Question about Whirlpool Duet GHW9150P Front Load Washer
Help - my clothes are tearing
My daughter's pajamas, my t-shirt, my husband's t-shirt... I think it's the washer, has anyone else complained of this issue and what can I do about it?
  • KimRN Feb 12, 2008
    i HAD THIS PROBLEM TOO, IT SHREDDED SEVERAL OF MY DAUGHTERS LIGHTWEIGHT SHIRTS AND SOME BRAS. I CANT FEEL ANYTHING SHARP AND WE STARTED PUTTING DELICATES IN A GARMENT BAG TO WASH BUT I HAVENT NOTICED THIS PROBLEM FOR AWHILE NOW. I AM STUMPED.
  • 2839077 Mar 11, 2009
    My wifes Pajamas ans some of our bed sheets have rips and holes in them like you took a serated knif to them This just started about 2 months ago and dosen't happen every load The last pair of pajamas were realy ripped bad Model GHW9150 WHIRLPOOL
    Genius:
  • 1,554 Answers
I've heard of this often and don't know of any fixes.
I would suggest getting womens hosiery or Halloween spider web cotton and running it around inside to see if it snags.
make sure the basket arms inside are not loose. rock them hard while holding the drum. sometime those arms come loose and pinch the clothing.
Posted on Feb 13, 2008
Amana 7300 Tandem
Check the drum surface of your dryer for possible object that may be stucked in the drum holes that may cause damage to the clothes. You may do similar checks of the washer drum if your dryer drum checked negative.
Good hunting.
Aug 21, 2017 | Dryers
Whites are dingy. Random stains appear on my husband's dress shirts that weren't there when I put them in the wash. We have a water softener; don't know if that plays into the problems. Please help!
Put washer through a clean cycle with bleach only. Check to be sure you are using HE soap. Check the bellows(door seal) make sure it is not jamming clothes.
Oct 29, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My washer damages clothes
You should inspect the inside of the drum for damage or something stuck in the drum perforations. I have had exactly this problem and it was caused by the wire from one of my wife's bras coming out in the wash and getting stuck in the drum perforations.
Mar 01, 2010 | GE WSXH208A Front Load Washer
Maytag puts holes in clothes
try to change the soap and the washing cycle to delicate,good luck
Sep 17, 2009 | Maytag Neptune MAH5500B Front Load Washer
Holes in clothes
Inspect the rubber seal, and steel drum to make sure there is no foreign object sticking out, which could be tearing holes in your clothes. Also check to see if any of the holes in the steel drum are dented in. or out or misshaped, as this could cause the tumbling action of the drum to tear clothes.
Mar 13, 2009 | Kenmore HE2 Plus Front Load Washer
Maytag Neptune 9700 series
IT SOUNDS LIKE THE OUTER BAND TO HOLD ON THE DOOR BOOT/SEAL. WHAT I HAVE SEEN IS THAT AN ARTICLE OF CLOTHES WAS NOT ALL THE WAY INTO THE WASHER AND IT WAS STARTED, PULLING THE DOOR BOOT INTO THE WASHER. THE ONLY OTHER THING I HAVE NOTICED WITH THIS NEW BREED OF SUPER CAPACITY WASHERS IS THAT THEY LIKE BIGGER LOADS TO HELP BALANCE THEMSELVES. IT MAY BE POSSIBLE THAT IT WAS SO SEVERLY OUT OF BALANCE THAT IT PULLED THE BOOT INTO THE TUB AS THE MAYTAGS OF THAT MODEL LINE WERE KNOWN TO NOT BE THE MOST SENSITIVE TO OUT OF BALANCE CONDITIONS. THERE IS A CONTROL BOARD KIT THAT COMES WITH A MOTION SENSOR NOW FOR THEM AS AN UPGRADE.
Jan 27, 2009 | Maytag Neptune MAH9700 Front Load Washer
Tiny holes in clothes
We have the same problem. Look at the agitators inside the washer. We found strings and material there. Not sure what or if there is a fix bout I just saw the problem 2 days ago.
Aug 26, 2008 | Maytag Neptune MAH5500B Front Load Washer
GE Front load washer clothes coming out with holes/torn/even shredded
Metal inside washer drum may be faulty and causing tearing of clothes (run your finger around the inside when empty and you will feel where it snags). Had same problem, only got worse and ruined many expensive t-shirts! Replacement of drum is required and is extremely costly if not under warranty!
Jun 05, 2008 | GE WSXH208A Front Load Washer
Washer Creates holes in clothes
We purchace a washer and dryer in Dec 08 Kenmore HE energy star. They started destroying cloth about 2 months after purchace.
under our warranty and many many calls they sent a new set. 2 months later same problem. HELP
Nov 12, 2007 | Kenmore 98702 Stacked Washer/Dryer
GE top load Washer ripping clothes
Solution!
GE has replaced the "boot" (the large rubber gasket at the opening of the washer) on my washer. This has fixed the problem!
Although the majority of people I spoke with at GE did not know about this, eventually I got a repair technician out here who spoke with one of the engineers. The engineer said that there was a problem with the boot causing clothing to rip. The new boot we have on our washer covers a ring of plastic just on the outside of the metal drum (the plastic rim remains stationary while the metal drum spins - this is the cause of the ripped clothing) - the old boot left this plastic ring exposed. Our washer was only 8 months old - so even if your washer is new, if your clothing is being ripped, insist that the boot be replaced for an updated version.
May 03, 2007 | GE Energy Star WCVH6260F Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
1,317 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
