Question about Linksys WPC54G Wireless-G Notebook Adapter V2.0 (WPC54C)
Keep getting kicked off
I am able to connect to the internet through my wireless connection but i keep getting disconnected from the internet every 2 minutes and i have to keep reconnect to the network. It remains connected to the access point but it says the internet can't be found
  • ddial May 14, 2008
    I have problems staying connected as well...........every so often it states it can not find ip address and i am disconnected from the internet...what can i do to fix this problem?
  • Anonymous Mar 20, 2014
    Keep getting this message and losing internet connection
Make sure to that you are using your laptop within recommended range of signal..
Posted on Jun 20, 2008
  • 84 Answers
Usually the problem like this was cause by unupdated firmware of either you wireless card or router. check the manufacturer of both devices and check the website if there is any updated firmware of both. you will also find instructions on how to upgrade the firmware on the manufacturer website.
Posted on Feb 11, 2008
Keeps Getting DIsconnected from network
CONTINUAL DISCONNECTION OF WIRELESS CONNECTION
There are a few things that can cause you to lose wireless connection with your wireless router. 1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from brick or concrete walls and if possible locate the wireless router higher up. 2. Have you secured your wireless router from people near your from unauthorized access? i.e. change the default password, setup encryption use WPA2 or WPA, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router. 3. You could be getting interference from electrical sources such as air conditioners, arc welders, washing machines etc. If so, the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply). 4. Check the channels of the wireless routers and access points in your area and change the broadcast channel on your wireless router to an unused channel or one that is currently used but has the weakest signal strength. This will minimize interference with your wireless router from other wireless routers and access points in your area.
Mar 18, 2013 | D-Link Computers & Internet
Dv6-6110 wireless Internet button not working
So your saying your losing Internet Connection?
Feb 27, 2013 | HEWLETT-PACKARD Hewlett Packard HP...
when sharing internet connection, it's all about sequence when turning it on... Sequence in regard to what's turned on first, second etc... Here's the solution:
1. Turn everything off... modem, router...computers etc..
2. Turn on the wireless router FIRST and let it boot up.
3. Then turn on the modem and let it cycle up...
This allows your modem to lock onto the wifi router.
4. Turn everything else back on...
You should be good to go without drop outs...
If the power goes out, simply follow this sequence...
It's all about the sequence!!
May 31, 2010 | Belkin N Wireless Router wireless router
Engenius eap-3660 access points channels chashing.
This is a massive and expensive network, which appears to require a full signal and configuration audit. It's quite possible that many of your problems are stemming from the APs you have already deployed being situated in suboptimal and conflicting locations, which is an issue with three-dimensional wireless networks.
I really don't see your problems being debugged by anyone short of an experienced on-site wireless network technician. I'm saying this as a person who tuns a one-man company serving two rural communities with wireless internet service.
Sorry.
May 07, 2010 | EnGenius EAP-3660 802.11b/g Wireless...
Frequent disconnection using wireless router
if you live in a heavily populated area you might be experiencing interference try switching the wireless channel on the routers config page. if there's a choice for auto-channel try that.
Jun 28, 2017 | Trendware TEW-432BRP Router (S4432514)
Kicks in and out the internet all the time.
Try to see if your firewall is bloking your router,if so change the firewall to allow your router to access the internet
May 31, 2009 | Linksys Wireless-G Broadband Router
Wireless Router Randomly Disconnects
I am having this problem as well, however my connection goes from 56M down to 1M and I cant connect to anything. I previously thought it was my router but none of my other systems experience it. If you know someone with an external Wireless card I'd suggest trying that before purchasing one. I dont believe anyone can fix an internal wireless card that goes bad. Try downloading the latest drivers for your PC/LAPTOP's wireless device and reload it.
Jan 07, 2009 | HP Pavilion dv6000z Notebook
I have recently bought a Belkin 54G Mod Router so that I could use my laptop with wireless connection in another room while my PC remained wire connected. I have installed it as directed but I keep losing...
a couple of question for you, is your wireless secure or did you enable security features like wep or wpa, how many people authorise people are on your network. if not secure, secure your wireless network, hackers like to kick people off their own system, upgrade the firm ware on your router, for the latest compatibility it will fix issues that arise and finally do a bios upgrade on your laptop.
May 26, 2008 | Belkin Computers & Internet
Laptop keeps disconnecting then connecting every so often.
Has the computer ever stayed on long enough to connect to the internet?
Is there a wired computer working when attached to the router?
If not, if possible please try to connect the laptop wired to the router as a test and tell me if it works.
I am trying to determine if your router works with the internet before considering the wireless connection simplying the initial problem. Once the router works wired is time to try the wireless. Once the wireless works unsecured you may want to change the router and wireless adapter to secure the wireless network. So this can be a three step process.
Jan 03, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Open Questions:
Linksys WPC54G Wireless-G Notebook Adapter V2.0 (WPC54C) Logo
232 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
