE513D9589ECAC7129DDC7C3" Size="3025408" RelativeCachePath="Office64WW.msi" RelativeSourcePath="Office64WW.msi"/>
<File Id="OWOW64WW.cab" MD5="E1E97F01F4292B89953204557A043C7D" Size="23865400" RelativeCachePath="OWOW64WW.cab" RelativeSourcePath="OWOW64WW.cab"/>
<File Id="ProPlusWW.xml" MD5="146CA2B8E1559F81E8DF6A3AED949E2A" Size="17252" RelativeCachePath="ProPlusWW.xml" RelativeSourcePath="ProPlusWW.xml"/>
<File Id="ProPlusWW.msi" MD5="F7DCCD578605F72AEEED775C9EB40AB8" Size="24809472" RelativeCachePath="ProPlusWW.msi" RelativeSourcePath="ProPlusWW.msi"/>
<File Id="ProPsWW.cab" MD5="3EA469E81A6064AE4BEFE4A9ACF36A9D" Size="149278843" RelativeCachePath="ProPsWW.cab" RelativeSourcePath="ProPsWW.cab"/>
<File Id="ProPsWW2.cab" MD5="86BEB0B6A2E76E95E580615185C06B04" Size="197934115" RelativeCachePath="ProPsWW2.cab" RelativeSourcePath="ProPsWW2.cab"/>
<File Id="setup.exe" MD5="4D92F518527353C0DB88A70FDDCFD390" Size="1100664" RelativeCachePath="setup.exe" RelativeSourcePath="..\setup.exe"/>
<File Id="osetup.dll" MD5="FCC38158C5D62A39E1BA79A29D532240" Size="5789544" RelativeCachePath="osetup.dll" RelativeSourcePath="osetup.dll"/>
<File Id="ose.exe" MD5="9D10F99A6712E28F8ACD5641E3A7EA6B" Size="149352" RelativeCachePath="ose.exe" RelativeSourcePath="ose.exe"/>
<File Id="pkeyconfig-office.xrm-ms" MD5="3DCFF1DCDEB1B837EC8F13351C8A92AC" Size="715834" RelativeCachePath="pkeyconfig-office.xrm-ms" RelativeSourcePath="pkeyconfig-office.xrm-ms"/>
<File Id="PidGenX.dll" MD5="7F120AAD20ECAE1EA421083F26611519" Size="1248016" RelativeCachePath="PidGenX.dll" RelativeSourcePath="PidGenX.dll"/>
<File Id="Setup.xml" MD5="" Size="" RelativeCachePath="Setup.xml" RelativeSourcePath="Setup.xml"/>
</LocalCache>
Next you will need to download and install an MD5 checker. I'll leave the process of how to use the MD5 to you to learn but it's pretty simple.
Next run the MD5 checker on the file/s that produce the errors during install. *there may be more than one*
Now there are 2 ways to work around this - If the MD5 on the checker did not match the MD5 in the file it probably means the file is corrupted so your best bet is to download the software again or get another disk.
Another less recommended way is to copy/paste the MD5 from the checker into the file (remember to make a backup of your setup file before) then save it and run the install again. This fools the installation process into verifying that your installation files are all OK.
Good luck!!
Jan 06, 2013 | Microsoft Office Professional 2010
After shutting down the computer a few times when transfer file from PC to CAXE3702T0, all of a sudden, blue screen and when the Window 7 boot up again, it said the CAXE3702T0 has CRC problem. I tried...
CRC or Cyclic Redundancy Check is a process that helps in identifying any errors that might occur during the data transmission process. Data is usually transmitted in small blocks, and a CRC value is assigned to each block and transmitted along with it. This CRC value is verified at the destination to ensure that it matches the CRC value transmitted from the source. A CRC error occurs when the two values (source and destination) do not match and the test fails. The main benefit of CRC is that it helps you ensure that data you have received or downloaded is not damaged or corrupt.
Causes of CRC Errors
CRC errors can occur due to many different types of problems. Some of these problems are:
  1. Damage to file during the transmission process.
  2. A problem occurred when the file was being sent.
  3. Problems with the device that is accessing or opening the file.
  4. Problems with the file itself.
Jan 14, 2011 | Cavalry Storage (CAXE3702T0) USB Hard...
When i try to install the sims 3 File: E:/Chaches/Sunset Valley.objectChache Error: Data error (cyclic redundancy check). pops up i cleaned the disc but it didnt help
If 'E:' is your CD/DVD drive, then some of the data could not be _correctly_ read from the disk.
When the data was written, a CRC value was calculated for the data, and that CRC-value was written onto the disk immediately after the data. When the data is read from the disk, the CRC-value also is read from the disk. A "new" CRC-value is calculated from the data that was read, and the "new" CRC-value is checked against the "old" CRC-value. If the two values do not match, then the data retrieved does *NOT* match the data that was written, i.e., you have an "I/O error".
Take the defective CD-ROM back to the retailer, and get it replaced, under warranty.
Nov 21, 2010 | Computers & Internet
I have an crc error problem when i install any game likh fifacricket they give me a crc error plzz givem e solution to solve this problem
CRC error usually indicates a problem with the hard drive. I suggest you do a full scan of your hard drive and have it mark all the bad clusters.
thanks adi
Jun 22, 2010 | Computers & Internet
HP Real Estate Marketing Assistant
crc is READ errors.
what is this install media
you never said, what media, CD/DVD or USB stick
nor how it was made. by you, or media came from maker.
crc is error checking system for files.
https://en.wikipedia.org/wiki/Cyclic_redundancy_check
it can happen 3 ways, one reading a bad CD
or writing your HDD. (bad hdd)
windows does the check both ways
and the actual HDD does it internally, and if Sectors in the HDD
are bad, it replaces them (unseen on the fly) until such day the HDD
runs out of spares and is DOOM.
we run SMART test on all suspected hDD
the more modern unstated windows by you, will tell you the HDD is failing early, W10 for example warns of HDD internal errors.
Simple answer
CRC is like dropping deck of cards to the floor
you pick them up , count 51, and now right away this deck is no good. no need to count suites. at all.
CRC is the big brother to Checksum (card deck answer)
MD5 is what we use to check large down loaded files for integrety
cheers !
Aug 04, 2017 | HP Real Estate Marketing Assistant...
Foxconn NF4UK8AA-8EKRS Motherboard Logo
48 people viewed this question
Top Foxconn Computers & Internet Experts
Alun Cox
Rommel Balcita
David
David
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
