Question about iLO (2 GB) MP3 Player
Is it chargeable, it doesn't seem to charge
Doesn't say anywhere if it is chargeable or not
  • 8,596 Answers
It is
Posted on Mar 19, 2008
I have a charging station for the Motorola T8500 walkie talkies which holds two of the T8500. When plugged in only the back slot can be used charge. The front slot does not work.
This is common. For some reason, the GMRS chargers of all brands break often. Unplug the unit. Try lightly sanding the contacts on the front cup/slot. Make certain you do not push them in too far. If you do, carefully pull them out. They should be bright. Then clean the contacts on the radio. If it still does not work, use a voltmeter and test the power is getting through to the battery from the charging cup. The voltage is DC and should read anywhere from 6-12 volts, maybe more.
Nov 11, 2016 | Motorola Radio Communications
How do you recharge the battery casio m850
if it doesn't have a jack for a charger or a charger stand to sit it in then it will not be re-chargeable as such
you will have to remove the battery and check if it is an alkaline battery ( not re-chargeable ) or a rechargeable battery in which case you will need a battery charger for that type of battery
If that is the case get spares and have a fully charged one on hand to just swap over while the other is charging
Sep 13, 2015 | Casio Cameras
My device is three months old. The charger is giving current as I am able to use it while plugged in, but will not charge at all. The device works beautifully in every other way accept for the charging...
Seems like internal battery charge controller has got fault or internal battery is not accepting charge. If it is under warranty then take it to the servicing centre.
Mar 20, 2015 | Bose SoundLink Color Bluetooth Speaker...
I believe that my charging port on phone is coming loose. Is there anywhere that I can fix this? I really don't want to spend a ton of money either.
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Jul 30, 2012 | HTC Vivid
The canopy on my Graco Stylus Travelsystem Stroller has an extra flap of fabric that doesn't seem to go anywhere. It hangs over the cupholders or lays over the canopy covering the window. It...
You may have the top on backwards. The flap is usually used as a sun shade, and should probably be over the open part in front of the stroller.
Nov 19, 2017 | Graco Snugride
I have a wirless xbox 360 headset and it was working about 4 days ago and I had it on charge when it died when I went to charge it wouldn't charge or turn on and I have had it to long to take back to...
so you are saying that you have a chargeable microsoft headset and the last time you tired to charge it. it would not work... it sounds like your rechargeable battery is dead and you might need a new one. also try you head set on a friends unit and see if it works, at the same time take their chargeable battery and place it in your headset and see if it works that will tell you if it is your headset or the battery..
game tag DeepReserve
May 19, 2011 | Microsoft Wireless Headset for Xbox 360
How do i charge it?
You do have re-chargeable batteries in it? You could try a new set of batteries and there's usually a "Connect button you can press to reconnect it after installing new batteries.
Jan 02, 2010 | Dynex Wireless Optical Mouse
Kodak Z812 shuts off automatically
It is a high-powered camera, also knows as a GREAT camera. Use CRV-3 lithium duracell batteries. I have the same camera and the same "problem", but when I use that battery it lasts forever.
Dec 03, 2008 | Kodak EasyShare Z812 IS Digital Camera
Wii docking station
try new (non chargeable) battery's and if they work then you have bad battery's, if they dont you have a problem with the remote or unit.
Jan 07, 2008 | Nintendo Wii Console
iLO (2 GB) MP3 Player Logo
19 people viewed this question
Top iLO Audio Players & Recorders Experts
Mohamed Ismail
Mohamed Ismail
Michael Vincent Cruz
Are you an iLO Audio Player and Recorder Expert? Answer questions, earn points and help others
