Question about HP Photosmart 4180 All-in-One Printer
HP 4180 printer
I have an HP 4180 all-in-one printer. When just using the copy mode the first page scales properly 1:1, but subsequent pages scale down, each page gets worse. Any ideas?
  • Anonymous May 05, 2008
    I have a F4180 all-in-one printer It is so slow it takes an hour to print of 6 or 7 pages fromthe computer what can I do to correct this problem
  • Anonymous Sep 29, 2008
    it is not working
    Guru:
  • 731 Answers
Try the resetting the printer to factory defaults.
Steps:
1.Turn the Printer OFF, unplug the power cabled from the back of the printer and from the wall outlet.
2.Then, Press and hold the ON button for 30 -60 seconds
3.Take the Ink Cartridges out, Unplug the printer power cable while its ON, press and hold CANCEL and COLOR COPY button and connect the Power cord while holding the buttons.keep Holding the buttons until the printer goes off ,release the button and Push the ON button.
Please let me know, the status. GoodLuck cheers!!
Thank you ...
Posted on Feb 11, 2008
Perfect...I have been racking my brain as to how the heck my printer could possibly not have ink levels it is brand new.
Your information worked and I appreciate it!!
Posted on Oct 09, 2008
How can I enlarge my text on my hp 4180
Posted on Jan 07, 2009
How to shrink document to fit screen size when printing
Scaled Printing
The procedure for specifying a scaling value and printing a document with pages enlarged or reduced to match the document to the paper size is as follows:
1. Open the printer driver setup window, and select Scaled Printing from the Page Layout list on the Page Setup tab.
figure:Select Scaled Printing for Page Layout on the Page Setup tab
2. Using Page Size, select the page size that was set with your application.
3. Do either of the following to set a scaling factor:
Select a Printer Paper Size.
Select a printer paper size, which is different from the Page Size, from the Printer Paper Size list. If the printer paper size is smaller than the Page Size, the page image will be reduced. If the printer paper size is larger than the page size, the page image will be enlarged.6c3578e0-f243-44b0-aa8e-f7bb7752ed56.jpg
figure:Printer Paper Size on the Page Setup tab
Specify a scaling factor.
Directly type in a value into the Scaling box.
figure:Scaling on the Page Setup tab
The current settings are displayed in the Settings Preview on the left side of the printer driver.
4. Click OK.
When you execute print, the document will be printed with the specified scale.
Note
If the application software with which you created the original has the scaled printing function, configure the settings on your application software. You do not need to also configure the same setting in the printer driver. When Scaled Printing is selected, the Staple Side list box appears grayed out and is unavailable (when Duplex Printing is not selected). When Borderless Printing check box is checked for the Page Layout list, Scaled Printing cannot be selected.
Tip
Selecting Scaled Printing changes the printable area.
Hope this helps
Mark
Sep 13, 2014 | Canon PIXMA MX310 All-In-One Printer
Designjet 800 not printing pdf to scale
Go To Below official HP Printer Page For Your problem
HP Support document HP Support Center Hope It's resolve all Your Printer Problem,
Or
Still having Problem Then follow Us For HP Support
Mar 07, 2014 | Office Equipment & Supplies
Can't print colour copies with HP d1470
Check color cartridge good?Go to printer properties > preference>color>remove check mark in print in grey scale.. check for color print..
Dec 22, 2011 | HP Deskjet D1341 InkJet Printer
How do I access the menu/control panel?
MFP and scanner settings can be changed several ways: through the MFP control panel, the software application in use,
the print driver, MarkVision™ Professional, or the Web pages. Settings changed from the application or print driver apply
only to the job being sent to the MFP.
Changes made to print, fax, copy, and e-mail settings from an application override changes made from the control panel.
If a setting cannot be changed from the application, use the MFP control panel, MarkVision Professional, or the Web pages.
Changing a setting from the MFP control panel, MarkVision Professional, or the Web pages makes that setting the user
default.
Menus (A key is shown on the button.) Touch to access the menus. These menus are only
available when the MFP is in the Ready state.
The Menus button is on a gray bar called the navigation
bar. The bar contains other buttons described as follows.
Understanding the copy screens and options
Copy From:
Opens a screen where you can enter the size of the documents you are going to copy.
Touching any of the paper size icons on the follow-on screen will make that your selection and return you to the
Copy Options Screen.
When Original Size is set to Mixed Sizes, you can scan different size original documents (letter and legal size
pages). They will be scaled automatically to fit the selected output media size.
Copy To: Opens a screen where you can enter the size and type of paper on which your copies will be printed.
If the size settings for Copy From and Copy To are different, the MFP will automatically adjust the Scale setting to
accommodate the difference.
If you have a special type or size of paper that you'd like to copy onto that is not normally in the MFP paper trays,
you can select MP Feeder, and manually send the type of paper you want through the MP feeder.
When using Auto Match, the MFP will match the size of the original document as specified in the Copy From box.
If a matching paper size is not loaded in one of the paper trays, the MFP will scale the copy to fit loaded media.
Scale: Creates an image from your copy that is proportionally scaled anywhere between 25% and 400%. Scale can also be
set for you automatically.
When you want to copy from one size of paper to another, such as legal size to letter size, setting your Copy From
and Copy To paper sizes will automatically change the scale to keep all the original document information on your
copy.
Touching the arrow to the left lowers the value by 1%; touching the arrow to the right increases the value by 1%.
Holding your finger on an arrow makes a continuous increment.
Holding your finger on an arrow for two seconds causes the pace of the change to accelerate.
************************Darkness: Adjusts how light or dark your copies will turn out in relation to the original document.****************** here is the link to the full pdf manual for your unit: http://www.lexmark.com/publications/pdfs/2007/x644e/en/ug.pdf#xml=http://support.lexmark.com/lexmark/index?page=answeropen&segment=SUPPORT&userlocale=EN_US&locale=en&type=open&searchid=1270220491739&answerid=16777216&iqaction=6&url=http%3A%2F%2Fwww.lexmark.com%2Fpublications%2Fpdfs%2F2007%2Fx644e%2Fen%2Fug.pdf&productCode=&highlightinfo=106955230,537,548
Apr 02, 2010 | Lexmark X 646e MFP - multifunction ( B/W )...
When trying to print Avery Labels L7160 the top few labels print within each label 'frame' BUT towards the end of the page the labels are printed further up and therefore are out of the label 'frames' ALSO...
For Word 2007/Word 2010
1- Click on the Office button
2- Select Print then Print again.
3- In the Zoom section make sure 'Scale to paper size' is set to 'A4'
4- Click on the Properties button.
5- Click on the Paper / Quality tab, then click on Advanced.
6- In the Paper/ Output section it has Paper size. To the right you have a drop down menu . Make sure A4 is selected and not letter, then click on OK.
3- There may also be other options in your printing preferences such as 'Print Area', 'Scale to Fit Page Size' or 'Page Margins. These will all need to be set correctly for your design to print 100% e.g. Print Area set to Maximum, Scale to fit Page Size disabled and Page Margins set to Minimized.
Some printers ( for example Epson printers ) have a 'Reduce /Enlarge' facility that defaults to 94% or 97% (instead of 100%). To set this to 100% click the 'Layout' tab and in the 'Reduce/Enlarge' section select 'Custom' you should then be able to change the scaling to 100%.
Mar 12, 2010 | HP LaserJet 3050 All-In-One Printer
Hi, if I am printing a form, my 5L printer cannot print the full pages, it runs into two or more pages.What needs adjustment? thank you
The issue could either be in your general printer setup (adjust the scaling % in the printer options) or in the application you are printing (adjust the page setup scaling % or it may possibly have the option to print 1 page high x 1 page wide).
Feb 10, 2010 | HP LaserJet 5L Printer
How do I change the print size on my D4160 hp printer
There basically two approaches to changing the print size of your printer whether D4160 printer or any modern other particularly hp printer.
1. Go to file/print or simply do ctrl P on your keyboard. The print menu pops up. Go to properties/features. When the features tab opens look for resizing options. Under resizing options you will see print at actual size and scale to paper size. Select scale to paper size and list box will activated. Select the paper size to scale to from the list. If you are not familiar with paper sizes then this list introduction should do. The conventional official paper size is A4, half of that is A5, and half of that is A6.
2. The other procedure is to simply right click on the image and select print. A print wizard pops up. It enables you to chose size of images and automatically fits them into 1 per page, 2 per page or 4 per page depending on how many images you selected in the first place. However this is meant specifically for images/photos.
3. Again you may decide to physically resize them in the application (Word, CorelDraw etc) you are working with before sending print.
Sep 03, 2009 | HP Deskjet D4160 InkJet Photo Printer
Problems printing a booklet
What size paper are you printing on? Reset the side margin to make narrow and see if that helps.
Sep 23, 2017 | HP Officejet Pro 8500 Wireless All-In-One...
Scaling drawings automatically HP8100
Check the printer settings and make sure to set the "Fit To Page" option to "None".
Jan 15, 2009 | HP DesignJet 1050c plus InkJet Printer
HP Photosmart 4180 All-in-One Printer Logo
1,169 people viewed this question
Ben Johnson
