Question about Panasonic Lumix DMC-LZ5 Digital Camera
When turn it on the lens will come out but the cover that is over the glass part of the lens wont open
The non opening lens cover problem isnt worth paying to fix..so exactly how can I remove the lens cover ? (so that the camera can at least be used if I take care of the lens )
  • 1,162 Answers
This is a common problem to deal with in all these type of cameras. You can take the camera apart going slowly and you will need a small philips and straight screwdriver. It is easy to do but time consuming. Once you get the lens apart you can see the spring that holds onto the side and either super glue it if the plastic is broken or remove it all together. I would rather try to fix it. Let me know how it goes.
Posted on Aug 04, 2009
Tip
Solution for nikon "lens Cover Error"
Nikon Coolpix S5/S6 “LENS COVER ERROR”
In this document I have given a solution to fix the problem most of the Nikon coolpix S5/S6 cameras face. At power –on it give an error “Lens Cover Error”
Before opening the camera I would suggest you to take a snap of each and every step. Because it will helpful while you are fixing the screws back. There are many screws which has to be opened. So better take a photo of each and every step.
IMP NOTE: Remove the battery before opening the camera. Use some antistatic strip to prevent the components from getting damaged Or Keep your feet touched to the floor such that your body remains grounded.
Follow the below steps in the given order:
Step 1> Remove the screws at the bottom of camera
Step 2>Remove the side screws
Step 3> Remove the side screws as given below .
Step 4>Lift the cover and remove the cables which connects the switches to the camera. These cables are fitted in a small connector. There is a tiny lock (present for few connectors)  on the connector, which on pulling it across its hinges, will open and the cable comes out easily. You need not pull it forcefully.
Step 5> Remove the screw as shown below
Step 6> Lift the screen as shown below.
Step 7> Remove the cables and screws as shown below.
Step 8> Lift the screen panel as given below.
Step 9>
Remove cables as shown below.
Step 10>
Remove the cables as given below.
Step 11> Remove cables.
Step 12> Remove cables
Step 13> Remove the 4 wires using a soldering iron.
Step 14>
Step 15> Removing at this stage is a bit difficult. You will have to open it cleverly. Lift it from the side as shown below.
Step 16>
Step 17>Below figure shows the lens cover and the stepper motor which controls the lens civer.
Step 18> To remove the stepper motor remove the screws as given below.
Step 19> Below figure shows the stepper motor used for lens cover
Step 20> Below figure shows the stepper motor which is used to control the lens cover. There is a small white switch on this motor. This Switch is used by the camera to detect whether the camera lens cover has is open or closed. When we switch on the camera the lens cover (which is shown in step 17) opens and in turn it presses the white switch show below. If the lens cover is unable to press this switch, then the error “Lens cover Error” flashes on the camera.
I would suggest 3 different ways to solve this problem.
1>     Fix some glue on the white switch shown in the below figure, such that it remains pressed forever. Because of this, camera will never give the error message. Remove the lens cover (which is shown in step 17) forever. You don’t  need it anymore. Now fix the below stepper motor back in the camera and follow the steps in the reverse order to fix the camera components.
2>     Buy a new stepper motor from the market. Its quite cheap. Fix it back in the camera. Here you need not remove the lens cover. Follow the steps in the reverse order to fix the camera.
3>     In this method you can open the stepper motor to fix the problem. Now follow the steps given below.
Step 21>
Remove the screws as shown below.
Step 22> Remove the gears one-by-one. See the placements because you have place them again in the right order.
Step 23>
Step 24> The gear shown below is the culprit. Remove it. There is a tension spring present inside this gear. Do remember the position of this gear before removing this gear. Its placement is very important.
Step 25> The spring is shown below.
Step 26> Now the switch shown in step 20 does not get pressed because of reduced tension of the spring. Increase the tension of this spring by pulling it in opposite direction. Place the spring back in the gear and follow the steps in the reverse order to solve the problem. Now because of increased tension of the spring, the lens cover will be able to Press the switch shown in fig 20.
Happy debugging
Mukesh
on Mar 25, 2009 | Nikon COOLPIX S6 Digital Camera
Camera turns on but lense cover only opens half way
There are a few different things you could try. First would be to get some air in a can (available at walmart or anywhere similar) and give the lens a good cleaning with that. Also you can get a glasses cleaning cloth and wipe off the lens and if you can, manually open the non working part of the cap and clean under it.
Hope that helps!
May 11, 2011 | Kodak EasyShare MD41 Digital Camera
1996 mercury villager minivan rear hatch wont open acts like its locked but it isnt?
http://groups.yahoo.com/group/villagerquest/
go here.
You can remove the inside trim panel for access. If rear hatch glass opens, you will need to remove small cover first, above trim panel
gerry
Jan 31, 2011 | 1996 Mercury Villager
Sony HDR-XR200 lens cover problem
You have two options, replace the motor that opens and closes the lens cover or remove the lens cover shutters all together, and use a 30mm lens cap.
May 25, 2010 | Sony HDR-XR200V High Definition AVCHD...
My zoom lens is not opening when i switch on the camera and the screen is showing a message zoom error
Usually those symptoms indicate that the lens extension drive motor or gears are jammed or failed. This means you will need to take it in for repairs or replace it.
Unfortunetly the repair cost on this is not cheap and can come close to what a new camera is worth. If you have warrenty then get it fixed it will be covered but if you are paying for it then get an estimate and check it against the cost of a new camera.
Apr 27, 2010 | Fuji FinePix S1000FD Digital Camera
The lens cover doesn't open fully Canon A630
Sure it is, and repair isn't that hard. See this link for tips on repair of sticky automatic lens covers. Recommend reading the reader's comments section of the link for additional tips. Especially pay attention to the vacuum cleaner tip.
Feb 08, 2010 | Canon PowerShot A630 Digital Camera
Automatic lens cover will not open.
please try resetting your camera to the factory settings..the procedure to reset is found in the instruction manual as well as in the cd that came along with your device. thank you for using fix ya
May 26, 2009 | Canon Cameras
Lens wont extend, lens error restart camera
My wife's Canon SD200 got stuck with an open lens and the E18 error. I opened the case and wiggled things and still nothing. Then, I turned the camera on and started tapping the edge of the lens casing with the magnifying glass I'd been using (need the battery and memory chip in place and make sure you've transferred pictures to your computer before trying this). Voila! The lens closed. But, of course, it wouldn't open and still gave the E18 error. Well, one good tap deserved another and Voila! again. It opened. After a few more iterations - and cleaning the lens casing each time, it was back to normal. The trick is the timing of the tapping. Just after turning on the power to the camera start tapping on the lens casing - not hard - just a light tapping. And don't tap on the glass lens itself -- you don't want to really break it.
May 15, 2009 | Canon PowerShot SD600 Digital Camera
Panasonic Lumix DMC-LZ5 Digital Camera Logo
231 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
