Sanyo AVM-2054 TV Video interruption
Hi, Our Sanyo TV turns on fine but after a short period of time (varies), the picture is overlaid with a large black box leaving about an inch and a half border all the way around the screen showing the TV program on the border only. When menu button is pushed, black box disappears, but reappears as soon as graphics clear from screen.
This AVM-2054 TV has a G4Z-20540 Chassis.
Any ideas?
  • yesac May 01, 2008
    After the TV is on for a bit in the mornings, a black box appears and the picture can still be seen around the black box. It used to really happen on ESPN, now it happens on a local channel and various channels, but not all channels. I can turn the TV off and back on and the black box disappears. Most of the time when I get the black box, there are letters and symbols like this: a~a~a~g*fg^g^g^g^. I used to write them down thinking they meant something, but now I don't.
techman
  • 3130 Answers
SOURCE: Screen split with black bar through center, top of picture shows in bottom
It sounds as you desribe, the vertical output IC and or the b+ feed capacitor off the Hi voltage transformer feeding the vert. IC its required voltage. Not a really hard job to replace, but not for a handi person to do. This should be left to the professional, as there are no user serviceable parts inside this set and with the HI voltage and the safety issues its best to call somesone to assist you with this repair. Good Luck
Posted on Jun 14, 2006
techman
  • 3130 Answers
SOURCE: black rectangle on t.v. screen
It sounds like you have the Text feature on the closed caption option turned on. your going to most likly need an original remote to turn this feature off as far as i know of. If you do not have an original toshiba remote to turn off the clkosed caption or in some sets you have to go into the menu to turn this feature off, maybe you can borrow one from a friend that has one or you can get one from http://www.remotes.com. Good liuck and let us know if you need more assistance
Posted on Oct 05, 2006
  • 556 Answers
SOURCE: schematic for a sanyo avm 2506 tv
schematic for a sanyo avm 2506 tv. please check www.serviceinfo.com for schematic diagram.
Posted on Sep 28, 2007
  • 71 Answers
SOURCE: Black Box on Screen
you have to turn OFF cc - closed caption - in the menu
Posted on Apr 29, 2008
  • 108 Answers
SOURCE: Black box showing up in center of tv
your closed caption feature is turn on and in the text mode. either turn off the closed captions or change it from text to cc1
Posted on Jan 08, 2009
Loud buzzing sound on Sanyo AVM 1909
I had a problem like that so I disabled the tv's onboard tuner (input source)and now we use the cablebox's video and audio out to the video and video in jacks on the TV this will work as long as you have a cable box or sat reciever for your video and audio source and of course your TV must have video and audio inputs so it will work.
Good luck Rich
Jun 06, 2010 | Sanyo AVM-1909S TV
Sanyo Model AVM 3659G won't recognize DVD player
Let's try the easy one first:
  • verify the connections, normally yellow for video, white & red for audio. TV has to be set to Video 1, A/V or Channel 0;
  • in some instances, it could be a single coaxial cable. If it were so, the TV has to be set to Ch 3.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 05, 2008 | Sanyo AVM-3659S 36" TV
SANYO TV MODEL CM20SP8S CHASSIS AC3-A20
try to fine tune your tv using the remote control, or, if you had knowleged in electronics adjust the sound IF transformer using a wood stick or plastic don't use a metal in adjusting the IF
Sep 01, 2008 | Sanyo AVM-3259S TV
Tv in video mode
sanyo model: AVM-21 MB
problem: during tv mode the reception will loss and back
in turn to blue color then back to channel frequency!
at video the picture is okay but ther is no audio!
can you please suggest me how to solve this problem
can you send this to my email add.
albertdlc_12yahoo.com thank you and more power!
Jul 21, 2008 | Sanyo AVM-3259S TV
Sanyo TV
every time i plug tv in outlet it blow the fuse inside tv board
Jul 01, 2008 | Sanyo AVM-3259S TV
Hi I would suggest getting the Phillips Digital 5 Device remote Model PHDVD5, I have one of these, and I have yet to fond anything this universl remote will not operate, it is outstanding! you can get this remote at a local WalMart store, thats where I purchased mine, goodluck:)
Mar 10, 2007 | Sanyo AVM-3659S 36" TV
Sanyo PLV-55WM1
Hi I read your problem with the Sanyo PLV-55wm1. It sounds to me like a power supply problem. Like most new electronics devices, they use a switched mode power supply (SMPS)to supply the voltages to the rest of the set. Many of them use a current feedback loop to sense a short in the circuits that it powers. I would check for a shorted diode in the high voltage section of the tv. If any one of the components is shorted around the high voltage circuit, The current control line will be zero forcing the regulator to shut down.
Mar 25, 2007 | Sanyo AVM-1909S TV
TV sounds like power up for few seconds then goes off
You have a short somewhere causing the power supply not to start. Most likely a shorted horizontal output transistor and maybe a flyback transformer which caused the transistor to short. It would have to be checked out by a technician to find out exactly happened. Stargazer
Mar 04, 2007 | Sanyo AVM-2506 TV
Televison & Video Logo
133 people viewed this question
Top Televison & Video Experts
