Question about Lexmark X3470 All-In-One InkJet Printer
Lexmark x3470 Purchased a non lexmark brand printer cartridge, it did the alignment page and printed, but won't print anything else, WHY?
    Sergeant:
  • 390 Answers
Hello, always keep dockets. Could be a dud cartridge. Recommend clean unit with own printer program, especially a deep clean if you have this. Try cleaning manually with proper cleaning solution and cotton tip, where cartridge sits. Also, is the cartridge the correct generic equivalent of the genuine lexmark, you may have wrong no cartridge too. good luck, lilacgerry xxx
Posted on Feb 11, 2008
My lexmark x3470 wont recognise compatible ink Cartridges any know of a way round this
If the ink cartridges you purchased are not Lexmark - that could be the problem. I used to have a Lexmark printer and I did the same thing - I purchased ink cartridges that were compatible but not Lexmark brand. Everything seemed fine until I tried to print and then I would get the same error sign and low ink message and it would not print. I kept thinking I was doing something else wrong and tried everything. In the end I broke down and got ink cartridges from Lexmark and that solved the problem. Now I have a Brother printer and I never buy anything other than Brother ink cartridges because I'm always afraid of that same thing happening again. I wish I knew which printers WOULD accept those non name brand ink cartridges, but thus far I do not know of any printers that do. Hope this helps you.
Mar 24, 2012 | Lexmark X3470 All-In-One InkJet Printer
Brand new ink cartridge for Lexmark X3650. Error message to remove tape from cartridge. Tape has been removed. Print alignment prints in only black and same thing on cleaning process.
You can try to manually wipe the cartridge nozzles with a moistened soft cloth to clean it from dirts and clogs. You can also clean the nozzles using the Lexmark software on your computer. If you're using Windows, go to Programs/All Programs > Lexmark 3600-4600 Series folder > From the printer folder, click Maintenance > Clean Cartridges > Print. A page prints, forcing ink through the print cartridge nozzles to clean them.
May 27, 2011 | Lexmark X3650 Printer
My lexmark x2600 keeps telling me i need to realign the cartridge but nothing is really wrong.. wont let me print anything but alignment test pages. How do i fix this
One of the utilities included with the Lexmark software will print a "test" page.
Then, you view the test page, and enter some numbers into the utility.
The utility uses those numbers to (ectronically) align the print-heads.
Dec 18, 2010 | Lexmark X2600 InkJet Printer
Lexmark All-in-One Alignment Problem
-take out your cartridges and put it back in again after 5 minutes.
-print an alignment page and you have to scan the alignment page that you printed
-try to print
Apr 07, 2009 | Lexmark X2470 All-In-One InkJet Printer
Lexmark x3470
This printer only has a color cartridge, but you can still use the color cartridge to print black and white. It mixes the cyan, magenta, and yellow inks to make black. You do not have to do anything special to make this happen--just print as normal.
Feb 04, 2009 | Lexmark X3470 All-In-One InkJet Printer
How to change lexmark Cartridge
  1. Click Start, Programs, Lexmark Series.
  2. Click Lexmark Control Panel.
  3. Click Print Cartridge installation.
  4. Depending on which cartridges you are using and which printer model you have, select Install Color Cartridge or Install Black Cartridge or Install Photo Cartridge.
  5. Carefully remove the tape covering the printhead of the print cartridge. Important: Be sure to remove all of the tape. Do not touch the copper area on the back of the cartridge.
  6. Insert the print cartridge into the print cartridge carrier.
  7. Push the cartridge back until it clicks into place.
    • If the print cartridge moves loosely in the carrier, it is not locked into place. Repeat step 7.
  8. Click the appropriate Cartridge Installed option in the printer software.
    • If you choose to install a new print cartridge, you will be prompted to align your print cartridges. The printer will print a page with a bi-directional alignment pattern. Follow these steps to align the cartridges:
      1. On the printed test page, locate the number under the Bi-directional Alignment pattern that comes closest to forming a straight line.
      2. Enter the number as the Bi-directional Alignment setting in the Alignment Cartridge screen.
      3. Click OK.
  9. Close the front cover of the printer.
Dec 09, 2008 | Lexmark X1150 All-In-One InkJet Printer
Problems priniting
copy alignment..did you try a test page`?
Oct 13, 2008 | Lexmark X3470 All-In-One InkJet Printer
PRINTING PROBLEM X3470
Are you using an OEM cartridge or a refilled one?
Jun 27, 2008 | Lexmark X3470 All-In-One InkJet Printer
Alignment Error
well, got tired of it so, i trashed it-replaced it with a lexmark X3470, so far no problems, cheaper ink... great printer :) Plus it has a real scanner not one that feeds through
Feb 04, 2007 | Lexmark X4270 All-In-One InkJet Printer
Lexmark X3470 All-In-One InkJet Printer Logo
63 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
