Question about Toshiba Gigabeat MEG-F10K MP3 Player
Windows media player won't recognize Gigabeat device
As though they couldn't have made the Gigabeat more difficult to use and user un-friendly if they had designed it to be that way, it seems to be getting worse as my problem gets more and more agrivating and ilogical. When I want to sync my music from my PC to my Gigabeat I don't want to use the (pardon my french) shitty software provided by Toshiba that apears to be designed by a second grade student as it is bungling and confusing. I want to sync exclusively from WMP, so I must plug it into the dock and then plug the dock into my PC via USB cable for it to be recognized. This used to work up until a couple weeks ago when, all of a sudden, doing all of this wouldn't get my device recognized. I tried uninstalling/reinstalling the gigabeat room program, but that didn't work. I really don't know what to do anymore, and help resources are slowly draining my patience.
  • 4 more comments
  • Anonymous Feb 28, 2008
    my mpt player wont show up in wmp
  • Anonymous Mar 14, 2008
    I've had the same problem with WPM. It used to work and now it doesn't see it. I've changed the settings on the gigabeat to just WPM and it will come up with gigabeat room only.
  • Anonymous Jul 26, 2008
    same here
  • raulc1111 Sep 23, 2008
    i updated mi windows media player to wmp 11 and now i cant open my gigabeat v30 the way i used to which was kind os simple now i cant do anything :S plx help
  • Anonymous Dec 30, 2008
    pooooooooooooooooooooop pppppppppppppppppppppppppoooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooopppppppppppppppppppppppppppppppppppp pppppppppppppppppppppppppppppppppppppppppppppppppppppppppppoooooooooooooooooooooooooooooooooppopoopopoppooppopopopopopopoppopooppopopoooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooopju8t77tgutt77777777777777777777777777777777777777777777777777777777777777777777777777777777777777777777777777777777777777777777777777777777777777777777777777777ccccccccccccccccccccccccccccccccccccpp ------------------[0000000000000000000000000000000ooooooooooooooooooooooooooooooooooooooooooo00000000000000000000000000000000000000000000000000000000000000000000000000000oooooooooooooooooooooooooooooooooooooooooooooooooooooooo0000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000ooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooo00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000oooooooooooooooooooooooooooooooo60000000oooooooooooooooooooooooooooooooooooooooooooooooooooo0000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000ooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooo000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
  • TWRX Jan 09, 2009
    My S30 previously worked fine. Now WMP wont recognize it at all, though the PC does because when I plug it into the USB port it asks if I wish to Sync. About the only system change I've made recently was to install Vista onto a secondary drive and dual boot. Does anyone know of any fix or if it may be related to the dual boot install?
My T400 windows embeded toshiba gigabeat is fully charged and is not turning on. what should i do? i plugged it into my windows xp computer and my computer told me the USB device that is connected is...
sounds like something inside has shorted or blown. when you plugged it into windows did it say power surge on hub or did it say USB Device not recognized
Mar 03, 2011 | Toshiba Gigabeat T400 MP3 Player
4yr old gigabeat 30gig won"t connect to PC
Try re-installing windows media player 10. It did the trick for me.
Feb 26, 2009 | Toshiba Gigabeat S30 MP3 Player
Vista recognises Gigabeat F40 as a hard drive and not an Mp3
hi had the same problem with mine, you must use the dock and have the connections setting set to media player it will sync then
Dec 05, 2008 | Toshiba Gigabeat MEG-F20S MP3 Player
File transfer Problem
Ok, I figured out a solution on my own.
Remarkably simple - all I did was reformat the player again and then reinstall windows media player.
Although in my travels I came across an article which may help users with a similar problem: http://support.microsoft.com/kb/911091/en-us#appliesto
Apr 20, 2008 | Toshiba gigabeat S MP3 Player
Toshiba Gigabeat
try using windows media player it does work if you go to the setting file on yor f20 and slect media player in the pc connections folder
Apr 20, 2008 | Toshiba Gigabeat MEG-F20S MP3 Player
Computer does not recognize Gigabeat Device
Check the manufacturers website for specific Vista drivers.
Mar 08, 2008 | Philips GoGear HDD075/17 MP3 Player
Gigabeat u202 sl, winXP sp2
I have a similar problem. I bought a new gigabeat U 2Gb in USA last week. It functioned properly in computers in USA. Now I'm in Argentina and I can't connect it to my computer (windows XP and windows media player 10 both in spanish)I tried install WMP 10 in english that came in the CD and the other
two files windowsmedia10-kb902344-x86-intl.exe and windowsmedia10-kb895316-x86-enu.exe and in the last case apear this message:
"Setup cannot update your WMP 10 files because the language installed on your system is different from the update language". Do you have any suggestion to solve my problem? Thanks
Jan 04, 2008 | Toshiba Gigabeat U202 MP3 Player
the solution is simple. Simply Run both Gigabeat watcher and giga-room programs as administrator if u have windows vista.
How to do this :
Click on start in the taskbar at the bottom right of your screen,
then click on all programs,
then click on the Toshiba Gigaroom Folder,
then right click Gigabeat watcher and click on "Run as Administrator"
then right click "Gigaroom" and click on Run as Administrator
and then look in the bottom right of the taskbar, the little Gigabeat watcher symbol should be there with a green square instead of grey. If its green then it means Vista has recognised your gigabeat and u can now transfer music to it via gigaroom. i hope this helps people as i was on the verge of buying XP myself again... Peace all and HAPPY GIGABEATIN!
DREZO 9/3/2009
Oct 12, 2007 | Toshiba Gigabeat MEGF40S MP3 Player
Toshiba Gigabeat MEG-F10K MP3 Player Logo
240 people viewed this question
Top Toshiba Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Jerry Kramer
Jerry Kramer
Are you a Toshiba Audio Player and Recorder Expert? Answer questions, earn points and help others
