Question about Optoma EzPro 739 Multimedia Projector
Optoma EP739 Our projector started buzzing a few weeks back and wouldn't work. We assumed it was the bulb and replaced it, but it wasn't. The we noticed that the fan was not spinning, so we ordered the part online, and then today replaced it. Still not working. Upon further disection, we have discovered that there is a sort of color wheel that spins in front of the lens -- a transparent wheel divided into four colored sections. One of our sections had snapped off, and since the wheel is now unbalanced, it is buzzing. What is this part called, and how do we get a new one? Hope you can help! Tammy
  • rohitmuk Nov 13, 2008
    I was watching TV on my ep 739 and heard a bang followed by a buzzing noise while the projector began to vibrate. Opened up the unit to find shattered peices of glass strewn about the casing. Its the colora wheel. called optoma support a new wheel costs $99.00 + $18 ground shipping. Or if you send it in they will replace and ship it back for $130, but will probably take 3 weeks or so... anybody know where to get the color wheel for cheaper online?
I have the same projector with same problem. i called optoma direct and ordered a new color wheel. it was relatively easy and came in about a week. the phone no. is 408-383-3710
Posted on Mar 08, 2008
    Master:
    Sergeant:
  • 440 Answers
Coler wheel ?
Posted on Feb 11, 2008
The lamp exploted in less than 30 hours of use, replaced an exploted in 4 hours, replaced and exploted in 5 minutes what can I do?
Is it the correct bulb? Or recommended bulb? Try a higher wattage or lumens. I'm not sure what the lamps in the projectors are called, but check on the wattage and lumens.
Dec 07, 2014 | Optoma EP739 Multimedia Projector
We have a optoma ep739 used at our local football club;but whenit gets warm it cuts out until it cools down;isthere any filters that need cleaning
take the lamp out, there is a fan directly looking to the lamp... clean it with a compressor. and after that at the menu of projector there is a place called 'High Altitude'. turn it on. And it'll be fine...
Mar 01, 2010 | Optoma EP739 Multimedia Projector
Optoma hd65 projector new bulb wont turn on...cant reset timer!
I think it's a lamp driver issue from what I've seen others have gone through. I also read that if you go through the sequence of unplugging, plug back in, wait 20 seconds and try to turn on, multiple times, it will finally kick on and work. I just got mine to turn back on by doing this and waiting through the fan cycling without the light turning on. After the 4th sequence the light flickered. After the 7th sequence it finally turned on and is working. Now I can watch the Super Bowl and will look into replacing soon.
Jan 31, 2010 | Optoma HD65 DLP Projector
Optoma ep739 color was going greenish so i replced the bulb and now it seems to be getting no power at all? i tried several outlets and still no power, no flashing light, no led, nothing. Any suggestions?
These units have many safety interlocks. First make sure that all of the doors that you opened are replaced correctly. If not, the interlocks will prevent any power from getting to the unit. Update this with what you find.
Dan
Jan 29, 2009 | Optoma EP739 Multimedia Projector
Optoma HD65 bulb only 108 hrs old having difficulty starting up
Use the warranty! since you anly had it for 8 weeks, and the waaranty last for one year, go back with it and get it repaired or get a new bulb. A buld last at least 2500 hours, in eco mode it last for over 3000 hours.
Good luck to you
Dec 17, 2008 | Optoma H30 Multimedia Projector
Optoma EP739
The lamp cover has a disconnect that wont allow the unit to power on while the cover is off.
Try taking the lamp cover off and bending the little piece of metal you find underneith.
It worked for me.
Nov 01, 2008 | Optoma EP739 Multimedia Projector
Can you tell me why the optoma HD72I lamp will turn off after just a few minutes of running, the lamp is still fine
I have the same problem. I got a new bulb and it worked for about 1000 hours, then the new bulb started having the same problem. So, I was about to buy another bulb, and I figured why not try the original bulb. IT WORKED! For a couple weeks... Then it started doing it again. Obviously there was nothing wrong with the original bulb, and there is nothing wrong with the new bulb, but I have 2 bulbs that do it now. So, is there any way to just tell the projector run the bulb till it actually dies and not turn it off because it thinks it is about to die.
Aug 01, 2008 | Optoma HD72 Multimedia Projector
Optoma EP739 Projector Overheating
Set the projector to "high altitude mode." It will be noisier, but won't overheat. I wonder whether using one of those $10-$20 laptop coolers underneath it might be a quieter solution.
Mar 09, 2008 | Cameras
Open Questions:
Optoma EzPro 739 Multimedia Projector Logo
1,001 people viewed this question
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
