Back to:
Tags:
GE VG4040 VCR
No power
posted by jlp140766 on Feb 11, 2008
My GE VG4040 has no power. The cord is OK. The fuse is not blown. But no LED comes up when power button is pressed. Any clue?
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Feb 11, 2008
Not Rated (0)
sharcnet
Rank:Guru Guru
Rating: 92%, 399 votes
I assume you unplugged the unit for several minutes and tried plugging it back in to reset it. Is the outlet ok? Did you try plugging something else into the same outlet and it worked?
If the cord is ok and the fuse isn't blown and the VCR is completely dead, I would say that you have a problem in the power supply section. This could be a bad transformer, rectifier or regulator module. Unfortunately you'll need to take it to be serviced.
Please let me know if I can be of further assistance to you.
- Jim
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on no power:
I don't want to Accept this solution
Can you Help with these VCRs problems?
VCRs
I can't figure out how to tape a tv show on the vcr mode,...
VCRs
Trying to engage VCR to TV [Audio logic P1430] without...
VCRs
I have a hitachi video recorder vt-rm800ev and i need a...
VCRs
How do I stop a VCR recording? Digilogic VCR/DVD Combi...
GE VG4040 VCR
The time counter always resets itself to 0:00:00, and then...
Loading problems.
Repair Service
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
