Question about Sharp AQUOS LC-32GP1U 32 in. LCD HDTV
Antenna setup for digital signals is grey and not available
Cannot set up antenna for digital (HD) signals. the antenna I use does provide hd programming on my other hdtv's
in the setup menu, the antenna setup-digital is grey (not lit) and has a circle with a line through it next to the option.
i cannot find any troubleshooting info on this issue
  • 2 more comments
  • papa trey Feb 11, 2008
    yes, channels scanned and all are analog
    i have a large (huge) antenna in my attic. the line is run down 3 stories to my basement.
    would a booster that plugs to a wall outlet help?
    okay, boost made it worse.
    what does "reg one right off it" mean?
    now, i was able to get the antenna setup-digital lit by manually choosing a digital channel (5.1) and working through the setup menu, now i am rescanning channels to see what comes of it.
    Master:
    Sergeant:
  • 440 Answers
Is scan for chs lit up in options scan 1st ok
Posted on Feb 11, 2008
  • 1 more comment
  • nick helpap
    nick helpap Feb 11, 2008
    try differnt antenna what room are u in basment might wann buy philps one at walmart 50db booster ok certain rooms are picky then others we have the 32 acoes in my dads room sumtimes 66 wont come in but rest do made him buy hi quilty antella
  • nick helpap
    ya booost may help or just reg one right off it
  • nick helpap
    ok great
    Master:
  • 426 Answers
Go to the link below and it will tell you the stations you can receive and the type of antenna needed TV Fool
Posted on Apr 12, 2015
How do I receive HD Channels on a Techwood 22884 HD Digital
Ensure your antenna is properly connected. If you are using a cable or satellite provider, ensure your subscriber equipment is HD capable. If HD channel signals are not available (antenna, SAT or cable), then the television cannot display them.
Have you tried another HD television (if available) in the same configuration, and does it work? More information about your installation with manufacturer and models will help.
Feb 03, 2015 | Televison & Video
How do i get hd channels with no cable ? just antenna
If your TV has a digital tuner, you can get any HD channels if you use the correct antenna pointed at the transmitter and are close enough to the transmitters. (Antennas labeled as HD are not always appropriate for your location.) Your TV will downgrade the signal to 480i if the TV can't support a 720p or 1080i resolution.
First where do you live? Use antennaweb.org or tvfool.com to determine the correct placement of your antenna for your area/stations. AntennaWeb uses a very conservative signal strength calculation despite assuming an external antenna. Tvfool will give the antenna color rating which is also provided on the antenna package. When properly installed (with no trees or hills blocking the signal), the matching antenna should receive the listed channel.
If you use a splitter to share the signal with several TVs, you may need an amplifier to bring the signal strength to that needed for the tuner to interpret the digital signal. (Note: amplifiers and splitters can fail and the amplifier may become a signal filter blocking the signal; test the antenna strength on a direct connection if there is a problem.)
If you do not have a digital tuner in the TV, you may have gotten an SD digital to analog converter. These are the more common (and available with the government coupon) converters. You will need to get an HD capable tuner to see the full HD signal.
Please add a comment with your TV model and antenna choice for additional support.
(antennaweb indicates that my external antenna should only get the stations 10 miles away. We actually receive the channels from 30 miles away. We use an amplifier splitter to feed the signal to several TVs. I set up two indoor antennas for a neighbor's TVs. One gets the signals from the transmitters 30 miles away and the other from the transmitter 10 miles away. Both get HD from the stations with HD broadcast (not all channels are in HD here). The difference is totally due to antenna placement.)
Aug 10, 2012 | Hisense Televison & Video
PICTURE SEEMS TO BE BLURRED WHEN ITEMS MOVE FAST ON SCREEN, ESPECIALLY PERSONS IN CLOSE UP.
The Sony Bravia KDL-32BX320 generally gets excellent reviews (4.5 stars out of 5) from owners, so I have to wonder what you're watching.
This is an HDTV and should excel when provided an HD signal to display. SD (standard definition) signals often look worse on an HD display than on an SD display. An HD signal is only available via the following ways (reference the image below):9_27_2011_4_28_11_pm.jpg
1) An "over the air" (UHF / VHF) antenna is connected to the cable / antenna input and there is a broadcaster of HD content nearby (only an over the air antenna can input HD signals to this jack - no cable boxes, etc.).
2) An HD Cable TV, DirecTV or Dish Satellite set top converter, Blu Ray Disk Player (or other HD source is connected via HDMI or Component RGB jacks.
3) An HD video played back from a computer hard drive connected to the VGA jack (when the computer is equipped with a modern processor and video card).
You will NOT be able to view HD video if:
1) The source material is a SD (non-HD) source. An over the air antenna will not provide HD signals if the broadcaster does not have HD content to show or is not capable of broadcasting in HD. Digital is not necessarily HD.
2) The source material (other than over the air antenna) is connected via Antenna / Cable jack.
3) The source material is connected via Composite jacks.
The USB jack is generally not an input for motion pictures, but may display stills - depending on the TV's ability to play the format they are stored in (jpeg, gif, bmp etc.).
Hopefully, this will help you solve the problem you're having with the picture. Good luck!
Sep 27, 2011 | Sony Bravia KDL-32BX320
How can i adjustment my picture quality sharp aqu40d78un to get rip of the fuzzy look?
Your Sharp Aquos 40D78UN is a 1080P HD display, and will provide razor sharp, vibrant images if provided with an HD signal.
HD signals (those that are 720P, 1080i and 1080P) are only available from the following sources:
1) Local "off air" (antenna) HD broadcasters (providing HD content) delivered via the coaxial antenna terminals.
2) An HD source such as a stand alone Blu Ray (BD) Disk player, PlayStation 3 optical (BD) disk, HD service provided by DirecTV, Disk Network, Local CATV provider or other satellite service delievered to the TV via any of the (3) HDMI jacks or (2) Component RCA jacks (RGB). Satellite and CATV providers offer both SD and HD service. You must have HD service to watch programs in the higher quality HD format.
3) Computer signals delivered via the PC (VGA 15 pin) jack - such as movies or video in HD or Netflix HD.
It is important to note that any signal source (regardless if 720 or even 1080) that is delivered to the TV via either of the (2) "A/V" RCA jacks, will be limited to SD or 480i resolutions.
An HD picture is only possible when the source is HD, it is brought to the display over HD cables to HD capable jacks on the TV and, the display is capable of at least 720P. If any one of these variables is missing or substituted, the picture quality will be reduced significantly.
CNet has a helpful review and discussed HD signals. it is only a couple pages in length and may help you understand even better. I hope this helps and good luck! Please rate my reply - thank you.
Feb 25, 2011 | Sharp Televison & Video
How do I change my pro-730 HD to a digital signal?
You need a set-top box with a digital tuner. (For HD, you will need an HD digital source if you have cable or satellite. For OTA, you need one of those HD tuners; the digital-to-analog converters available with the government coupon last year were SD units.) You may be able to use a computer with a USB or PCI card tuner. However, you may be limited to the VGA input on the TV unless you use a converter or have a video card that can output in a TV format. (I can't find the specs for the DVI on the TV to tell if it is compatible with the RGB of the default computer signal.)
If you are getting an OTA signal, you will need an appropriate antenna pointed at the transmitter. Use antennaweb.org or tvfool.com to find out the direction of the stations you should be able to receive. antennaweb is very conservative in the list it provides even though it assumes an outdoor antenna. tvfool gives more information on the antenna for each station in your area. Note: tall trees and buildings can block the signal even if you should get a signal. Digital signals are either enough for the tuner to read or no signal. An amplifier may be needed if you share your signal between several devices.
I hope this helps.
Dec 02, 2010 | Televison & Video
I need to know what cables to get to make it true HD. Also I wanted to know why I can't receive local channels.
go to menu then tuning,set from cable to air,for local channel.you can't get true HD for cable because cable is an analog signal
Sep 07, 2010 | Televison & Video
Can I use a regular antenna
Yes. You can use a regular antenna for any flat panel HD TV. You're only limitation the type of antenna and whether or not your flat panel TV has a built in digital tuner. If it does, you'll be able to scan for digital channels without any additional components, including the High Def ones,  though you may not get every channel available with a set of rabbit ears. A roof top antenna will give you a stronger signal and more channels. If your TV does NOT have a built in digital tuner, you'll have to purchase a digital converter box and attach your antenna to it to receive the digital and HD channels. Good luck.
Jun 30, 2009 | Panasonic Televison & Video
New TV doesn't register being HD ready during test TV stations do
Try going into the setup menu and make sure it is set to antenna then do a channel program. You don't need to wait for a test there are plenty of channels already there. Both digital and analog channels are still available so you will still a message that you are not receiving digital if you are putting it on an analog channel. The channel number has to have a dot(.) in it like 8.1, 24.1 If there is no dot you are on an analog channel
Mar 13, 2009 | Westinghouse Electric W1603 15.6 in. LCD...
HDTV Turner
If your set has HD on it means set is HD Ready and you do not need Converter Box even if your only signal is coming from an antenna. Either a TV has HD or it Does not! And NO you cannot buy Parts to make your set HD.
Dec 30, 2008 | Samsung HC-P4752W 47" Rear Projection...
NO HDTV
There are many variables here that could cause the problem. I can receive a few local HD channels ( within about 60 miles ) on my 57H94. I am not aware of any "HD specific" settings- it's all part of the receiving circuits in the TV. The first thing I would look at is to be sure you have a secure antenna connection. Then be sure you have selected the correct antenna input on the TV (there are two). HD channels, as an example will show up as 10-1, 10-2, etc. Most TVs have different sensitivity thresholds, regardless of size. Usually digital signals, including HD, are either there or not. In most cases if a TV picks up a decent analogue signal, a digital set should receive the digital signal, including available HD channels, as well. If you are going to use an antenna, rather than cable or satellite, try to get the best antenna you can afford, that will meet your physical requirements ( indoor / outdoor,etc.). Keep in mind that not all digital TV signal are HD. All of our local stations in this area transmit a digital signal, but true HD broadcasts remain variable. I hope this has helped in some way-Good Luck!
Nov 15, 2008 | Toshiba 57H94 57" Rear Projection HDTV
Sharp AQUOS  LC-32GP1U 32 in. LCD HDTV Logo
2,957 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
