Question about Bosch 23 in. SHU33A Built-In Dishwasher
Black spots on plastic items
After washing plastic items more often then not have black marks on themm, Apears like grease! Care is taken to ensure nothing is rubing agaist them. The machine is less then 2 years of age. DS
  • Anonymous Apr 14, 2008
    Maytag washing machine leaves black marks on clothes (shape of "()").Mark is about 1" across.
  • ac man209 Nov 23, 2008
    shu9925 very small dark grey spots only on plastic items
    appears to be bearing grease.
    New Friend:
I have the same problem on my Bosch dishwasher Model # SHX33A05UC. It is about 6 years old. I have replaced three gaskets and it did not solve the problem. I am a 25 year mechanical engineer. I do not recommend anyone changing these gaskets on their own except for the long dishwasher door gasket (which goes along the top, left and right door edges) which is quite easy to replace. The other two gaskets, which were quite difficult to replace, were the gasket at the bottom of the dishwasher door and the sump pump gasket. I am still having the tar like black tiny dots depositing on my plastic tupper wear on the second shelf. I will likely not buy a Bosch dishwasher ever again. I will make my decision after hearing what Bosch tech support has to say about what I need to replace next. Could it be the rubber drain check valve not operating correctly? I need to find out. I have spent so much time trying to solve this black tar dot problem!!!
Posted on Jan 10, 2016
Best way to remove black grease from fabric?
Removing grease is fairly easy but removing black grease, perhaps not easy at all - you have to consider what is in the grease to make it black, which could be molybdenum disulphide, graphite, carbon or any sort of general dirt, the particles of which are likely to be so fine as to act like a dye and leave a stain.
Depends also on the size of the grease spot and the fabric and what is available to you.
After carefully scraping as much grease from the surface of the fabric as you can it can then be either sponged with white gas or left to soak with a solvent based jelly type hand cleaner such as Swarfega or Klix worked well into the fabric just covering the grease spot.
Once it has soaked for a few hours, scrape off the excess and then sponge with white gas using a wad of absorbent paper or similar as backing and turning the cloth several times to sponge from the back and replacing the pad as required.
Once as much of the grease spot has been removed as possible the fabric can be laundered as normal, though dry cleaning is likely to be most successful though a boil wash could be superior if the fabric is able to be boil-washed, perhaps using some laundry bleach.
Apr 10, 2018 | Washing Machines
Kenmore 70 grease spots
If your starting to see black grease or oil spots on your clothes after washing and it seems to happen more and more chances are the transmission seal is busted and either the whole transmission or just the seal needs replacing.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Apr 24, 2012 | Kenmore Washing Machines
Top load washer leaving flaky black spots on some clothes. This doesn't happen with every load just randomly, but becoming more common. It doesn't damage clothes if I catch it when they come out, I...
It could be a sign one of the rubber hoses is eroding internally or perhaps a bearing is failing.
If a hose the black spots will be easy to remove, if grease, wiping the spots will spread them and they will be harder to remove.
Oct 08, 2017 | Washing Machines
Black grease spots on clothes after the wash I have a simpson espirit 750 washing machine
Hi just read your posting.Are you 100% sure the black marks are grease or oil?If you are then the only place the oil comes from is the gearbox.This means that to repair this fault you need a new gearbox.Unfortunately the repair is not cheap so I would recommend getting a service tech out to confirm.Every time I went to a customers house and I saw this problem then I would tell them the same thing.Once again sorry for the bad news and please reply if you need any more help or advice.Good luck.
Jul 11, 2010 | Whirlpool Washing Machines
GE WHDSR209D2WW has black grease in the wash water
The grease comes from the transmission. Part 320 on this diagram. You can see from the price it may be better to but a new washer.
depends on weather or not you can do it yourself.
Feb 11, 2010 | GE Profile Prodigy WPSE4200A
Noticed after I do a load of laundry there are black (grease) spots on my clothes. I found a grease spot on the bottom of tub. What could this be?
its the topseal on the transmission thats leaking,the term for this is called "back-wash" you need a new seal
Feb 03, 2010 | Washing Machines
Leaves spots
YOUR BEARINGS ARE GOING THE BLACK SPOTS ARE GREASE FROM THE BALL RACER RING THEY SIT IN, IT WILL ONLY GET WORSE & EVENTUALY YOU WONT BE ABLE TO GET IT OUT OF YOUR CLOTHING & THEN YOU DEVELOPE A PUNGENT SMELL THAT WONT GO UNTIL IT IS FIXED, YOU CAN CHANGE THEM YOURSELF BUT IT IS NOT EASY FOR SOMEONE NOT KNOWING WHAT THEY'RE DOING, SORRY, I HOPE THIS HELPS A BIT...
May 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Black marks on clothing
Sounds like grease or oil from transmission may be leaking and finding its way into tub.
Nov 03, 2017 | Kenmore 43142 Front Load Washer
Washing machine problems
Oil or grease due to failing seal on the drum shaft.
Jan 14, 2008 | Washing Machines
Black spots on white laundry
is the washer noisey when spinning? If so its probable that the main bearings are worn, & losing the original grease into the wash tub. At 10-14 yrs old its probably not woth fixing (assuming parts are still available)
Oct 19, 2007 | Kenmore Elite 45986 Front Load Washer
Bosch 23 in. SHU33A Built-In Dishwasher Logo
710 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
